raven-au 17 Posted January 8, 2021 Posted January 8, 2021 Hi all, As in the subject, using a Shield TV 2017, connected to a HDR10 compatible TV, where the SL DV says it's HDR10 compatible in its mediainfo display? Should this work? Is DV playback from an mp4 container supported in Emby? IOW do I need to do further investigation ...
ebr 16338 Posted January 8, 2021 Posted January 8, 2021 Hi. Can you try with the beta version of the app?
sooty234 266 Posted January 8, 2021 Posted January 8, 2021 It won't play the DV because none of your devices support it. It will play the HDR10 (if available) instead.
jrwalte 17 Posted January 8, 2021 Posted January 8, 2021 and the HDR10 doesn't require the DV layer. It will work with just the movie video (at least when MakeMKV used to create MKV). Also only the 2019 Shield supports DV
raven-au 17 Posted January 9, 2021 Author Posted January 9, 2021 (edited) 7 hours ago, sooty234 said: It won't play the DV because none of your devices support it. It will play the HDR10 (if available) instead. Your making assumptions here. The encoded videos have HDR10 compatible video and they play just fine in this case if using an mkv container. All I wanted to know is if this case should work ok and ( I apologize for it in advance) because I have been playing around with the 2019 shield tube trying to understand the problems it has with play back I'm not in a position to be accurate enough to make any bug reports if in fact there are problems other than the shield tube playback. Edited January 9, 2021 by raven-au
raven-au 17 Posted January 9, 2021 Author Posted January 9, 2021 1 hour ago, jrwalte said: and the HDR10 doesn't require the DV layer. It will work with just the movie video (at least when MakeMKV used to create MKV). Also only the 2019 Shield supports DV Also not quite what I was asking. The encoded videos play fine if they use an mkv container and they work on Shield TV 2017 and Shield TV 2019 tube connected to an HDR10 capable TV and on a Shield TV 2019 Pro connected to a DV capable TV, triggering DV with a visible improvident in quality if the original source quality (older shows that maybe haven't been remastered aren't all that good) and the scenes (darker scenes aren't so obviously improved) are appropriate. But, as I said, I'm not in a position to make a problem report just yet.
raven-au 17 Posted January 9, 2021 Author Posted January 9, 2021 (edited) 9 hours ago, ebr said: Hi. Can you try with the beta version of the app? Thanks @ebr I'll try that. Edited January 9, 2021 by raven-au
sooty234 266 Posted January 9, 2021 Posted January 9, 2021 (edited) 17 hours ago, raven-au said: Your making assumptions here. No I'm not. You asked: On 1/8/2021 at 2:21 AM, raven-au said: Hi all, As in the subject, using a Shield TV 2017, connected to a HDR10 compatible TV, where the SL DV says it's HDR10 compatible in its mediainfo display? The answer to that is no, it's impossible. HDR10 and Dolby vision are completely separate. One has nothing to do with the other, they are independent. Or did you intend to ask; If I have a single layer mp4 that has both HDR10 and Dolby Vision, and I play it with a Shield 2017 on an HDR10 TV, will the app select the HDR10 and ignore the Dolby Vision? Then the answer is, possibly, depending on the file multiplexing. It's been seen that it can work, but at present isn't a full guarantee. But they are working on it. Edited January 9, 2021 by sooty234
raven-au 17 Posted January 9, 2021 Author Posted January 9, 2021 41 minutes ago, raven-au said: But, as I said, I'm not in a position to make a problem report just yet. So, to add a little more to this while I'm waiting for the beta ... At some point I saw no video but that was a while ago and I think not consistent and my process for creating these video encodes was questionable. But I'm starting to work out the process now and just prior to asking this question I had no sound for the TrueHD Atmos track consistently (I have an Atmos capable receiver on one TV and Atmos capable soundbars on two other TVs) while the mkv container worked fine. To avoid the possible "why not just use an mkv container" I'll explain why it would be better if I could use an mp4 container instead. I'm using DVDFab to create these encoded DV videos so they are (sometimes, depending on original content) much smaller than the copied original which was all that could be done as far as I knew previously. But DVDFab only has an mp4 target profile and altering those profiles isn't straight forward so mp4 is the simplest way to go. To create an mkv without loosing DV is a rather convoluted and somewhat lengthy process so it would be good to not need to do it if possible.
