raven-au 17 Posted January 10, 2021 Posted January 10, 2021 Hi all, I'm trying to play an HDR movie in an mp4 container and I'm getting no audio on playback. The mediainfo output for the movie is: General Complete name : M:\1\Movies\Sonic The HedgeHog (2020)\Sonic the Hedgehog (2020) - 4K-HDR-DV.mp4 Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 (mp42/isom/dby1) File size : 10.00 GiB Duration : 1 h 38 min Overall bit rate mode : Variable Overall bit rate : 14.5 Mb/s Movie name : Sonic the Hedgehog Performer : Jeff Fowler Performer/Sorted by : Jeff Fowler Genre : Action & Science Fiction & Comedy & Family Description : Based on the global blockbuster videogame franchise from Sega, Sonic the Hedgehog tells the story of the world’s speediest hedgehog as he embraces his new home on Earth. In this live-action adventure comedy, Sonic and his new best friend team up to defend the planet from the evil genius Dr. Robotnik and his plans for world domination. Recorded date : 2020 Encoded date : UTC 2021-01-08 10:03:00 Tagged date : UTC 2021-01-08 10:30:22 Writing application : DVDFab 12.0.1.5 Cover : Yes Title/Sort : Sonic the Hedgehog LongDescription : Based on the global blockbuster videogame franchise from Sega, Sonic the Hedgehog tells the story of the world’s speediest hedgehog as he embraces his new home on Earth. In this live-action adventure comedy, Sonic and his new best friend team up to defend the planet from the evil genius Dr. Robotnik and his plans for world domination. Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU / SMPTE ST 2086, HDR10 compatible Codec ID : dvhe Codec ID/Info : High Efficiency Video Coding with Dolby Vision Duration : 1 h 38 min Bit rate : 10.0 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.050 Stream size : 6.91 GiB (69%) Encoded date : UTC 2021-01-08 10:03:00 Tagged date : UTC 2021-01-08 10:28:43 Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2 Maximum Content Light Level : 698 cd/m2 Maximum Frame-Average Light Level : 204 cd/m2 Menus : 3 Codec configuration box : hvcC+dvcC Audio ID : 2 Format : MLP FBA 16-ch Format/Info : Meridian Lossless Packing FBA with 16-channel presentation Commercial name : Dolby TrueHD with Dolby Atmos Codec ID : mlpa Duration : 1 h 38 min Source duration : 1 h 38 min Bit rate mode : Variable Bit rate : 4 434 kb/s Maximum bit rate : 7 872 kb/s Channel(s) : 8 channels Channel layout : L R C LFE Ls Rs Lb Rb Sampling rate : 48.0 kHz Frame rate : 1 200.000 FPS (40 SPF) Compression mode : Lossless Stream size : 3.06 GiB (31%) Source stream size : 3.06 GiB (31%) Title : English (truehd 7.1) Language : English Default : Yes Alternate group : 1 Encoded date : UTC 2021-01-08 10:03:00 Tagged date : UTC 2021-01-08 10:28:43 Number of dynamic objects : 11 Bed channel count : 1 channel Bed channel configuration : LFE Menu ID : 3 Codec ID : text Duration : 1 h 38 min Encoded date : UTC 2021-01-08 10:03:00 Tagged date : UTC 2021-01-08 10:29:26 Menu For : 1 00:00:00.000 : Chapter 1 00:03:51.898 : Chapter 2 00:09:32.989 : Chapter 3 00:12:46.015 : Chapter 4 00:18:09.463 : Chapter 5 00:22:20.380 : Chapter 6 00:27:33.693 : Chapter 7 00:35:09.357 : Chapter 8 00:41:37.328 : Chapter 9 00:51:24.664 : Chapter 10 01:01:04.827 : Chapter 11 01:04:38.249 : Chapter 12 01:10:20.340 : Chapter 13 01:18:54.062 : Chapter 14 01:25:38.758 : Chapter 15 01:30:27.338 : Chapter 16 Server log during playback is attached.
raven-au 17 Posted January 10, 2021 Author Posted January 10, 2021 Server log should have been attached ... embyserver.txt
raven-au 17 Posted January 10, 2021 Author Posted January 10, 2021 (edited) Some more information ... The log shows the playback client is a Shield TV but not the model, it's a Shield TV 2019 tube but I have seen the same symptoms on a 2017 Shield TV. The Shield is connected to a Denon AVR-X1400H which is connected to a Sony KD-X8500F, HDR capable TV. When the same movie is in an mkv container playback works fine. When played my receiver phone app shows it's receiving unknown audio, not PCM or anything else. The server version, platform and Andriod TV client version is included in the log and in the log it appears Emby Server thinks it's direct playing. That's about all I say, if more info is needed please ask. Edited January 10, 2021 by raven-au
ebr 16338 Posted January 10, 2021 Posted January 10, 2021 Hi. Please play the item for just a few seconds and then send a log from the app. Thanks.
