bmflagg 21 Posted January 17, 2021 Posted January 17, 2021 Lastest Emby build. On QNAp TS-451+ Libraries are all built. Movie Library will not build Collections. I have set "Group items into collections", but the collection view isn't being created. Ideas anyone?
seanbuff 1356 Posted January 17, 2021 Posted January 17, 2021 Collections are 'built' either manually, or by using the Auto Box Sets plugin. Once you create some collections, you will see that view populated. 1
Happy2Play 9811 Posted January 17, 2021 Posted January 17, 2021 Note the plugin will become obsolete in 4.6+. But yes collections are currently only created by the plugin automatically from required metadata. Do you have TMDB enabled as a metadata provider? Does your media have the TMDBCollectionid? 1
Luke 42241 Posted January 18, 2021 Posted January 18, 2021 3 hours ago, bmflagg said: I have set "Group items into collections", but the collection view isn't being created. Hi, you have to have collections in your library in order for this to happen. Do you have any? Have you created any?
bmflagg 21 Posted January 18, 2021 Author Posted January 18, 2021 Hello.. Yes, there is TheMovieDb Id and a TheMovieDB Collection ID. I've set the movies to refresh metadata and also rescan library...
bmflagg 21 Posted January 18, 2021 Author Posted January 18, 2021 (edited) hmm. I couldn't sworn it did it automatically in the past..maybe auto box sets. Either way.. I seem to recall a setting from long ago that ..if more than two add to collection..(sic) but things are a bit fuzzy now. So going forward we must create collections manually? On my older windows 7 MCE / Emby setup..I had a lot of collections. maybe it was auto box sets... Edited January 18, 2021 by bmflagg
Luke 42241 Posted January 18, 2021 Posted January 18, 2021 Quote So going forward we must create collections manually? You either need manually created collections, or collections created by AutoBoxSets. https://support.emby.media/support/solutions/articles/44001162222-autoboxsets
bmflagg 21 Posted January 18, 2021 Author Posted January 18, 2021 thank you gentlemen.. manual it is. If I enable autobox sets now.. will 4.6x still see the prior 4.5x current collections list?
Luke 42241 Posted January 18, 2021 Posted January 18, 2021 7 minutes ago, bmflagg said: thank you gentlemen.. manual it is. If I enable autobox sets now.. will 4.6x still see the prior 4.5x current collections list? Yes.
