547555909 0 Posted January 29, 2021 Author Posted January 29, 2021 On 1/27/2021 at 11:10 PM, ebr said: Hi. I meant to press the button to send the log from the app again. However, first, let's be sure you changed the device name properly. I meant in the settings on the device itself, not in our server device list. Is that where you changed it? 2021-1-28 23:00 GMT+8:00,I'm sure i changed the device name,not the server name
ebr 16338 Posted January 29, 2021 Posted January 29, 2021 Hi. Exactly where did you change the device name? It needs to be done here: https://www.amazon.com/gp/help/customer/display.html?nodeId=201252640
547555909 0 Posted February 1, 2021 Author Posted February 1, 2021 On 1/30/2021 at 1:35 AM, ebr said: Hi. Exactly where did you change the device name? It needs to be done here: https://www.amazon.com/gp/help/customer/display.html?nodeId=201252640 my device name is DB,two words D and B
ebr 16338 Posted February 1, 2021 Posted February 1, 2021 13 hours ago, 547555909 said: my device name is DB,two words D and B Hi. In your last log, the device name was: Octaviode%202º%20Fire%20TV%20Stick That is encoded but basically shows some non-English characters. Again, this should be solved with the current beta and next release of the app but, for now, removing those characters would be the solution.