raven-au 17 Posted January 11, 2021 Author Posted January 11, 2021 11 hours ago, ebr said: Hi. Please play the item for just a few seconds and then send a log from the app. Thanks. I think I have sent a log from the app. The time was 8:51pm US Eastern time and the Emby user was Poppy. The tittle I played was the same title I talked about above, "Sonic the Hedgehog". Hope that's what you need, .
ebr 16338 Posted January 11, 2021 Posted January 11, 2021 The player cannot see the audio track at all. It appears that support for TrueHD in mp4 containers is pretty sketchy and Exo must not support it at this point.
jrwalte 17 Posted January 11, 2021 Posted January 11, 2021 (edited) I'd use MKVtoolnix and change it to MKV. Quick and simple. No converting and everything will stay original. Edited January 11, 2021 by jrwalte 1
raven-au 17 Posted January 11, 2021 Author Posted January 11, 2021 5 hours ago, jrwalte said: I'd use MKVtoolnix and change it to MKV. Quick and simple. No converting and everything will stay original. It is a lot more work to convert the Dolby Vision encodes I get from DVDFab from mp4 to mkv, without loosing the Dolby Vision bit. And I kinda like the mp4 that's produced by the encode.
ebr 16338 Posted January 11, 2021 Posted January 11, 2021 2 minutes ago, raven-au said: It is a lot more work to convert the Dolby Vision encodes I get from DVDFab from mp4 to mkv, without loosing the Dolby Vision bit. You could also choose a more compatible audio format (DD or DD+) as another option.
raven-au 17 Posted January 11, 2021 Author Posted January 11, 2021 9 hours ago, ebr said: The player cannot see the audio track at all. It appears that support for TrueHD in mp4 containers is pretty sketchy and Exo must not support it at this point. That's strange, Emby ffmpeg looks like it understands it: Quote [/share/media/1/Movies/Sonic The HedgeHog (2020)] # /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/emby-ffmpeg -i Sonic\ the\ Hedgehog\ \(2020\)\ -\ 4K-HDR-DV.mp4 ffmpeg version 4.3.0-emby_2020_05_23 Copyright (c) 2000-2019 the FFmpeg developers and softworkz for Emby LLC built with gcc 8.3.0 (crosstool-NG 1.24.0) Execution Date: 2021-01-12 07:05:51 [mov,mp4,m4a,3gp,3g2,mj2 @ 0x1541080] stream 0, timescale not set [hevc @ 0x1542a40] Skipping NAL unit 62 Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Sonic the Hedgehog (2020) - 4K-HDR-DV.mp4': Metadata: major_brand : mp42 minor_version : 0 compatible_brands: mp42isomdby1 creation_time : 2021-01-08T10:03:00.000000Z title : Sonic the Hedgehog artist : Jeff Fowler album : comment : genre : Action & Science Fiction & Comedy & Family date : 2020 sort_name : Sonic the Hedgehog sort_artist : Jeff Fowler description : Based on the global blockbuster videogame franchise from Sega, Sonic the Hedgehog tells the story of the world’s speediest hedgehog as he embraces his new home on Earth. In this live-action adventure comedy, Sonic and his new best friend team up to defe synopsis : Based on the global blockbuster videogame franchise from Sega, Sonic the Hedgehog tells the story of the world’s speediest hedgehog as he embraces his new home on Earth. In this live-action adventure comedy, Sonic and his new best friend team up to defe encoder : DVDFab 12.0.1.5 Duration: 01:38:52.89, start: 0.000000, bitrate: 14477 kb/s Stream #0:0(und): Video: hevc (Main 10) (dvhe / 0x65687664), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160 [SAR 1:1 DAR 16:9], 10005 kb/s, Level 153, 23.98 fps, 23.98 tbr, 24k tbn, 23.98 tbc (default) Metadata: creation_time : 2021-01-08T10:03:00.000000Z encoder : DOVI Coding Stream #0:1(eng): Audio: truehd (mlpa / 0x61706C6D), 48000 Hz, 7.1, s32 (24 bit), 4433 kb/s (default) Metadata: creation_time : 2021-01-08T10:03:00.000000Z Stream #0:2(und): Data: bin_data (text / 0x74786574) Metadata: creation_time : 2021-01-08T10:03:00.000000Z Stream #0:3: Video: mjpeg (Progressive), yuvj420p(pc, bt470bg/unknown/unknown), 500x750 [SAR 1:1 DAR 2:3], 90k tbr, 90k tbn, 90k tbc (attached pic) At least one output file must be specified Stream 0:3 is probably the chapters, that doesn't look too good. And I guess the problem is the client not knowing how to identify it though ...
