leihao 1 Posted May 6, 2022 Posted May 6, 2022 Thank you. It works perfectly! All my missing Actor photos is showing now. Your work save my time. 1
tr0nllam 36 Posted May 23, 2022 Posted May 23, 2022 Have you made any progress on preventing the plug-in from auto-fetching the person metadata even if the setting is off? Because of the slowdown that causes, I had to re-install the Custom Person Provider plug-in to use in tandem with this one, but having both plug-ins installed messes with the settings page of the Custom Person Provider plug-in.
mickle026 653 Posted May 23, 2022 Author Posted May 23, 2022 9 hours ago, tr0nllam said: Have you made any progress on preventing the plug-in from auto-fetching the person metadata even if the setting is off? Because of the slowdown that causes, I had to re-install the Custom Person Provider plug-in to use in tandem with this one, but having both plug-ins installed messes with the settings page of the Custom Person Provider plug-in. Im not uderstanding which other plugin you have installed. The Custom Person Provider replaces my other plugins totally.
tr0nllam 36 Posted May 23, 2022 Posted May 23, 2022 (edited) 3 hours ago, mickle026 said: Im not uderstanding which other plugin you have installed. The Custom Person Provider replaces my other plugins totally. I'm using the old Custom Person Provider in addition to the new Custom Provider, since the old Custom Person Provider doesn't have the slowdown associated with the attempted metadata retrieval of the new plugin. I just turned off the Custom Provider search in the new one. Ideally, I would only use the new one, but with the Fetchers enabled, theres around a 5-second delay when opening an actor page w/o metadata and then an additional 5-second delay just to open the image search page. This all happens before an image search even occurs. Edited May 23, 2022 by tr0nllam
mickle026 653 Posted May 24, 2022 Author Posted May 24, 2022 20 hours ago, tr0nllam said: I'm using the old Custom Person Provider in addition to the new Custom Provider, since the old Custom Person Provider doesn't have the slowdown associated with the attempted metadata retrieval of the new plugin. I just turned off the Custom Provider search in the new one. Ideally, I would only use the new one, but with the Fetchers enabled, theres around a 5-second delay when opening an actor page w/o metadata and then an additional 5-second delay just to open the image search page. This all happens before an image search even occurs. I don't see that in my system any more but ill try to replicate it and see whats going on.
hotlattle 0 Posted May 27, 2022 Posted May 27, 2022 Thank you very much. This plug-in has helped me a lot. Although I haven't fully understood it yet.
Dez_Lamar 10 Posted June 15, 2022 Posted June 15, 2022 This might just be on Linux but, under repair tab the function to use the .actor folder to import actor pictures has no end point it just keeps running continuously with stopping point @mickle026
Abobader 3485 Posted June 15, 2022 Posted June 15, 2022 @mickle026 What the latest build file to download? Thanks
GrimReaper 4906 Posted June 15, 2022 Posted June 15, 2022 3 minutes ago, Abobader said: @mickle026 What the latest build file to download? Thanks AFAIK Apr 21st, that's the one I'm using. 1
warrentc3 47 Posted June 15, 2022 Posted June 15, 2022 On 4/21/2022 at 12:37 AM, mickle026 said: Latest build. Zip contains build for stable server (CustomProviderStable.dll), and beta server (CustomProviderbeta.dll). Any chance you could maintain releases, versioning, and change notes in the original post?
