TrackZ 16 Posted August 6, 2014 Posted August 6, 2014 Hello. Is there any way to custom control the thumbnail image used for extras when viewing in clients like the web client? If the extra is a video file, then MB will extract an image and use that, but if MB cannot get an image, the extra shows up with the clicker icon.
Debug Mode 2 Posted August 7, 2014 Posted August 7, 2014 (edited) Create a picture in the same folder called [file name]-thumb.[extension]. You can also tag it, if you click on the entry with the middle mouse button. Edited August 7, 2014 by Debug Mode
TrackZ 16 Posted September 1, 2014 Author Posted September 1, 2014 Create a picture in the same folder called [file name]-thumb.[extension]. You can also tag it, if you click on the entry with the middle mouse button. Finally got around to trying this out and its not working for me. I have a filename-thumb.jpg in the folder with the special feature ISO. MB in the web client keeps showing the extracted image, not my custom image. I've tried a bunch of different thing from refresh to moving the feature out and back in. How can I get MB to pick up this file? Thanks.
Beardyname 198 Posted September 1, 2014 Posted September 1, 2014 You can edit most of the pictures for every (almost?) item in the web-client, should be what you are looking for ? Just go to the file/movie and press edit.
TrackZ 16 Posted September 2, 2014 Author Posted September 2, 2014 If there's a way to edit the image for a special feature on a movie through the web client, I am not able to find it. The images page only lets you edit images for the main movie itself.
Happy2Play 9798 Posted September 2, 2014 Posted September 2, 2014 Just figured this out. Tested in IE and Firefox, right click on the special feature and open in new tab or window, this will open the special feature and allow you edit it.