ebr 16338 Posted January 11, 2021 Posted January 11, 2021 If you Google TrueHD in mp4 you will find a lot of discussion about the lack of support for that audio in that container. I'm not sure if we can extend Exo to support it right now so the app will have to be updated to transcode those - but that is going to lose both the lossless track and your DV.
raven-au 17 Posted January 11, 2021 Author Posted January 11, 2021 9 minutes ago, ebr said: You could also choose a more compatible audio format (DD or DD+) as another option. LOL, kinda defeats the purpose of HDR and DV when your play back device and audio gear understands it and, of course, the Atmos effects are lost.
ebr 16338 Posted January 11, 2021 Posted January 11, 2021 3 minutes ago, raven-au said: LOL, kinda defeats the purpose of HDR and DV when your play back device and audio gear understands it and, of course, the Atmos effects are lost. Then using mkv will probably be your best near-term solution.
raven-au 17 Posted January 11, 2021 Author Posted January 11, 2021 1 minute ago, ebr said: If you Google TrueHD in mp4 you will find a lot of discussion about the lack of support for that audio in that container. I'm not sure if we can extend Exo to support it right now so the app will have to be updated to transcode those - but that is going to lose both the lossless track and your DV. Yes, it is fairly new, and those same limitations are largely the reason it's so much effort to convert them to mkv. But it must be happening since tools are slowly being updated to understand it.
raven-au 17 Posted January 11, 2021 Author Posted January 11, 2021 Just now, ebr said: Then using mkv will probably be your best near-term solution. Yes, it's not the end of the world, I'll need to continue converting them to mkv for now. Please keep an eye out so this can be done some time in the future.
Luke 42246 Posted January 16, 2021 Posted January 16, 2021 Yea I don't think I had ever seen truehd in mp4 until you mentioned it here.
sammy2 2 Posted January 27, 2021 Posted January 27, 2021 MKV is the preferred container for movies. It would be simple to change containers from MP4 to MKV using XMedia Recode. You can set it to copy both video and audio. Or use Mkvtoolnix-Gui. Both are free.
raven-au 17 Posted January 28, 2021 Author Posted January 28, 2021 4 hours ago, sammy2 said: MKV is the preferred container for movies. It would be simple to change containers from MP4 to MKV using XMedia Recode. You can set it to copy both video and audio. Or use Mkvtoolnix-Gui. Both are free. Yes, I am aware of my options. Keep in mind that it's not just any old movie I would need to convert, the ones that are more complicated to convert are the Dolby Vision encoded ones. I want to encode them to reduce size to something more sensible and I can only do that with an output of an mp4. Then I need to be careful that the apps I use to further transform these don't loose the Dolby Vision from the video track. At the moment, for me, after the encode that means extract the original video, use tsmuxer to create an iso from the encoded video, use MakeMKV to create an mkv from the iso, use mkvtoolnix to mux the bits together, basically replacing the Dolby Vision track with the enocded one. If you have any suggestions on how I can make this simple then please share. It's this that prompted the question in the first place since mkv is pretty much what I use for everything normally.
rbjtech 5345 Posted January 28, 2021 Posted January 28, 2021 There is plenty of info on makemkv's forums on how to do this. Personally I don't get why you would ever want to do this - you want to keep DV and HD Audio - but sacrifice bitrate to save space ... err.. ok. If you have the equipment to play DV and HD Audio - then add an 8Tb HDD to the list .. just saying.
raven-au 17 Posted January 28, 2021 Author Posted January 28, 2021 1 hour ago, rbjtech said: There is plenty of info on makemkv's forums on how to do this. Personally I don't get why you would ever want to do this - you want to keep DV and HD Audio - but sacrifice bitrate to save space ... err.. ok. If you have the equipment to play DV and HD Audio - then add an 8Tb HDD to the list .. just saying. No, I want to encode to a high enough quality the difference is not noticeable. Historically that meant a significant reduction in movie size but with UHD material that's not always the case. But there is still a reduction, most noticable for newer material that, for whatever reason, is better quality than others. Some may have been just upscaled by the movie companies and sold as UHD when it's really not up to that quality, I don't know I just see differences. As far a adding disks to my NAS, it's fully populated, and to repopulate it with larger disks would cost at least $1200 AUD. And, storage is not the only issue, as the size of movies grows so does the overhead of moving them around and re-encoding them for whatever reason I may have. That infrastructure also costs quite a bit. So it's not as simple you say as far as I am concerned and, for me, it's what I want for myself that counts. And, I'm not complaining that Emby isn't in a position to do this now or even in the near future, I understand the way things are and I'm happy that the developers were kind enough to listen and respond.
