vdatanet 1619 Posted August 30, 2019 Posted August 30, 2019 (edited) In my opinion: - When you set an watched episode as unwatched, watched datetime should be set to null - When you watch a watched episode, watched datetime should be updated Is that true? What is the current behavior? Edited August 30, 2019 by vdatanet
vdatanet 1619 Posted August 30, 2019 Posted August 30, 2019 (edited) Episode S1.E7 of Show "Verano Azul" was watched yesterday: And it's marked as watched: With the API I've tried to get info from S1.E7 episode: { "Name": "Beatriz, Mon amour", "ServerId": "0e2add2c5d074653acbdafb6dd2b36b7", "Id": "47869", "PremiereDate": "1981-11-22T00:00:00.0000000+00:00", "RunTimeTicks": 37207360000, "IndexNumber": 7, "ParentIndexNumber": 1, "IsFolder": false, "Type": "Episode", "ParentBackdropItemId": "45554", "ParentBackdropImageTags": [ "0383bee4148b7d3f8d657ecbd1285765" ], "UserData": { "PlaybackPositionTicks": 0, "PlayCount": 1, "IsFavorite": false, "Played": true }, "SeriesName": "Verano Azul", "SeriesId": "45554", "SeasonId": "45642", "SeriesPrimaryImageTag": "ca4b2cf4855ef2f7bbd1f99d4bf236bd", "SeasonName": "Temporada 1", "ImageTags": { "Primary": "4267fcd73c5d26b353325684b37738a6" }, "BackdropImageTags": [], "ParentThumbItemId": "45554", "ParentThumbImageTag": "2802b70b0290fcf80b7fef90de559d9a", "MediaType": "Video" }, I see played = true, but LastPlayedDate is empty. I guess that's why this show is not in the first position of the "Next Up" row. What could have happened? Today I've played the episode again and now LastPlayedDate has value, and the show is now the first one in "Next Up". So my conclusion is that LastPlayedDate sometimes is not updated. I have to say that there are very few watched episodes with empty LastPlayedDate, but there are. "UserData": { "PlaybackPositionTicks": 0, "PlayCount": 2, "IsFavorite": false, "LastPlayedDate": "2019-08-30T16:55:01.0000000+00:00", "Played": true }, Edited August 30, 2019 by vdatanet
Luke 42210 Posted August 31, 2019 Posted August 31, 2019 Did you manually toggle the watch state off and on? That could be why.
vdatanet 1619 Posted August 31, 2019 Posted August 31, 2019 (edited) No, I thought that was the problem and did the following test: - I marked as unwatched a watched episode: watched was set to false and the last watched date was unset. - I marked as watched an unwatched episode: watched was set to true and the last watched date was set correctly Edited August 31, 2019 by vdatanet
vdatanet 1619 Posted August 31, 2019 Posted August 31, 2019 (edited) I also thought it was a sync problem with Trakt, but it wasn't. I marked as watched an episode on Trakt and after sync, Emby had the correct values, watched = true and last watched date had the correct value. At some point Emby does not set last watched date correctly. I tried all different situations where that date should be updated and always was correct. Do you have another suggestion to test? Anyway, this bug is shown very rarely and the only consequence is sorting of "Next Up", it should not be a priority. Edited August 31, 2019 by vdatanet
vdatanet 1619 Posted September 3, 2019 Posted September 3, 2019 Any idea when the last playback date set may fail? I've found a couple more episodes, watched without last watched date.
Luke 42210 Posted September 4, 2019 Posted September 4, 2019 It could perhaps be from trakt. I'm not sure. You could try running without it for a little while and see if it happens again with new content.