mickle026 653 Posted June 15, 2022 Author Posted June 15, 2022 1 minute ago, GrimReaper said: AFAIK Apr 21st, that's the one I'm using. Yes thats the latest on here, I cannot post the one on my server at the moment because of a few issues, but I have figured out what causes the slow down with pages with missing metadata, and done a lot more "behind the scenes" since that build as I have figured out quite a bit more and how it works. It will come, its just not ready yet. As for maintaining build notes on here, I ought to split off to a dedicated plugin page as this is not even the same plugin as post 1. 1
mickle026 653 Posted June 16, 2022 Author Posted June 16, 2022 (edited) I'll post this for now. Consider it just a preview... Please keep the one you are currently using backed up somewhere and don't treat this as the latest version. In the QuickLinks there is a new entry "movie metadata settings" page, nothing here works so ignore it for now. Whats different? - Quite a lot but not much visibly to see, the main thing is TXT imports for now Matadata slow downs shouldn't happen in movie pages. (no guarantees!) Importing from TXT files with certain data should work from the local movie directory. Enable this at the bottom of Fetchers page It will look for any of these files in the movie directory Cast.txt or cast.txt About.txt or about.txt Info.txt or info.txt Rating.txt or rating.txt Studio.txt or Studios.txt Genre.txt or Genres.txt Category.txt categories.txt and search them for stings that start with these words To add People, use csv values featuring: Cast: Starring: Actors: Casting: Pornstars: Director: Writer: Producer: To add Studios use csv values Studio: Studios: Production House: Production Company: Label: To add Ratings use csv values Rating: BBFC: Certification: To Add Genres use csv values Categories: Categorie: Category: Genres: Genre: Tags: To Add Collections values to Movie Data Collection: Group: Series: An Example is this (Adult), Must be Comma seperated! About.txt in \Movies\R18\My Friend's Hot Mom Vol. 13 (2008) Starring: Brenda James, Nicole Moore, Kelly Leigh, Crystal Court, Bridgette Lee , Georgina Smith Categories: Mature, MILF Rating: XXX Studio: Naughty America Collection: My Friend's Hot Mom Resulting in You only need to metadata refresh for this to work, however Collections do not add to the collections on screen, but the data is there (added to the movie internally) for a boxset lookup, which seems to only be triggered on adding new movies but not metadata refreshes - hopefully i'll find out why.... I now have a boxset lookup adapter in the code but its not looking for anything yet ..... As I said this is just a preview it will be better than this when its finally released Almost forgot Overview.txt file in the same location containing th overview/plot only. No keyword at the front. The whole file is added to the overview. CustomProvider.zip Edited June 16, 2022 by mickle026
tr0nllam 36 Posted June 16, 2022 Posted June 16, 2022 Unfortunately, the missing metadata slowdown is still happening. It actually seems a bit worse because there's now a slight pause when right-clicking on an actor without metadata even when the custom image scraper is disabled, which was not the case in the old version. The extreme slowdown is still there when they are enabled as well.
mickle026 653 Posted July 1, 2022 Author Posted July 1, 2022 Anyone willing to test an Adult Movie plugin for me? (Currently fetches movie poster, plot, genres , actors (but no actor images) etc ) This is for movies , ie DVD titles and not for scenes. I want to know how accurate it is or if it miss-identifies titles. So best not to test on production server, only a test server? Its seperate from Custom Provider at the moment, but the intention is to add it in eventually. Oh and its not a scraper, its fetching from one of my own databases.
paddy75 16 Posted August 20, 2022 Posted August 20, 2022 you wrote: Quote To Add Genres use csv values Categories: Categorie: Category: Genres: Genre: Tags: but "tags" are not a Genre. All what is in the csv with "Tags:" should go into the "Tags" in emby right?
mickle026 653 Posted August 20, 2022 Author Posted August 20, 2022 6 hours ago, paddy75 said: you wrote: but "tags" are not a Genre. All what is in the csv with "Tags:" should go into the "Tags" in emby right? I agree, but when using other peoples nfo files, txt, info files etc, the word Tags in them refers to Genres. So if it were an import of my own generated files then I would have imported them to the Emby Tags, but as this is meant to be helpful to import from txt files in the directory they are imported to genres. (I may remove that from genres later on and add as tags)
paddy75 16 Posted August 21, 2022 Posted August 21, 2022 sounds good. any idea when you will release the next version? have a lot of old movies with missing actors pictures
mickle026 653 Posted August 21, 2022 Author Posted August 21, 2022 6 hours ago, paddy75 said: sounds good. any idea when you will release the next version? have a lot of old movies with missing actors pictures Do you not use my server in the providers, there are lots on there? with this config (disable) scrapers if you dont want to use them)
paddy75 16 Posted August 21, 2022 Posted August 21, 2022 i tried it but was not successfull. 21.Aug.2022 - 19.07.49 Request Made By: Dorothy Patten ,Type: MediaBrowser.Controller.Entities.Person from CP.CS (IEnumerable<RemoteImageInfo>> GetImages) 21.Aug.2022 - 19.07.57 Emby Custom Provider Call to retrieve Movie Metadata 21.Aug.2022 - 19.07.57 Name: Das Schiff der Verurteilten, Year: 1952, IMDB: tt0045574, TMDB: 168330, TVDB: , Custom: 21.Aug.2022 - 19.07.57 Task<MetadataResult<Movie>> IRemoteMetadataProvider<Movie, MovieInfo>.GetMetadata(MovieInfo info, CancellationToken cancellationToken) 21.Aug.2022 - 19.07.57 Caller: Das Schiff der Verurteilten (1952) 21.Aug.2022 - 19.07.57 Checking for local TXT file data 21.Aug.2022 - 19.07.57 Checking for Backup XML file data 21.Aug.2022 - 19.07.57 FG_XmlReader Cannot Find File: /MovieDB/MovieName/Das Schiff der Verurteilten (1952)/Info.xml 21.Aug.2022 - 19.07.57 FG_XmlReader Cannot Find File: /AdultDB/MovieName/Das Schiff der Verurteilten (1952)/Info.xml I see that the fetcher search for the german title and can't found it. Maybe it makes more sense to search for the original title??
