Aminology 0 Posted January 9, 2021 Posted January 9, 2021 Hi Luke, Hi everyone. Apologies if this issue was covered somewhere else and I mistakingly overlooked it. Here is my situation : I started using Emby server on my DS220j about 2 weeks ago, it wasn't hard to configure it at the beginning but then I noticed that the interface couldn't connect to internet at all (except for subtitles). So I figured I'd just update my metadata the manual (and the tedious) way. So a few days ago the connection started glitching, going on and offline, and when it's successful it's always with a very lagging connection speed, which wasn't the case before this month of January. Yesterday I attempted to solve the problem by updating to the BETA version, which had it work for about few minutes before it stopped reacting and opening altogether. I'm using a Macbook with a Chrome based browser, with my synology running DSM 7.0. To sum up, here are my problems : 1- External access doesn't work, and apparently I can't configure an Emby Connect. 2- I can't use the metadata downloader (identify function) and I also can't access the plugin store. 3- As of yesterday, I lost access to the Emby server altogether. I attached my logs hopefully you can help me locate where the problem is. embyserver.txt
Aminology 0 Posted January 13, 2021 Author Posted January 13, 2021 Please can anyone get back to me on this? Meanwhile I reinstalled the service and still no access ...
Happy2Play 9812 Posted January 13, 2021 Posted January 13, 2021 There is still testing going on with all the DSM-7 issues. Are you following this topic? Synology DSM 7 Testing - Emby Server - Emby Community
