Ronstang 294 Posted April 16, 2023 Posted April 16, 2023 On 4/14/2023 at 8:35 PM, Luke said: Hi, what do you mean? Default order for movies is MovieDb first. It's the first one listed on my server so from my similar experience it causes the problem of the actors being out of order based on relevance. I don't know if the box is checked by default but mine wasn't then a few months ago I don't remember why but I checked it when I made a new library and then I noticed that the actors were completely out of whack....with the main actors actually being last or near last. I couldn't understand why, then I remembered I checked the box for TVDb so I unchecked it and Voila! everything went back to the correct order again. So in my opinion a database for TV shows shouldn't even be an option for movies, especially when it's data is questionable for TV shows. 1
StuBailey 35 Posted May 25, 2025 Posted May 25, 2025 A lot of these posts are old so I'm only speaking about recent version since the drag and drop to sort the cast the way you want... The Director is listed first no matter, and I don't like it first, and a way to allow the director any position is to edit the director in the web editor (people) to be an actor, and you make the role DIRECTOR. Save and go edit the director to Guest Star. Save scan and it will still show as director but you can drag to any position.
Luke 42176 Posted May 25, 2025 Posted May 25, 2025 3 minutes ago, StuBailey said: A lot of these posts are old so I'm only speaking about recent version since the drag and drop to sort the cast the way you want... The Director is listed first no matter, and I don't like it first, and a way to allow the director any position is to edit the director in the web editor (people) to be an actor, and you make the role DIRECTOR. Save and go edit the director to Guest Star. Save scan and it will still show as director but you can drag to any position. Hi, can’t you just move the director to a lower position?
StuBailey 35 Posted May 25, 2025 Posted May 25, 2025 1 minute ago, Luke said: Hi, can’t you just move the director to a lower position? If there's a way I can't seem to figure it out. The only way I found was what I just mentioned.
StuBailey 35 Posted May 25, 2025 Posted May 25, 2025 Just now, StuBailey said: If there's a way I can't seem to figure it out. The only way I found was what I just mentioned. I couldn't even change the order by editing the NFO
Luke 42176 Posted May 25, 2025 Posted May 25, 2025 Did you try using the drag handles to reorder the list?
StuBailey 35 Posted May 25, 2025 Posted May 25, 2025 if you mean the = thing then yes. In fact it appears to work until you scan and then on display it's back on top.
Happy2Play 9798 Posted May 25, 2025 Posted May 25, 2025 4 minutes ago, StuBailey said: if you mean the = thing then yes. In fact it appears to work until you scan and then on display it's back on top. That would suggest Emby is not writing nfo file and once file is reread your order reverts.
StuBailey 35 Posted May 25, 2025 Posted May 25, 2025 3 minutes ago, Happy2Play said: That would suggest Emby is not writing nfo file and once file is reread your order reverts. I disagree, otherwise any person would do the same as the director.
StuBailey 35 Posted May 25, 2025 Posted May 25, 2025 1 minute ago, StuBailey said: I disagree, otherwise any person would do the same as the director. I even tested that by editing the nfo and moved director to the bottom but it still displays first or the top in the editor
Happy2Play 9798 Posted May 25, 2025 Posted May 25, 2025 Just now, StuBailey said: I even tested that by editing the nfo and moved director to the bottom but it still displays first or the top in the editor Can you provide a nfo. Is Emby writing your nfo files? As this was discussed in a TMM topic as their order of writing causes director first issue.
StuBailey 35 Posted May 25, 2025 Posted May 25, 2025 I could but before I forget I just tried adding a director where it already had none listed - and it was a different show and no problem.. Very strange..... Ok here is 2 NFO's - one has director edited as guest and the other is the original and I added ORG and the end of the file name. The Twilight Zone (1959) - S02E18 - The Odyssey of Flight 33 (1080p BluRay x265 ImE).nfo The Twilight Zone (1959) - S02E18 - The Odyssey of Flight 33 (1080p BluRay x265 ImE)---ORG.nfo
Happy2Play 9798 Posted May 25, 2025 Posted May 25, 2025 (edited) 7 minutes ago, StuBailey said: I could but before I forget I just tried adding a director where it already had none listed - and it was a different show and no problem.. Very strange..... Ok here is 2 NFO's - one has director edited as guest and the other is the original and I added ORG and the end of the file name. The Twilight Zone (1959) - S02E18 - The Odyssey of Flight 33 (1080p BluRay x265 ImE).nfo 3.27 kB · 0 downloads The Twilight Zone (1959) - S02E18 - The Odyssey of Flight 33 (1080p BluRay x265 ImE)---ORG.nfo 3.27 kB · 0 downloads You will have issues here as the already imported info in DB cannot be updated to any other order. <lockdata>true</lockdata> <lockedfields>Cast</lockedfields> Pretty sure it will primarily be lockdata. Edited May 25, 2025 by Happy2Play
StuBailey 35 Posted May 25, 2025 Posted May 25, 2025 it's locked but it let's you sort the people order and I already said everyone but the directors could be re-arranged. and her's a better original NFO The Twilight Zone (1959) - S02E18 - The Odyssey of Flight 33 (1080p BluRay x265 ImE).nfo
Happy2Play 9798 Posted May 25, 2025 Posted May 25, 2025 16 minutes ago, StuBailey said: it's locked but it let's you sort the people order and I already said everyone but the directors could be re-arranged. and her's a better original NFO The Twilight Zone (1959) - S02E18 - The Odyssey of Flight 33 (1080p BluRay x265 ImE).nfo 2.92 kB · 1 download What server version are you on as I just remembered this Director first is a change in 4.9. As refreshing all old media changes the previous order.
StuBailey 35 Posted May 26, 2025 Posted May 26, 2025 3 hours ago, Happy2Play said: What server version are you on as I just remembered this Director first is a change in 4.9. As refreshing all old media changes the previous order. 4.8.11 ..and I was thinking similar about difference in nfo... also think might have had same file in 2 places and testing that now.
Luke 42176 Posted June 11, 2025 Posted June 11, 2025 The upcoming 4.9 server release has improved support for modifying the actor order. Thanks.
StuBailey 35 Posted October 5, 2025 Posted October 5, 2025 On 6/10/2025 at 11:17 PM, Luke said: The upcoming 4.9 server release has improved support for modifying the actor order. Thanks. I just added 4.9 and now tags seem to be automatically in alphabetical order no matter how I drag and drop.
Luke 42176 Posted October 5, 2025 Posted October 5, 2025 7 hours ago, StuBailey said: I just added 4.9 and now tags seem to be automatically in alphabetical order no matter how I drag and drop. There shouldn't be any drag and drop anymore. What Emby app are you seeing that in?
StuBailey 35 Posted October 5, 2025 Posted October 5, 2025 6 minutes ago, Luke said: There shouldn't be any drag and drop anymore. What Emby app are you seeing that in? I just upped to 4.9.1 server and I see it on the web and current roku app. I haven't touched emby for close to a month and shocked. Actually I meant I used the right click and move up and down which appears to work but when you scan it's in alphabetical order. If there's no way to put it in order I then I do have a solution I'm working on, but manual sort if far easier.
StuBailey 35 Posted October 5, 2025 Posted October 5, 2025 Drag and drop, or even the move up or down was perfect
Luke 42176 Posted October 5, 2025 Posted October 5, 2025 Quote current roku app. ?? The Roku app does not have metadata editing.
Luke 42176 Posted October 5, 2025 Posted October 5, 2025 1 minute ago, StuBailey said: well you asked which app I'm seeing it in And you're seeing tag drag handles in Emby for Roku?