raven-au 17 Posted January 9, 2021 Author Posted January 9, 2021 8 minutes ago, sooty234 said: Or did you intend to ask; If I have a single layer mp4 that has both HDR10 and Dolby Vision, and I play it with a Shield 2017 on an HDR10 TV, will the app select the HDR10 and ignore the Dolby Vision? Then the answer is, possibly, depending on the file multiplexing. It's been seen that it can work, but at present isn't a full guarantee. But they are working on it. You make a good point here. The DV support is fairly new, and I have seen inconsistent results, so there could be more problems with the playback other than no audio that require checking. Hopefully I'll be able to help with working that out if there are problems with this.
sooty234 266 Posted January 9, 2021 Posted January 9, 2021 I have DVDfab, also. It's a bit hit and miss with DV stuff. You'll just have to test it. Also, is this a disc rip with Profile 7 DV?
sooty234 266 Posted January 9, 2021 Posted January 9, 2021 3 minutes ago, raven-au said: The DV support is fairly new, and I have seen inconsistent results, so there could be more problems with the playback other than no audio that require checking. I've got some single layer DV Pro 5 only, media. And the official Dolby Labs software won't play the audio for those. So it's a craps chute.
raven-au 17 Posted January 9, 2021 Author Posted January 9, 2021 1 minute ago, sooty234 said: I've got some single layer DV Pro 5 only, media. And the official Dolby Labs software won't play the audio for those. So it's a craps chute. Oh right. All I can get using MakeMKV and using DVDFab on isos' I've created from my discs so far is profile 5, at least that's what they look like to me. Quote HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU / SMPTE ST 2086, HDR10 compatible I had read a discussion that questioned what DVDFab was doing and some test results on samples showed that the 10 bit HDR10 compatible DV video was closer to the 12 bit DV than it was to the 10 bit HDR video so it seemed worth encoding the DV videos I have, .
sooty234 266 Posted January 9, 2021 Posted January 9, 2021 I just grabbed an mp4 with DV 8.1 and HDR10 from the Dolby Developers page. It played correctly on my Shield 2017. i.e. It played the HDR10.
raven-au 17 Posted January 9, 2021 Author Posted January 9, 2021 I thought I'd seen a later DV version ... this is from the the recent (re-mastered) release of The Hobbit Trilogy ... Quote General Unique ID : 248031002404117017222434017086969507518 (0xBA990891452AFE82A96CEC6FDD9C6EBE) Complete name : /share/shadow/media/2/Movies/The Hobbit/The Hobbit An Unexpected Journey (2012)/The Hobbit An Unexpected Journey (2012) - 4K-HDR-DV.mkv Format : Matroska Format version : Version 4 File size : 42.3 GiB Duration : 3 h 2 min Overall bit rate mode : Variable Overall bit rate : 33.1 Mb/s Movie name : The Hobbit: An Unexpected Journey Encoded date : UTC 2021-01-08 06:38:38 Writing application : mkvmerge v51.0.0 ('I Wish') 64-bit Writing library : libebml v1.4.0 + libmatroska v1.6.2 Video ID : 1 ID in the original source medium : 4117 (0x1015) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, dvhe.07.00, EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 3 h 2 min Bit rate : 29.0 Mb/s Width : 3 840 pixels Height : 2 176 pixels Original height : 2 160 pixels Display aspect ratio : 16:9 Original display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.145 Stream size : 37.0 GiB (88%) Language : English Default : No Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2 Maximum Content Light Level : 801 cd/m2 Maximum Frame-Average Light Level : 188 cd/m2 Original source medium : Blu-ray Audio #1 ID : 2 Format : MLP FBA 16-ch Format/Info : Meridian Lossless Packing FBA with 16-channel presentation Commercial name : Dolby TrueHD with Dolby Atmos Codec ID : A_TRUEHD Duration : 3 h 2 min Bit rate mode : Variable Bit rate : 3 403 kb/s Maximum bit rate : 5 616 kb/s Channel(s) : 8 channels Channel layout : L R C LFE Ls Rs Lb Rb Sampling rate : 48.0 kHz Frame rate : 1 200.000 FPS (40 SPF) Compression mode : Lossless Stream size : 4.34 GiB (10%) Title : TrueHD 7.1 Atmos Language : English Default : No Forced : No Number of dynamic objects : 11 Bed channel count : 1 channel Bed channel configuration : LFE
sooty234 266 Posted January 9, 2021 Posted January 9, 2021 Yeah, that's Profile 7. Common on disc media
