troyhough 61 Posted August 23, 2021 Author Posted August 23, 2021 1 minute ago, ebr said: My guess would be no mpeg2 decoder on those other devices... Aren't all 7 of the HDHR channels pumping out MPEG2?
Carlo 4561 Posted August 23, 2021 Posted August 23, 2021 If these are OTA channels I'd almost guarantee they're Mpeg2.
troyhough 61 Posted August 23, 2021 Author Posted August 23, 2021 Just now, cayars said: If these are OTA channels I'd almost guarantee they're Mpeg2. Yes they are all OTA channels. HEVC is not available in my market yet FYI.
troyhough 61 Posted August 25, 2021 Author Posted August 25, 2021 (edited) Channel 3, CBS, Direct Play no problem. Edited August 25, 2021 by troyhough
troyhough 61 Posted August 25, 2021 Author Posted August 25, 2021 Channel 6, NBC, Direct Play no problem.
troyhough 61 Posted August 25, 2021 Author Posted August 25, 2021 Channel 7, ABC, Direct Play no problem.
troyhough 61 Posted August 25, 2021 Author Posted August 25, 2021 Channel 10, CBS, Direct Play no problem.
troyhough 61 Posted August 25, 2021 Author Posted August 25, 2021 Channel 12, PBS, Direct Play no problem.
troyhough 61 Posted August 25, 2021 Author Posted August 25, 2021 Channel 15, CW, Will Only Transcode!
troyhough 61 Posted August 25, 2021 Author Posted August 25, 2021 Channel 42, Fox, Will Only Transcode!
troyhough 61 Posted August 25, 2021 Author Posted August 25, 2021 @ebr@cayars I got the following info/screenshots above from VLC on my LAN. Do you see any reason why the 2 channels, CW and Fox, will only Transcode with my Pixel 4 XL and Chromebooks?
Carlo 4561 Posted August 25, 2021 Posted August 25, 2021 No, we need to know why the client won't direct play those two channels.
troyhough 61 Posted August 25, 2021 Author Posted August 25, 2021 4 minutes ago, cayars said: No, we need to know why the client won't direct play those two channels. What's the best way to pull that info from an Android phone or Chromebook?
Guest Posted August 25, 2021 Posted August 25, 2021 Forgive me if this has been asked, but if you record one that transcodes, and then play the recording, do you have the same result?
troyhough 61 Posted August 25, 2021 Author Posted August 25, 2021 42 minutes ago, generiq said: Forgive me if this has been asked, but if you record one that transcodes, and then play the recording, do you have the same result? I just recorded the 2 problematic channels for about 20 minutes and played both back. Both Transcode still
Carlo 4561 Posted August 25, 2021 Posted August 25, 2021 Do you get a different reason in Stats for Nerds?
troyhough 61 Posted August 25, 2021 Author Posted August 25, 2021 9 minutes ago, cayars said: Do you get a different reason in Stats for Nerds? "Direct Play Error" for both channels, from both live and the recorded files.
troyhough 61 Posted August 25, 2021 Author Posted August 25, 2021 (edited) 5 minutes ago, cayars said: What app version are you running? 3.2.07 Edit: just uninstalled .07 and installed 3.2.05 with the exact same results. Edited August 25, 2021 by troyhough
Carlo 4561 Posted August 25, 2021 Posted August 25, 2021 OK, that's the latest. Let's see if @Luke or @ebr have any ideas.
ebr 16305 Posted August 25, 2021 Posted August 25, 2021 We'll need to see the log from the Android app to see what the error is.
troyhough 61 Posted August 25, 2021 Author Posted August 25, 2021 41 minutes ago, troyhough said: 3.2.07 @ebr @cayars Are these what you need? 15.txt 42.txt
Carlo 4561 Posted August 26, 2021 Posted August 26, 2021 No those are from the server. We are asking for the logs from the Android device. 1
ebr 16305 Posted August 26, 2021 Posted August 26, 2021 Quote Android Logs The app writes log files to the system defined data folder for the app. Generally this is: /Android/data/com.mb.android/files/logs You may need to download and install a file manager to be able to access the files. ES File Explorer is a popular choice. 1
troyhough 61 Posted August 26, 2021 Author Posted August 26, 2021 3 hours ago, ebr said: I just tried to play the 2 problematic channels. I then pulled the logs from my Pixel 4 XL. I don't know what I am looking for but is this the error in question? Thu Aug 26 11:12:38 CDT 2021 Playback Error TYPE_UNEXPECTED: : Attempt to read from field 'float com.google.android.exoplayer2.Format.pixelWidthHeightRatio' on a null object reference java.lang.NullPointerException a6bce7b2-2b87-41e6-ab95-730752d1c08b.log 06b82062-0f05-49e9-a9d7-3438d463c779.log
