jtimmyf 1 Posted January 8, 2021 Posted January 8, 2021 Hello I need help. I know very little about ssl certificates and I think I need one for https streaming of emby movies. I am on a mac computer. Have been using plex and the setup has gone fine except for the ssl certs. I have tried to follow the instructions but it isn't working. Reg http connections are working fine. Please help Tim F.
Luke 42239 Posted January 9, 2021 Posted January 9, 2021 Quote I have tried to follow the instructions but it isn't working Hi there, what exactly did you try?
jtimmyf 1 Posted January 9, 2021 Author Posted January 9, 2021 I have tried to install a ssl certificate, not sure if it is installed properly? I think not. I have also forwarded port 8920 but it does not appear to be open. I am familiar with port forwarding and use it for many devices that I have so maybe the port isn't showing open because of something on the mac server. Again ssl certificates I am NOT familiar using, though I do have them installed on my synology nas and working, but that is an easy task as synology does most of the work. I probably really need to find someone to do this for me and pay them, which I am willing to do. Plex is soooo much easier. 1
thePaintGuy 0 Posted July 11, 2021 Posted July 11, 2021 I have the same problem, cant get my certificate part to work
thePaintGuy 0 Posted July 11, 2021 Posted July 11, 2021 On 1/9/2021 at 6:16 AM, jtimmyf said: I have tried to install a ssl certificate, not sure if it is installed properly? I think not. I have also forwarded port 8920 but it does not appear to be open. I am familiar with port forwarding and use it for many devices that I have so maybe the port isn't showing open because of something on the mac server. Again ssl certificates I am NOT familiar using, though I do have them installed on my synology nas and working, but that is an easy task as synology does most of the work. I probably really need to find someone to do this for me and pay them, which I am willing to do. Plex is soooo much easier. Plex is definitely easier. I feel like I wasted my money here.
Luke 42239 Posted July 11, 2021 Posted July 11, 2021 Hi @thePaintGuy, what is your exact problem? What kind of SSL certificate have you setup on your Emby Server?
