cochize1 55 Posted January 9, 2021 Posted January 9, 2021 I have a nice looking sunction of enlarging posters on hover: /* ----- Poster enlarge on hover ----*/ div.cardBox{transition:all 0.2s;} div.cardBox:hover {transform:scale(1.045);transition:all 0.2s;} but how can I exclude that function from the main poster in .detailImageContainerCard, I tried this but doesn;t seem to work: /* ----- Poster enlarge on hover ----*/ div.cardBox:not(.detailImageContainerCard) {transition:all 0.2s;} div.cardBox:hover:not(.detailImageContainerCard) {transform:scale(1.045);transition:all 0.2s;}
Happy2Play 9811 Posted January 10, 2021 Posted January 10, 2021 Use something like this div.card:hover:not(.detailImageContainerCard) or div.card:not(.detailImageContainerCard):hover
cochize1 55 Posted January 10, 2021 Author Posted January 10, 2021 ok, thanks this did the trick: /* ----- Poster enlarge on hover ----*/ div.card:not(.detailImageContainerCard):hover {transform:scale(1.025);transition:all 0.2s;} but now can't get rid of the dim effect in the same place and this won't do it, any ideas? /* dim posters */ div.cardBox:not(.detailImageContainerCard){opacity: .75;} div.cardBox:hover{opacity: 1;}
Solution Happy2Play 9811 Posted January 10, 2021 Solution Posted January 10, 2021 48 minutes ago, cochize1 said: ok, thanks this did the trick: /* ----- Poster enlarge on hover ----*/ div.card:not(.detailImageContainerCard):hover {transform:scale(1.025);transition:all 0.2s;} but now can't get rid of the dim effect in the same place and this won't do it, any ideas? /* dim posters */ div.cardBox:not(.detailImageContainerCard){opacity: .75;} div.cardBox:hover{opacity: 1;} Doesn't changing .cardBox to .card accomplish what you want? 1
cochize1 55 Posted January 10, 2021 Author Posted January 10, 2021 Unfirtunatelly it doesn't. I checked couple of options before posting.
cochize1 55 Posted January 10, 2021 Author Posted January 10, 2021 well, seems I haven't tried all the options and you were right, like usual, this works for me: /* dim posters */ div.card:not(.detailImageContainerCard){ opacity: .75;} div.card:hover{ opacity: 1;}
