tqbhuy 0 Posted January 16, 2021 Posted January 16, 2021 Hi, I'm running the latest official Emby on an OMV NAS. Generally my UHD mkvs work totally fine with Direct play, but I have two movies were my Nvidia ShieldTv (2017) just endlessly loads at start. Both are direct copies from disc: Back to the Future 4K The Neon Demon 4K After a lot of testing I kinda found out: I rename audio and subtitle tracks in the mkv header for better identification. Usually no problem even with really long texts for commentaries etc. Somehow Back to the Future has issues with the length? See the attached picture. The last name is already too long. Remove the 'n' and the video suddenly plays fine. Curiously BttF Part III has the same problem but can go one letter further. Neon Demon similar case. Difference is, I also have an HD version with the same track layout as the 4K file but HD plays fine. 4K only when I edit the track name. Is there something I missed like mkv specifications? Like I said, every other mkv I have works fine. Kind regards, embyserver (4).txt
ebr 16338 Posted January 16, 2021 Posted January 16, 2021 Hi. Please try and play one of these that has the problem for just a few seconds and then immediately send a log from the app. Thanks.
tqbhuy 0 Posted January 16, 2021 Author Posted January 16, 2021 Done, about two minutes ago. User is 'huy'. Kind regards,
ebr 16338 Posted January 17, 2021 Posted January 17, 2021 Interesting. There were no errors the item was just still loading when you backed out. How long have you waited for it to start?
tqbhuy 0 Posted January 17, 2021 Author Posted January 17, 2021 15 to 20 seconds. Usually it takes 2 seconds max.
Solution Luke 42246 Posted January 17, 2021 Solution Posted January 17, 2021 Quote Remove the 'n' and the video suddenly plays fine What tool are you doing it with? It could also just be the act of rewriting the file that fixes it, not specifically the track length.
tqbhuy 0 Posted January 17, 2021 Author Posted January 17, 2021 23 minutes ago, Luke said: What tool are you doing it with? It could also just be the act of rewriting the file that fixes it, not specifically the track length. I'm using MKVToolNix and then the Header Editor.
Luke 42246 Posted January 18, 2021 Posted January 18, 2021 Have you tried just saving one of these mkv's as a new mkv without changing anything?
tqbhuy 0 Posted January 20, 2021 Author Posted January 20, 2021 On 1/18/2021 at 4:37 AM, Luke said: Have you tried just saving one of these mkv's as a new mkv without changing anything? I just remuxed the movie into a new file and it seems to work now. I remembered I had the same problem with re-encodes from Handbrake. I then remuxed those files too, but also removed the global tags handbrake adds, but the remux might have been enough to fix that. Since my 4K mkvs didn't have those tags, I didn't really thought of completely remuxing it.
Luke 42246 Posted January 21, 2021 Posted January 21, 2021 Thanks for the info. If you created the original file with an older version of mkvtoolnix or handbrake it's possible it had a defect in the way it muxed the file, thus causing the problem.
