gthrift 66 Posted November 7, 2013 Posted November 7, 2013 He has to use the RAID controller for the port splitting, or whatever it's called. I did see in a google search that there is BIOS for the raid card just for JBOD if you are not going to use RAID. There was a discussion on the flexraid forum about it.
Airbender 128 Posted November 7, 2013 Author Posted November 7, 2013 johnchimpo and gthrift You both are correct i am going to use FilexRaid with Raid F Combo in the future but right now it is JOBD with NO Raid on windows 7 64 bit Thanks
ddiehl 2 Posted November 8, 2013 Posted November 8, 2013 (edited) wrong thread.. sorry.. Edited November 8, 2013 by ddiehl
johnchimpo 7 Posted November 8, 2013 Posted November 8, 2013 johnchimpo and gthrift You both are correct i am going to use FilexRaid with Raid F Combo in the future but right now it is JOBD with NO Raid on windows 7 64 bit Thanks Is it working now? Did you try removing all but one drive and writing that way. Need to determine if its a problem with your desktop I/O, enclosure card, or eSata connection.
Airbender 128 Posted November 8, 2013 Author Posted November 8, 2013 Is it working now? Did you try removing all but one drive and writing that way. Need to determine if its a problem with your desktop I/O, enclosure card, or eSata connection. Hi did not try anything as i left to work so mybe tonight i will have to test it + i open a case with san digital as if i cant fix this on time i will have to send the unit back and get full refund
Airbender 128 Posted November 9, 2013 Author Posted November 9, 2013 Hello Not getting anywhere with my sans digitl unit so i seriously thinking to return it and get my money back does anyone recommand a diffrent brand to look into ? i have until thursday to returen it back for full refund Thanks
Airbender 128 Posted November 10, 2013 Author Posted November 10, 2013 Hello i think i know where the problem could be it is either the Controller card driver or controller card by it self. This unit used eSATA 6Gbps (via Port Multiplier) my motherboard comes with 2 e-sata but JOBD or slicon image is not Port Multiplier for all 8 drives to be seen at once. in this case i either have to return the item and get my money back or buy JOBD eSata Card that support 6GBPS and Port Multiplier on windows 7 Enterprise or ultimate X64 bit. So i guess back to original issue again
Airbender 128 Posted November 12, 2013 Author Posted November 12, 2013 Hello i found a card replacement http://www.newegg.co... UGT-ST622 card so hoping this will fix my issue with speed issue and as far parity drive i got a new 4TB drive also so let see what happens after i get parts back Thanks
Airbender 128 Posted November 15, 2013 Author Posted November 15, 2013 Hello Vantec card did not work with my unit which is 8 Hard drives , spoke to support and they said Max drives are 4 so i had to RMA it and get my money back from newegg and now in market again looking for a card againSan Digital guys said they can do a card swap from what i have RR622 Dual-Port eSATA 6Gb/s PCIe 2.0 x1 RAID Controller to Roket Raid 642 just to see if it fix the issue with Speed problemalso they said something about there cards support FIS and not CBS so mybe i need to find a port multiplier with FIS and Support for 8 Hard drives at Sata 6 Gbps on e-Sataback to step one againThanks
Airbender 128 Posted November 15, 2013 Author Posted November 15, 2013 Hello I guess we all need to keep an eyes on CBS VS FIS and Port Mulitpiler for Storge systems
Airbender 128 Posted November 15, 2013 Author Posted November 15, 2013 Hello For better discriptions so others can know also before they run into an issue like me Supports Port Multiplier FIS Based Switching or Command Based Switching
Airbender 128 Posted November 30, 2013 Author Posted November 30, 2013 Hello issue resolved got RR642L Card and everything is working now
