TrackZ 16 Posted August 6, 2014 Posted August 6, 2014 I've been trying to figure this out for a while now (and posting various feedback points on it), but it finally occurred to me how to use an external ISO mounting program with MBT and have it route and start playback properly. The trick was not trying to specify PDVD as the player, but to specify VCD instead. I have external player configured as shown in the attached screen shot. Basically, set for video with ISO Support as "pass directly to player". The media player path is set to the full path to VCDMount.exe and just "{PATH}" as the command line argument. The other key trick though is to use Windows autoplay to configure Blu-ray and DVD titles to autoplay using PDVD. The end result is that playing out of MBT triggers the VCD mount which triggers Windows autoplay and PDVD loads and automatically plays the mounted image. This should work until/unless additional ISO support is added within the MB3 framework and MBT. It even works properly when triggering playback to MBT from the iOS apps and such.
