tp546 41 Posted January 16, 2021 Posted January 16, 2021 Hello, I have a Sports library where the folder structure is different from the conventional one and I am having trouble getting it to display properly in Emby. Attached is an example of how things are laid out - currently some of the season folders show up in my library but I can't view or play anything inside them. I put season.xml files in each folder but that doesn't seem to help. Please let me know how I can get this functioning properly. Thanks!
Solution Luke 42204 Posted January 18, 2021 Solution Posted January 18, 2021 Hi, you may want to set this up as the home videos content type. if it's not following our TV naming guide: https://support.emby.media/support/solutions/articles/44001159110-tv-naming Then I would not suggest using the TV content type.
tp546 41 Posted January 18, 2021 Author Posted January 18, 2021 52 minutes ago, Luke said: Hi, you may want to set this up as the home videos content type. if it's not following our TV naming guide: https://support.emby.media/support/solutions/articles/44001159110-tv-naming Then I would not suggest using the TV content type. Thanks for the advice. I removed the library folder and added it as home videos and I can see my Season folders now, but nothing appears inside any of them. Are there additional steps I can take here?
tp546 41 Posted January 18, 2021 Author Posted January 18, 2021 Actually it looks like I spoke too soon - they seem to be working now! 1
