andrex991 1 Posted January 16, 2021 Posted January 16, 2021 I have a Samsung QLED 49" and I am trying to connect to my iMac27 which has two connected disks, Movies and TV shows. I have downloaded the Samsung Emby app, but when it asked me for a password I said I'd forgotten and it directed me to the emby-server to read a reset text file. Where is the Emby server? Any help would be appreciated. I might just add that I can access my computer from my TV and get to the movie and TV files that way, but it is a method of access that seems primitive, going through levels of folders. I would prefer to go via the correct TV Emby app.
Solution Luke 42240 Posted January 20, 2021 Solution Posted January 20, 2021 Hi @andrex991 have you setup your own Emby Server? That's something you would do first before trying to use the Samsung app. I would suggest checking out our quick start guide: https://support.emby.media/support/solutions/articles/44001159034-quick-start Please let us know if this helps. Thanks !
andrex991 1 Posted January 20, 2021 Author Posted January 20, 2021 Hi @Luke ... thanks for the reply. I have now linked in from my Samsung TV
