SeiferAlmazy 0 Posted January 8, 2021 Posted January 8, 2021 Hello all, here is my problem. I've installed emby on my small synology nas, and it worked, but due to low memory and small processor, sometimes there where lag issues. So I decided to install emby on my TS-870 pro (i7 3770 + 16 GB Ram) to have more performance. But I could'nt find a way to add the network path of the files on my synology. So here is the path I wanted to add : Synology file path : //192.168.0.5/films/films/ I've tried any solutions I could but it still doesn't work. folder \\192.168.0.5 or \\192.168.0.5\films\ or \\192.168.0.5\films\films\ optionnal \\192.168.0.5\films\films I can't find a way to fix this issue. Any help would we welcome (sorry for my aproximative english)
Luke 42241 Posted January 9, 2021 Posted January 9, 2021 Hi there, I would suggest mounting the network share to a local path using the tools in the QNAP OS, then add the local path into Emby Server. Please see if that helps. Thanks.
SeiferAlmazy 0 Posted January 10, 2021 Author Posted January 10, 2021 (edited) Hi Luke, thx for you answer. So I mounted the drive on my qnap and now I have access on the movies on the QNAP. but in emby, the path still doesn't work. no files detected... This is the path I tried to add : Edited January 10, 2021 by SeiferAlmazy
Luke 42241 Posted January 11, 2021 Posted January 11, 2021 That's not what I suggested. the \\192.XXX path is not a mounted path. That's still the original SMB path. When you mount it on the QNAP, it will be mounted to a local path. Try adding that local path into Emby Server.
SeiferAlmazy 0 Posted January 13, 2021 Author Posted January 13, 2021 I find the solution, I used putty to have access to the linux part of the Qnap, instead of the visual part from my browser. I found a procedure to mount a drive on linux and after this it worked like a charm :). Thx a lot.
Luke 42241 Posted January 13, 2021 Posted January 13, 2021 8 hours ago, SeiferAlmazy said: I find the solution, I used putty to have access to the linux part of the Qnap, instead of the visual part from my browser. I found a procedure to mount a drive on linux and after this it worked like a charm :). Thx a lot. Thanks for the feedback.