mickle026 653 Posted August 21, 2022 Author Posted August 21, 2022 There are 2 separate calls there. I don't have Dorothy Patten in my backup. (Person call) So she won't be found. And the movie Das Schiff der Verurteilten (English title botany bay) not be found in my data either. (Movie call) Media and meta contains all of the info that I have it's not as big as tmdb, but has a good number that they don't have. Also a lot of people they don't have. Did you have any success with others?
mickle026 653 Posted August 21, 2022 Author Posted August 21, 2022 Dorothy Pattem Info for you http://www.elisarolle.com/queerplaces/ch-d-e/Dorothy Patten.html
paddy75 16 Posted August 21, 2022 Posted August 21, 2022 sure, a newer one is "Alexander from 2004" Missing is: Jessie Kamm Patrick Carroll Peter Williamson Morgan Christopher Ferris Robert Earley Quote Quote 21.Aug.2022 - 20.15.57 Request Made By: Robert Earley ,Type: MediaBrowser.Controller.Entities.Person from CP.CS (IEnumerable<RemoteImageInfo>> GetImages) 21.Aug.2022 - 20.18.31 Emby Custom Provider Call to retrieve Movie Metadata 21.Aug.2022 - 20.18.31 Name: Alexander, Year: 2004, IMDB: tt0346491, TMDB: 1966, TVDB: , Custom: 21.Aug.2022 - 20.18.31 Task<MetadataResult<Movie>> IRemoteMetadataProvider<Movie, MovieInfo>.GetMetadata(MovieInfo info, CancellationToken cancellationToken) 21.Aug.2022 - 20.18.31 Caller: Alexander (2004) 21.Aug.2022 - 20.18.31 Checking for local TXT file data 21.Aug.2022 - 20.18.31 Checking for Backup XML file data 21.Aug.2022 - 20.18.31 FG_XmlReader Cannot Find File: /MovieDB/MovieName/Alexander (2004)/Info.xml 21.Aug.2022 - 20.18.31 FG_XmlReader Cannot Find File: /AdultDB/MovieName/Alexander (2004)/Info.xml
paddy75 16 Posted August 28, 2022 Posted August 28, 2022 Any idea when you can change that "tags" goes into "tags" and release this? So i could go ahead to test my worklow
mickle026 653 Posted August 28, 2022 Author Posted August 28, 2022 (edited) 9 hours ago, paddy75 said: Any idea when you can change that "tags" goes into "tags" and release this? So i could go ahead to test my worklow This is the stable build (not built for the beta server) with 4.60.50 server core nuget. This has Tags split off to add tags instead of genres, I dont think anything else is changed since the last release (Although im not entirely sure) I have not tested it, so you will have to let me know if it works or not. My advice is keep the one your using backed up somewhere, incase I built the wrong version, so you can revert back. CustomProviderStable.zip Edited August 28, 2022 by mickle026
paddy75 16 Posted August 28, 2022 Posted August 28, 2022 looks good at the moment. My workflow is working what i was looking for.
