Pankookis 10 Posted January 7, 2021 Posted January 7, 2021 Hi! Never used FFmpeg as a standalone software before. I'm trying to shrink some of my kids media since the quality is not as important for them. I've used Emby's convertion with great success, using the settings hevc, mkv, same quality, aac. I've been doing this on my file server where my Emby Server is installed. Unfortunataly it's quite an old computer with no dedicated GPU so it takes forever to convert stuff. Now I'm trying to do this on my other desktop which is much better. Have tried to use Handbrake but couldn't find the right settings so I thought that I should use the same thing as Emby... FFmpeg. I downloaded FFmpeg Batch AV Converter that I saw was recommended in another thread on this forum but I'm a bit lost now. I tried looking at the FFmpeg logs from my latest convertion but didn't get any smarter. What FFmpeg parameters should I use to emulate the Emby hevc,mkv,samequality,aac setting? I have a dedicated GPU on this computer also if that matters. Thanks
neik 874 Posted January 7, 2021 Posted January 7, 2021 Afaik the ffmpeg command is written in the conversion log file.
Pankookis 10 Posted January 7, 2021 Author Posted January 7, 2021 27 minutes ago, neik said: Afaik the ffmpeg command is written in the conversion log file. Yeah, I tried to look but was not sure. Spoiler C:\Users\Server\AppData\Roaming\Emby-Server\system\ffmpeg.exe -loglevel +timing -y -print_graphs_file "C:\Users\Server\AppData\Roaming\Emby-Server\programdata\logs\ffmpeg-transcode-9b826381-2254-49bf-a9ea-32f3806a213e_1graph.txt" -copyts -start_at_zero -f matroska,webm -c:v:0 h264 -i "Z:\xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx.mkv" -map 0:0 -map 0:1 -map 0:2 -map 0:3 -map 0:4 -sn -c:v:0 libx265 -g:v:0 150 -maxrate:v:0 5024708 -bufsize:v:0 10049416 -sc_threshold:v:0 0 -keyint_min:v:0 150 -preset:v:0 veryfast -profile:v:0 main -c:a:0 aac -ab:a:0 128000 -ac:a:0 2 -metadata:s:a:0 language=dan -disposition:a:0 default -c:a:1 aac -ab:a:1 128000 -ac:a:1 2 -metadata:s:a:1 language=fin -disposition:a:1 0 -c:a:2 aac -ab:a:2 128000 -ac:a:2 2 -metadata:s:a:2 language=nor -disposition:a:2 0 -c:a:3 aac -ab:a:3 128000 -ac:a:3 2 -metadata:s:a:3 language=swe -disposition:a:3 0 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 "C:\Users\Server\AppData\Roaming\Emby-Server\programdata\sync\23\84\9b826381-2254-49bf-a9ea-32f3806a213e.mkv" 16:08:37.229 ffmpeg version 4.3.0-emby_2020_05_23-g8f222573e9+530 Copyright (c) 2000-2019 the FFmpeg developers and softworkz for Emby LLC 16:08:37.231 built with gcc 9.2.0 (Rev2, Built by MSYS2 project) 16:08:37.233 Execution Date: 2021-01-06 16:08:37 16:08:37.316 Input #0, matroska,webm, from 'Z:\xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx.mkv': 16:08:37.316 Metadata: 16:08:37.317 encoder : libebml v1.3.6 + libmatroska v1.4.9 16:08:37.317 creation_time : 2020-03-08T08:42:25.000000Z 16:08:37.317 Duration: 00:23:29.22, start: 0.000000, bitrate: 2512 kb/s 16:08:37.317 Stream #0:0: Video: h264 (Main), yuv420p(progressive), 768x576 [SAR 1:1 DAR 4:3], Level 31, 25 fps, 25 tbr, 1k tbn, 50 tbc (default) 16:08:37.317 Metadata: 16:08:37.317 BPS-eng : 1997762 16:08:37.317 DURATION-eng : 00:23:29.200000000 16:08:37.317 NUMBER_OF_FRAMES-eng: 35230 16:08:37.317 NUMBER_OF_BYTES-eng: 351905936 16:08:37.318 Stream #0:1(dan): Audio: ac3, 48000 Hz, stereo, fltp, 128 kb/s (default) 16:08:37.318 Metadata: 16:08:37.318 title : Dansk 16:08:37.318 BPS-eng : 128000 16:08:37.318 DURATION-eng : 00:23:29.216000000 16:08:37.318 NUMBER_OF_FRAMES-eng: 44038 16:08:37.318 NUMBER_OF_BYTES-eng: 22547456 16:08:37.318 Stream #0:2(fin): Audio: ac3, 48000 Hz, stereo, fltp, 128 kb/s 16:08:37.318 Metadata: 16:08:37.318 title : Suomi 16:08:37.318 BPS-eng : 128000 16:08:37.318 