Carlo 4561 Posted February 21, 2021 Posted February 21, 2021 @ebr I don't have any apple products to test. Would you be able to try connecting to his server with Apple TV?
vdatanet 1619 Posted February 21, 2021 Posted February 21, 2021 2 hours ago, peanutbutter509 said: unfortunately it still doesn't work. Did you check your Apple TV host name?
peanutbutter509 0 Posted February 21, 2021 Author Posted February 21, 2021 @vdatanet Hello, How can I verify my hostname? What should I look for more specifically? Thank you
vdatanet 1619 Posted February 21, 2021 Posted February 21, 2021 7 minutes ago, peanutbutter509 said: @vdatanet Hello, How can I verify my hostname? What should I look for more specifically? Thank you https://www.cnet.com/how-to/how-to-rename-your-apple-tv/ Apple TV should not contain non ASCII chars
peanutbutter509 0 Posted February 22, 2021 Author Posted February 22, 2021 Unfortunately, still no result. I think it's the seedbox that's causing the problem. Because when I do a local installation with a Home NAS server it works very well. Do you think it's possible to make a seedbox appear on a local server to make a final attempt? Or conversely, for example ask emby to fetch the files on a non-local server (ultraseedbox)?
Carlo 4561 Posted February 22, 2021 Posted February 22, 2021 What do you mean to get a seedbox to appear on a local server?
peanutbutter509 0 Posted February 22, 2021 Author Posted February 22, 2021 Make my seedbox appear on my mac as if it was a local NAS.
peanutbutter509 0 Posted February 23, 2021 Author Posted February 23, 2021 Thanks a lot anyway guys. But I think my situation is desperate and there is no solution for my problem. I will go through plex for my seedbox and emby for my test NAS. That way one will be managed on my Mac and the other one will be managed via the seedbox. Once again a big thank you to the whole team you are at the top.
