dance4ever 11 Posted January 7, 2021 Posted January 7, 2021 Hi! I had a cable guy come over and he unplugged my mac mini server (10.15.6) without even asking me I rebooted and started Emby again and it comes up with the first-time configuration wizard. $HOME/emby-server still exists and as far as I know, I haven't lost any files. How do I get my Emby server to reattach to my last configuration? I actually have 2 instances of Emby running on 2 different ports (8096, 8097) and interestingly enough, the other server came up just fine. Please let me know if there are any files you need me to check as I have quite a bit of meta-data in my old config! 1
Luke 42239 Posted January 7, 2021 Posted January 7, 2021 Hi, I would try just stepping through the wizard and then see if everything comes right up after that.
dance4ever 11 Posted January 7, 2021 Author Posted January 7, 2021 ok. i'll zip the emby-server directory just in case.
Solution dance4ever 11 Posted January 7, 2021 Author Solution Posted January 7, 2021 aha - I see what's going on after looking through the log of the new instance. Since my last reboot a few weeks ago, I since installed gh through homebrew and it creates a ~/.config directory if it doesn't exist to store saved credentials. I shut down the server and did the following: cd ~/.config mv emby-server emby-server.new mv ~/emby-server . and restarting worked like a charm. given ~/emby-server is the default, you may wish to put some logic if Emby notices a new ~/.config, perhaps to ask the user if they wish to move their emby root directory into ~/.config This would explain why launchctl didn't boot this instance on startup - it was waiting to be configured. Ok - I'll leave it to your team to figure out how to handle these situations - I'm sure it doesn't happen often - though it did make my heart drop! Probably don't want this to happen too often 1
bigferther 1 Posted May 19, 2021 Posted May 19, 2021 (edited) This happened to me today! Although, as far as I know, I did not experience power loss (or Macos update, or anything else out of the ordinary for that matter). Restarted my iMac this morning and emby server starts on boot as expected, then prompted me to create my first user. Definitely not expected. I went through the wizard, but it did not restore my existing library as I had hoped. I had nearly given up and started recreating my library from scratch, but the above terminal commands got me right back up and running!! Thanks so much for this post! Edited May 19, 2021 by bigferther 1
Luke 42239 Posted May 20, 2021 Posted May 20, 2021 19 hours ago, bigferther said: This happened to me today! Although, as far as I know, I did not experience power loss (or Macos update, or anything else out of the ordinary for that matter). Restarted my iMac this morning and emby server starts on boot as expected, then prompted me to create my first user. Definitely not expected. I went through the wizard, but it did not restore my existing library as I had hoped. I had nearly given up and started recreating my library from scratch, but the above terminal commands got me right back up and running!! Thanks so much for this post! Thanks for the feedback !
bigferther 1 Posted May 20, 2021 Posted May 20, 2021 No problem. Just for reference: I think the issue for me could be related to some software I installed that day which created a new folder in the .config directory.
bjhille 3 Posted September 7, 2021 Posted September 7, 2021 This worked for me! Not sure what I installed that would have caused this, but running these commands brought my configuration back. Thank you!! 1
Luke 42239 Posted September 7, 2021 Posted September 7, 2021 9 hours ago, bjhille said: This worked for me! Not sure what I installed that would have caused this, but running these commands brought my configuration back. Thank you!! Thanks for the feedback !
