paddy75 16 Posted August 29, 2022 Posted August 29, 2022 only hast problems with special caracters during the import from csv. é for example is imported as a questionmark inside a square --> don't know how to translate it into english think has here problems with UTF
mickle026 653 Posted August 29, 2022 Author Posted August 29, 2022 OK, added a utf8 conversion to the text to provide utf support so Acción becomes Acción Again, not tested this CustomProviderStable.zip
mickle026 653 Posted August 29, 2022 Author Posted August 29, 2022 perhaps your text file is a different encoding such as utf16 utf16le or utf32 ?
paddy75 16 Posted August 29, 2022 Posted August 29, 2022 arrrr, yes. Didn't set the encoding in my powershell. now is working
Dez_Lamar 10 Posted August 30, 2022 Posted August 30, 2022 @mickle026 Is it possible to use this plug-in to backup actors in a specific library? Like for example if I just wanted to back up actors from my tv show library would I be able to do that?
mickle026 653 Posted August 30, 2022 Author Posted August 30, 2022 2 hours ago, TallBoiDez said: @mickle026 Is it possible to use this plug-in to backup actors in a specific library? Like for example if I just wanted to back up actors from my tv show library would I be able to do that? In the current form this is only supported to the media folers via creating kodi style ".actors" folders. It is not the same as People backup as it doesnt save anything oither than the images. 1
Luke 42250 Posted October 24, 2022 Posted October 24, 2022 On 10/23/2022 at 3:31 AM, Spegeli said: Any new Updates of this Plugin? Hi, what kind of update are you looking for?
mickle026 653 Posted October 24, 2022 Author Posted October 24, 2022 It will be a while before anything is released because the plugin is getting a full rewrite to remove the existing issues. New items will be in the new release when its ready. It'll completely replace this version.
tr0nllam 36 Posted December 20, 2022 Posted December 20, 2022 Is it just me or does the IMDB Person Image Scraper no longer work? For a while, it was occasionally failing to fetch an image, but now I no longer see any IMDB images.
GrimReaper 4906 Posted January 20, 2023 Posted January 20, 2023 Run "Backup People (Movie and Series Cast Images)" task, backup folder created however not a single image created, NFOs only. 4.7.10.0 stable.
mickle026 653 Posted January 20, 2023 Author Posted January 20, 2023 ok, im busy right now but ill take a look when i have time. Thanks for letting me know.
letterman 40 Posted February 15, 2024 Posted February 15, 2024 (edited) I am happy finding this plugin. unfortunately it seems not to work with emby 4.8.1.0. I just need a bulk refresh of people/actors. Can anyone help me how to do it now? @mickle026: Are you still coding at this plugin? I do also need a solution to export/import collections (songs, album, artists etc). There is no way within emby right now. Edited February 15, 2024 by letterman
sftech13 25 Posted December 22, 2024 Posted December 22, 2024 @mickle026are you still working on this? If not do you have a git that you can share. I need the livetv logo refresh. Thank you
mickle026 653 Posted December 22, 2024 Author Posted December 22, 2024 The answer is no. I am very slowly working on a different (new) version which has a lot better and more robust code now im 2 years on in my c# learning... However the plugin is still avaliable a few posts above this on (in page 10) and the live tv logo removal tool still works in it. Just use it for that and remove it again, a lot of the original plugin is redundant. It still removes the logos, and then when you run a guide update afterwards they will re-populate. 1
phoenix4 1 Posted January 3, 2025 Posted January 3, 2025 On 22/12/2024 at 16:39, mickle026 said: and the live tv logo removal tool still works in it Might just be me but it looks like this is broken now also? (Emby server version 4.8.10.0, plugin version 1.0.0.3752 from 29-Aug post) It gives that "Finished!" message with the log filename (although I can't find any such files on the server), but the channel logos are still present.
