13782022 0 Posted January 12, 2021 Posted January 12, 2021 The device I use is Android 9.0 and the CPU is S922X. At present, this device cannot enter the emby homepage normally, and will return to the desktop after a period of time. The device model is Dangbei DBB3PRO. I hope the official can help me solve this problem.thanks!
Solution ebr 16338 Posted January 12, 2021 Solution Posted January 12, 2021 Hi. Does this device have a true Android TV launcher? If not, this may be solved by the current beta of the app.
13782022 0 Posted January 13, 2021 Author Posted January 13, 2021 12 hours ago, ebr said: 你好 此设备是否具有真正的Android TV启动器? 如果不是,则可以通过该应用程序的当前Beta解决。 Yes, it is not a tv version, I will use beta for testing, thank you for your help!
