saikik 0 Posted January 7, 2021 Posted January 7, 2021 Hi. I have a local TV stream in IPTV and in the m3u file best quality is on the third line. Would be nice if theres a option to choose quality when there more than one stream in m3u file. Right now it chooses the first one.
neik 874 Posted January 7, 2021 Posted January 7, 2021 Have a look at this post, might be a solution for you:
saikik 0 Posted January 7, 2021 Author Posted January 7, 2021 7 hours ago, neik said: Have a look at this post, might be a solution for you: Thanks for the replay. Im taking the m3u from the channel page itselt. Ive tried to download, change the order and play it then but I get error, cant connect.
Carlo 4561 Posted January 9, 2021 Posted January 9, 2021 The next version of Live TV should help you with this. Stay tuned for more info on this in the near future.