sftech13 25 Posted January 6, 2025 Posted January 6, 2025 On 1/2/2025 at 10:34 PM, phoenix4 said: Might just be me but it looks like this is broken now also? (Emby server version 4.8.10.0, plugin version 1.0.0.3752 from 29-Aug post) It gives that "Finished!" message with the log filename (although I can't find any such files on the server), but the channel logos are still present. I ran into the same issue but found that there was a script made by @BillOatmanI altered the script so that will remove logos and refresh guide by CLI if you want to use it. https://github.com/sftech13/EmbyRefreshLogos
BillOatman 597 Posted January 6, 2025 Posted January 6, 2025 3 hours ago, sftech13 said: I ran into the same issue but found that there was a script made by @BillOatmanI altered the script so that will remove logos and refresh guide by CLI if you want to use it. https://github.com/sftech13/EmbyRefreshLogos Maybe should rename to EmbyRemoveLogos 1
mickle026 653 Posted January 7, 2025 Author Posted January 7, 2025 (edited) Strange. but I am not arguing , this old plugin is long since depricated. However , I just copied the code to my new plugin that I am working on, didnt change a thing (except the logging because I use a better method now) and it works flawlesly. So there must be something changed in the old plugin nuget server core. I cannot see that any of that would matter though but it must do if it isnt working. 07.Jan.2025 - 15.33.31[Delete Logos] Found 432 Channels 07.Jan.2025 - 15.33.31[Delete Logos] looking at Channel (1): BBC TWO Deleting Primary Image: BBC TWO Deleting LogoLight Image: BBC TWO Deleting LogoLightColor Image: BBC TWO 07.Jan.2025 - 15.33.31[Delete Logos] looking at Channel (2): ITV1 Deleting Primary Image: ITV1 Deleting LogoLight Image: ITV1 Deleting LogoLightColor Image: ITV1 07.Jan.2025 - 15.33.31[Delete Logos] looking at Channel (3): Channel 4 Deleting Primary Image: Channel 4 Deleting LogoLight Image: Channel 4 Deleting LogoLightColor Image: Channel 4 07.Jan.2025 - 15.33.31[Delete Logos] looking at Channel (4): Channel 5 Deleting Primary Image: Channel 5 Deleting LogoLight Image: Channel 5 Deleting LogoLightColor Image: Channel 5 07.Jan.2025 - 15.33.31[Delete Logos] looking at Channel (5): ITV2 Deleting Primary Image: ITV2 Deleting LogoLight Image: ITV2 Deleting LogoLightColor Image: ITV2 07.Jan.2025 - 15.33.31[Delete Logos] looking at Channel (6): BBC FOUR Deleting Primary Image: BBC FOUR Deleting LogoLight Image: BBC FOUR Deleting LogoLightColor Image: BBC FOUR 07.Jan.2025 - 15.33.31[Delete Logos] looking at Channel (7): ITV3 Deleting Primary Image: ITV3 Deleting LogoLight Image: ITV3 Deleting LogoLightColor Image: ITV3 If any one wants to do this in c#, it is really simple:- This is all I do, get a list of tv channels, then go through them deleting the 3 types of logo (Primary, LogoLight and LogoLightColor) directly updating the library with library manager. Of course you can do this in any language. This can be made even simpler and streamlined if you care to do it, this is old code. public string RunDeleteLiveTVChannelLogos(string logname, string OptionalPath = "") { config = Plugin.Instance.Configuration; Current = this; string LogPath = Current.configurationManager.ApplicationPaths.LogDirectoryPath; string currentlog = Path.Combine(LogPath, $"MechBox-[{logname}]-" + DateTime.Now.ToString("dd.MMM.yyy-HH'.'mm'.'ss") + ".txt"); var log = new FileLogging(); var AllChannels = libraryManager.GetInternalItemIds(new InternalItemsQuery { IncludeItemTypes = new[] { typeof(LiveTvChannel).Name } }); log.LogToMyFile(currentlog, DateTime.Now.ToString("dd.MMM.yyy - HH'.'mm'.'ss") + $"[Delete Logos] Found {AllChannels.Length} Channels"); var i = 0; foreach (var SingleChannel in AllChannels) { i++; var channelNameID = libraryManager.GetItemById(SingleChannel); var pImage = channelNameID.GetImages(ImageType.Primary); var pImage2 = channelNameID.GetImages(ImageType.LogoLight); var pImage3 = channelNameID.GetImages(ImageType.LogoLightColor); try { log.LogToMyFile(currentlog, DateTime.Now.ToString("dd.MMM.yyy - HH'.'mm'.'ss") + $"[Delete Logos] looking at Channel ({i}): {channelNameID.Name}"); foreach (var imag in pImage) { channelNameID.DeleteImage(ImageType.Primary, 0); libraryManager.UpdateImages(channelNameID); log.LogToMyFile(currentlog, $"Deleting Primary Image: {channelNameID}"); } foreach (var imag in pImage2) { channelNameID.DeleteImage(ImageType.LogoLight, 0); libraryManager.UpdateImages(channelNameID); log.LogToMyFile(currentlog, $"Deleting LogoLight Image: {channelNameID}"); } foreach (var imag in pImage3) { channelNameID.DeleteImage(ImageType.LogoLightColor, 0); libraryManager.UpdateImages(channelNameID); log.LogToMyFile(currentlog, $"Deleting LogoLightColor Image: {channelNameID}"); } } catch (Exception e) { log.LogToMyFile(currentlog, $"Exception: {e.ToString()}"); } } log.LogToMyFile(currentlog, DateTime.Now.ToString("dd.MMM.yyy - HH'.'mm'.'ss") + $"[Delete Logos] Completed."); string output = "Completed."; return output; } Edited January 7, 2025 by mickle026 1
phoenix4 1 Posted January 8, 2025 Posted January 8, 2025 I ended up doing the same thing in nodered actually, although only for the primary images as those are the ones synchronised from tvheadend.
