Woozie 1 Posted February 21, 2021 Author Posted February 21, 2021 yap, thats the way i did it...but no playback and the servers still shows the newest version on dlna.
Luke 42237 Posted February 21, 2021 Posted February 21, 2021 Then you must have restarted an additional time when you shouldn't have. Can you please try this again and then attach the emby server log with the playback attempt? Let's at least first verify that you're testing with the correct version of the plugin. Thanks.
Woozie 1 Posted February 21, 2021 Author Posted February 21, 2021 hope you find the problem... embyserver (2).txt
Luke 42237 Posted February 21, 2021 Posted February 21, 2021 So you've got 1.0.46 of the dlna plugin. As a test, can you use the plugin catalog to install version 1.0.44 of the dlna plugin? Then restart the server and try again. Just avoid restarting a second time because the server will update the plugin again to the latest. Then please attach the emby server log. Thanks.
Woozie 1 Posted February 21, 2021 Author Posted February 21, 2021 this is the log after installing 1.0.44 from the katalog and one restart. embyserver (3).txt
Luke 42237 Posted February 21, 2021 Posted February 21, 2021 Are you sure you installed it? What exactly did you do?
Luke 42237 Posted February 21, 2021 Posted February 21, 2021 You must have restarted twice. Can you please supply the previous log file? thanks.
Woozie 1 Posted February 21, 2021 Author Posted February 21, 2021 now i restartet the computer, choose dlna 1.0.44, emby writes i have to restart the server, so i do this one time. and the dlna version is still 1.0.46
Woozie 1 Posted February 21, 2021 Author Posted February 21, 2021 and my last try for today i uninstalled dlna, made a restart, i install 1.0.30...and die plugin says: 1.0.46...why...
Luke 42237 Posted February 22, 2021 Posted February 22, 2021 Ok thank you for trying. With the next beta server release please see how that goes and then attach an emby server log. Thanks.
Happy2Play 9811 Posted February 22, 2021 Posted February 22, 2021 (edited) @Lukeisn't server superseding installed? 2021-02-21 23:27:30.990 Info App: File C:\Users\Johannes\AppData\Roaming\Emby-Server\programdata\plugins\Emby.Dlna.dll has version 1.0.44.0 2021-02-21 23:27:31.355 Info App: File C:\Users\Johannes\AppData\Roaming\Emby-Server\system\plugins\Emby.Dlna.dll has version 1.0.46.0 2021-02-21 23:27:31.355 Info App: Copying plugin from C:\Users\Johannes\AppData\Roaming\Emby-Server\system\plugins\Emby.Dlna.dll to C:\Users\Johannes\AppData\Roaming\Emby-Server\programdata\plugins\Emby.Dlna.dll So in order to rollback to a previous version one would need to delete the plugin in System folder to prevent this. But may have compatibility issues do to changes within current server version. Edited February 22, 2021 by Happy2Play
Luke 42237 Posted February 22, 2021 Posted February 22, 2021 Yes you're right, sorry, that was my mistake. Anyway please try the beta server that just went up, and then attach the emby server log. This should be interesting. Thanks.