DURATION-eng : 00:23:29.216000000 16:08:37.318 NUMBER_OF_FRAMES-eng: 44038 16:08:37.318 NUMBER_OF_BYTES-eng: 22547456 16:08:37.318 Stream #0:3(nor): Audio: ac3, 48000 Hz, stereo, fltp, 128 kb/s 16:08:37.318 Metadata: 16:08:37.318 title : Norsk 16:08:37.318 BPS-eng : 128000 16:08:37.318 DURATION-eng : 00:23:29.216000000 16:08:37.318 NUMBER_OF_FRAMES-eng: 44038 16:08:37.318 NUMBER_OF_BYTES-eng: 22547456 16:08:37.318 Stream #0:4(swe): Audio: ac3, 48000 Hz, stereo, fltp, 128 kb/s 16:08:37.318 Metadata: 16:08:37.318 title : Svensk 16:08:37.318 BPS-eng : 128000 16:08:37.318 DURATION-eng : 00:23:29.216000000 16:08:37.318 NUMBER_OF_FRAMES-eng: 44038 16:08:37.318 NUMBER_OF_BYTES-eng: 22547456 16:08:37.324 Stream mapping: 16:08:37.324 Stream #0:0 -> #0:0 (h264 (native) -> hevc (libx265)) 16:08:37.324 Stream #0:1 -> #0:1 (ac3 (native) -> aac (native)) 16:08:37.324 Stream #0:2 -> #0:2 (ac3 (native) -> aac (native)) 16:08:37.324 Stream #0:3 -> #0:3 (ac3 (native) -> aac (native)) 16:08:37.324 Stream #0:4 -> #0:4 (ac3 (native) -> aac (native)) 16:08:37.324 Press [q] to stop, [?] for help x265 [info]: HEVC encoder version 3.2+23-52135ffd9bcd x265 [info]: build info [Windows][GCC 9.2.0][64 bit] 8bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX x265 [info]: Main profile, Level-3 (Main tier) x265 [info]: Thread pool created using 4 threads x265 [info]: Slices : 1 x265 [info]: frame threads / pool features : 2 / wpp(9 rows) x265 [warning]: Source height < 720p; disabling lookahead-slices x265 [info]: Coding QT: max CU size, min CU size : 64 / 8 x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra x265 [info]: ME / range / subpel / merge : hex / 57 / 1 / 2 x265 [info]: Keyframe min / max / scenecut / bias : 25 / 250 / 40 / 5.00 x265 [info]: Lookahead / bframes / badapt : 15 / 4 / 0 x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 0 x265 [info]: References / ref-limit cu / depth : 2 / on / on x265 [info]: AQ: mode / str / qg-size / cu-tree : 2 / 1.0 / 32 / 1 x265 [info]: Rate Control / qCompress : CRF-28.0 / 0.60 x265 [info]: VBV/HRD buffer / max-rate / init : 10049 / 5024 / 0.750 x265 [info]: tools: rd=2 psy-rd=2.00 early-skip rskip signhide tmvp fast-intra x265 [info]: tools: strong-intra-smoothing deblock sao Is it all those parameters at the top? Row 2 down to the break?
Pankookis 10 Posted January 7, 2021 Author Posted January 7, 2021 8 minutes ago, Sammy said: Why not just use Handbrake? Tried several settings and everything either didn't shrink the size, or it got bigger. When I've used Emby, I managed to shrink a ~400 megabyte episode down to maybe 165 megabyte. I have not been able to achieve similar results with anything else than Emby.
Ronstang 294 Posted January 7, 2021 Posted January 7, 2021 1 hour ago, Pankookis said: Tried several settings and everything either didn't shrink the size, or it got bigger. When I've used Emby, I managed to shrink a ~400 megabyte episode down to maybe 165 megabyte. I have not been able to achieve similar results with anything else than Emby. If that is all you want and it's for kid's stuff then just use MCEBuddy but if it's an older PC with no GPU capable of hardware encoding of HEVC it is still going to take forever. If you have or get an nVidia GPU capable of HEVC and decide to try MCEBuddy I will give you a profile I use for my kid's TV and TV movies and some movies but it is not high quality enough for horror movies or those that have a lot of dark content. An example of size of output....all PAW Patrol episodes come out around 170 G.....for 11 minute episodes. About twice that or a little bigger for Spongebob double episodes of ~23 minutes. Animation compresses very well and does not require as high of quality settings to retain the quality of the original from my experience.
