Carlo 4561 Posted January 27, 2021 Posted January 27, 2021 ROBOCOPY Source_folder Destination_folder *.* /S We are worried about copying to any specific spot, just if load times going on for the files copied.
bigcookie 12 Posted January 29, 2021 Author Posted January 29, 2021 (edited) Sorry - I didnt see the second page appearing, thus being late. I had to fire up a virtual machine with Win10 on a Macbook Pro for now. Folder access via Samba. Executed your commandline. Currently running. I would say roughly 1s for a 2MB file to be copied. As I understand, this means reading from Samba and writing to Samba including overhead. All over Wifi, same location as when using Emby - but it is not the best spot in the apartment. When moving close to the route, it is about a 7-8MB images per second, which is successfully copied. Will post the result when done. BUT I noticed something, which might be an issue: Somehow my online file browser didnt show the extension so that I noticed it. The images in this folder I do get from foreign camera and some of them are HEIC images. Could this be the issue? I am happy to share some via PM... Edit: CPU on NAS stays at <10% during the copy process Edited January 29, 2021 by bigcookie
bigcookie 12 Posted January 29, 2021 Author Posted January 29, 2021 (edited) OK, here we are. PLease note: - robocopy cunning on a virtual machine using parallels on a macbook pro - Folder has been connected via Samba - Network connection was Wifi in a mid optimal spot via 5GHz (in between I moved to an optimal spot, which showed clear increase of speed) - folder size is 4,4GB Folder contains JPG and HEIC images (the HEIC images I overlooked prior) Edited January 29, 2021 by bigcookie
bigcookie 12 Posted January 29, 2021 Author Posted January 29, 2021 I removed the HEIC and CR2 images from the folder and rescanned the library and navigated to the folder to generate thumbnails - didn't make a difference for generating thumbnails. I navigated to another folder with a big number of JPG and the thumbnails still get created fast - BUT the CPU load touches 100% on that job too, but not really blocking everything. Navigation felt still normal and as stated thumbs have been generated fast.
