Legolas12 1 Posted January 9, 2021 Posted January 9, 2021 Buenas tardes dónde consigo el código pin para poder sincronizar mi servidor emby con mi tv Samsung gracias
FrostByte 5453 Posted January 9, 2021 Posted January 9, 2021 you get the PIN from the install process on your TV. You enter the PIN at the link below Enter Pin Code - Emby
Solution Legolas12 1 Posted January 9, 2021 Author Solution Posted January 9, 2021 Muchas gracias 1 hour ago, FrostByte said: obtiene el PIN del proceso de instalación en su televisor. Ingresa el PIN en el enlace de abajo Ingrese el código PIN - Emby 1
Luke 42239 Posted January 10, 2021 Posted January 10, 2021 Hi, didn't you see the instructions on your TV? It tells you this right on the screen.
leiton11 0 Posted September 9, 2024 Posted September 9, 2024 Hola me puedes ayudar a crear mi usuario y contraseña emby lo he intentado hacer por mucho tiempo y no puedo
Neminem 1620 Posted September 9, 2024 Posted September 9, 2024 @leiton11 Do you know if you are connecting to the server you installed ? or are you using someone else's server ? Emby does not supply media files. Quick Start
Neminem 1620 Posted September 9, 2024 Posted September 9, 2024 33 minutes ago, JayceDK said: Do you know if you are connecting to the server you installed ? or are you using someone else's server ? Emby does not supply media files. Quick Start Read the link.
Luke 42239 Posted June 23, 2025 Posted June 23, 2025 On 6/21/2025 at 5:56 PM, kapada said: hola no puedo instalar emby en mi tv Hi there, what exactly happens when you try?
rama1229 0 Posted September 2, 2025 Posted September 2, 2025 Hola cómo puedo ver conectarme a un servidor en emby
Luke 42239 Posted September 2, 2025 Posted September 2, 2025 31 minutes ago, rama1229 said: Hola cómo puedo ver conectarme a un servidor en emby 31 minutes ago, rama1229 said: Hola cómo puedo ver conectarme a un servidor en emby Hi, please check out our quick stay guide: Quick Start
Luke 42239 Posted November 11, 2025 Posted November 11, 2025 24 minutes ago, Droide23 said: Que servidor pongo para emby? Hi, please check out our quick start guide: Quick Start
