mrmcphisto 0 Posted January 20, 2021 Posted January 20, 2021 Hi all, i've got the following problem when reproducing .avi .mkv or .mp4: 10:16:21.486 ffmpeg version 4.3.0-emby_2020_05_23 Copyright (c) 2000-2019 the FFmpeg developers and softworkz for Emby LLC 10:16:21.487 built with gcc 8.3.0 (crosstool-NG 1.24.0) 10:16:21.487 Execution Date: 2021-01-20 10:16:21 10:16:21.506 [mov,mp4,m4a,3gp,3g2,mj2 @ 0x13b45e0] moov atom not found 10:16:21.506 /home/pi/Desktop/Condivisa/Film/Ve ne dovevate andare.mp4: Invalid data found when processing input 10:16:21.507 Attached complete logs for further investigation embyserver.txt ffmpeg-transcode-6c7b0298-9978-41dc-bd34-d428d01b53d4_1.txt
mrmcphisto 0 Posted January 21, 2021 Author Posted January 21, 2021 Usb on a raspberry pi 4. I tried even on its sd card. Same error
Luke 42246 Posted January 22, 2021 Posted January 22, 2021 Can you please provide a log example from an mkv? Thanks.
Happy2Play 9814 Posted January 22, 2021 Posted January 22, 2021 Does this file play outside of Emby? As the logs show it can't be probed. System.Exception: System.Exception: ffprobe failed for file:"/home/pi/Desktop/Condivisa/Film/Ve ne dovevate andare.mp4" - streams and format are both null: { } {"Protocol":"File","Id":"3f846b0b3f70f64b791efd376fe328c0","Path":"/home/pi/Desktop/Condivisa/Film/Ve ne dovevate andare.mp4","Type":"Default","Container":"mp4","Size":0,"Name":"Ve ne dovevate andare","IsRemote":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"RequiresLooping":false,"SupportsProbing":false,"MediaStreams":[],"Formats":[],"RequiredHttpHeaders":{},"ReadAtNativeFramerate":false} Another library is showing a IO issue also 2021-01-20 10:15:59.940 Error LibraryMonitor: Error watching path: /home/pi/Desktop/Condivisa/FilmPerTutti *** Error Report *** Version: 4.5.4.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_armhf.deb Operating system: Linux version 5.4.83-v7l+ (dom@buildbot) (gcc version 8.4.0 (Ubuntu/Linaro 8.4.0-3ubuntu1)) #1379 SMP Mon Dec 14 13:11:54 GMT 2020 Framework: .NET Core 3.1.8 OS/Process: arm/arm Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/lib/emby Application path: /opt/emby-server/system System.IO.IOException: System.IO.IOException: Input/output error at System.IO.Enumeration.FileSystemEnumerator`1.FindNextEntry(Byte* entryBufferPtr, Int32 bufferLength) at System.IO.Enumeration.FileSystemEnumerator`1.MoveNext() at System.IO.FileSystemWatcher.RunningInstance.AddDirectoryWatchUnlocked(WatchedDirectory parent, String directoryName) at System.IO.FileSystemWatcher.RunningInstance.AddDirectoryWatchUnlocked(WatchedDirectory parent, String directoryName) at System.IO.FileSystemWatcher.RunningInstance..ctor(FileSystemWatcher watcher, SafeFileHandle inotifyHandle, String directoryPath, Boolean includeSubdirectories, NotifyFilters notifyFilters, CancellationToken cancellationToken) at System.IO.FileSystemWatcher.StartRaisingEvents() at System.IO.FileSystemWatcher.StartRaisingEventsIfNotDisposed() at System.IO.FileSystemWatcher.set_EnableRaisingEvents(Boolean value) at Emby.Server.Implementations.IO.LibraryMonitor.<>c__DisplayClass37_0.<StartWatchingPath>b__0() Source: System.IO.FileSystem TargetSite: Void FindNextEntry(Byte*, Int32)
mrmcphisto 0 Posted January 23, 2021 Author Posted January 23, 2021 This is for the mkv as per request: 2021-01-23 12:39:35.940 Operating System: Linux version 5.4.83-v7l+ (dom@buildbot) (gcc version 8.4.0 (Ubuntu/Linaro 8.4.0-3ubuntu1)) #1379 SMP Mon Dec 14 13:11:54 GMT 2020 OS/Process: arm/arm Emby Server version: 4.5.4.0 Operating system: Unix 5.4.83.7 Command Line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_armhf.deb App: Emby Web 4.5.4.0 Chrome http://192.168.188.49:8096/emby/videos/1411/live.m3u8?DeviceId=4f67d509-8493-4a26-846e-d5d829d0f3c0&MediaSourceId=2050827552521e002f0a4d4574f08bfd&PlaySessionId=9f3f5473f0474714b7ad83c382c0699a&api_key=6c2ce618e694425bae409d636e53a7e6&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=139808000&AudioBitrate=192000&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=2&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&TranscodeReasons=VideoCodecNotSupported,DirectPlayError&allowVideoStreamCopy=false&allowAudioStreamCopy=false {"Protocol":"File","Id":"2050827552521e002f0a4d4574f08bfd","Path":"/home/pi/Desktop/Condivisa/Film/The lodge (2020) ITA-ENG Ac3 5.1 BDRip 1080p H264 [ArMor].mkv","Type":"Default","Container":"mkv","Size":0,"Name":"The lodge (2020) ITA-ENG Ac3 5.1 BDRip 1080p H264 [ArMor]","IsRemote":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"RequiresLooping":false,"SupportsProbing":false,"MediaStreams":[],"Formats":[],"RequiredHttpHeaders":{},"ReadAtNativeFramerate":false} >>>>>> User policy for emby EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True /opt/emby-server/bin/ffmpeg -loglevel +timing -y -print_graphs_file "/var/lib/emby/logs/ffmpeg-transcode-5753ce32-c693-4731-8163-8f5685256d6a_1graph.txt" -copyts -start_at_zero -f matroska,webm -i "/home/pi/Desktop/Condivisa/Film/The lodge (2020) ITA-ENG Ac3 5.1 BDRip 1080p H264 [ArMor].mkv" -map 0:0 -vn -sn -c:a:0 libmp3lame -ab:a:0 192000 -ac:a:0 2 -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "/var/lib/emby/transcoding-temp/CC805C.m3u8" -segment_list_type m3u8 -segment_time 3 -segment_list_entry_prefix hls/CC805C/ -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "/var/lib/emby/transcoding-temp/CC805C_%d.ts" 12:39:36.000 ffmpeg version 4.3.0-emby_2020_05_23 Copyright (c) 2000-2019 the FFmpeg developers and softworkz for Emby LLC 12:39:36.001 built with gcc 8.3.0 (crosstool-NG 1.24.0) 12:39:36.001 Execution Date: 2021-01-23 12:39:36 12:39:36.019 [matroska,webm @ 0xc3a5e0] Found unknown-length element with ID 0xFF at pos. 0x0 for which no syntax for parsing is available. 12:39:36.019 [matroska,webm @ 0xc3a5e0] EBML header parsing failed 12:39:36.019 /home/pi/Desktop/Condivisa/Film/The lodge (2020) ITA-ENG Ac3 5.1 BDRip 1080p H264 [ArMor].mkv: Invalid data found when processing input 12:39:36.019 ======= ExtraData 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
marciomaiden 3 Posted January 23, 2021 Posted January 23, 2021 I started having the same problem. 6:16:24.200 [mov,mp4,m4a,3gp,3g2,mj2 @ 0x236fa00] moov atom not found 16:16:24.200 /EP02.mp4: Invalid data found when processing input I use ubuntu 20.04 with rclone for google disk
marciomaiden 3 Posted January 23, 2021 Posted January 23, 2021 I have these errors *** Error Report *** Version: 4.5.4.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.4.0-64-generic (buildd@lcy01-amd64-021) (gcc version 9.3.0 (Ubuntu 9.3.0-17ubuntu1~20.04)) #72-Ubuntu SMP Fri Jan 15 10:27:54 UTC 2021 Framework: .NET Core 3.1.8 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 2 Data path: /var/lib/emby Application path: /opt/emby-server/system System.Exception: System.Exception: ffprobe failed for file:"DL.DDP5.1.H.264-NTb.mkv" - streams and format are both null: { } ffprobe version 4.3.0-emby_2020_05_23 Copyright (c) 2007-2019 the FFmpeg developers and softworkz for Emby LLC built with gcc 8.3.0 (crosstool-NG 1.24.0) file:/F.WEB-DL.DDP5.1.H.264-NTb.mkv: Input/output error
Q-Droid 1011 Posted January 31, 2021 Posted January 31, 2021 Are you able to play the very same files using something like VLC?
mrmcphisto 0 Posted February 1, 2021 Author Posted February 1, 2021 Sorry Just busy vlc yes folder is a usb share mounted on fstab
Q-Droid 1011 Posted February 1, 2021 Posted February 1, 2021 Quote {"Protocol":"File","Id":"3f846b0b3f70f64b791efd376fe328c0","Path":"/home/pi/Desktop/Condivisa/Film/Ve ne dovevate andare.mp4","Type":"Default","Container":"mp4","Size":0,"Name":"Ve ne dovevate andare","IsRemote":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"RequiresLooping":false,"SupportsProbing":false,"MediaStreams":[],"Formats":[],"RequiredHttpHeaders":{},"ReadAtNativeFramerate":false} The "Size":0 is not a good sign. It also supports the invalid data/format and null content errors. For some reason it can't read the file contents, if there are any. Usually it's permissions but I think those errors would be different, access related. Make sure those files do have data, are the right size and can be accessed by emby on the Pi. Plugging the USB in another machine could show if they are indeed playable media files but emby must be able to read them on the Pi.
Luke 42246 Posted April 14, 2021 Posted April 14, 2021 @mrmcphisto are you still having an issue with this?
