sross44 434 Posted January 11, 2021 Posted January 11, 2021 (edited) I just installed a secondary Emby server on a new Shield Pro. Just wanted to test it out and see how handles things like Live TV. Got everything up and running and when I click on the Emby App on the Shield it works perfectly. However on any other client, it won't connect. I'm at a loss... I've changed the ports to make sure there's no conflict with the other server, I've logged out and logged back in, still nothing. Any advice as to what I could be missing would be great. It just says the server isn't available. Edited January 11, 2021 by sross44
sross44 434 Posted January 11, 2021 Author Posted January 11, 2021 Update - it works if I manually enter the server IP address. It just wasn't working with Emby Connect for some reason? Still any thoughts would be welcomed as to why it wasn't working with Emby Connect. Thanks in advance.
ebr 16332 Posted January 11, 2021 Posted January 11, 2021 Hi. We'd need to look at specifics but I would be sure that the IP addresses shown on the dashboard are correct.