Gilgamesh_48 1243 Posted September 4, 2019 Posted September 4, 2019 It could perhaps be from trakt. I'm not sure. You could try running without it for a little while and see if it happens again with new content. I have had a few, non-serious, errors caused by being connected to Trakt. I have currently three servers running and I use Trakt to keep the TV watched status synced. Once in a rare while something happens on one of the servers and it gets the watched status screwed up on all the servers if the screwed up server updates its watched status before the others or if the screwed up server gets ahead of all the others. One example is that the screwed up server somehow marked a season two as watched on one of my servers when I was actually watching somewhere in the middle of season one. When that updated to TRAKT I suddenly had S03E01 as my "Next up." I tried to correct it on the server I was using for watching but every time it hit Trakt season two would be marked as watched. To fix the problem I had to go into each server and mark season two unwatched before an update to Trakt and go into Trakt and mark season two unwatched. It worked OK. I am sure that there might be an easier way but I want to keep all three servers equal in the eyes of Trakt. That is. right now, I do not want a "primary" server with the others in a subservient mode.. Once everything pretty much stabilizes in functionality (problems due to having to reinstall Emby) there will be one server as the "primary" server and the others will just get updated from Trakt to stay in sync with the primary. But for now I am as likely to watch something from one as I am from another and I just want to have it be pretty reliable and that is exactly where it is. The screwups are both rare and unpredictable.
vdatanet 1619 Posted September 7, 2019 Posted September 7, 2019 (edited) It could perhaps be from trakt. I'm not sure. You could try running without it for a little while and see if it happens again with new content. Since I have deactivated the import from Trakt, I have not seen this problem anymore. Edited September 7, 2019 by vdatanet
vdatanet 1619 Posted September 13, 2019 Posted September 13, 2019 (edited) Trakt disabled and again episodes played without last watched date, all played with Apple TV. I have done some tests and all those episodes are played with the client for Apple TV. Approximately 50% of the episodes played with Apple TV are marked as watched without the last watched date. https://emby.media/community/index.php?/topic/77518-sometimes-after-playing-an-episode-it-is-marked-as-watched-without-the-last-watched-date/ Edited September 13, 2019 by vdatanet
Luke 42210 Posted September 14, 2019 Posted September 14, 2019 And this is only with trakt installed?
vdatanet 1619 Posted September 14, 2019 Posted September 14, 2019 (edited) And this is only with trakt installed? It happens with and without trakt plugin installed: This is an episode I played yesterday on Apple TV: Look that is played and last played date is missing. After playing that episode, next episode is not in the first position of "Next Up" row. There's not any trakt command in that period of time, because it's uninstalled. But this occurs randomly. I've never seen this in any other Emby client, only in the Apple TV client. Edited September 14, 2019 by vdatanet
vdatanet 1619 Posted September 14, 2019 Posted September 14, 2019 In this particular case, trakt was installed with tasks disabled (import and sync), just scrobbling and trakt has the right date:
vdatanet 1619 Posted September 14, 2019 Posted September 14, 2019 Scrobbling seems to be the problem, it's not enough to disable import and sync. Can I have the plugin installed with scrobbling disabled and run sync tasks manually? I can't find and option to disable scrobbling.
Animizio 0 Posted November 17, 2019 Posted November 17, 2019 Yeah I m also with this problem. For the app it was only annoying a bit.. But for Kodi and embruary it's a Desaster.. I need a lot of time to search my actual watching TV shows, because they are nearly at the end of my list sometimes.. Please get a logical sorting for this. For example "last played" or something. It works for Kodi in different skins with custom lists. Please add it for emby apps and Kodi too. Thank you
Luke 42210 Posted December 26, 2019 Posted December 26, 2019 Please try the 3.4.0 update to the Trakt plugin. Thanks.
vdatanet 1619 Posted March 1, 2020 Posted March 1, 2020 Issue is still present. Sometimes a watched item has an empty last watched date.
Luke 42210 Posted March 1, 2020 Posted March 1, 2020 Sometimes Can you try to find the differences of when it does and when it doesn't? Thanks.
vdatanet 1619 Posted March 1, 2020 Posted March 1, 2020 Can you try to find the differences of when it does and when it doesn't? Thanks. No, The only thing I can say is that before version 3.4 of the plugin it happened very often, instead now it happens very rarely, but I have never been able to reproduce it. I will try to notice when it happens. I attach server log, but it can't see nothing special. 2020-03-01 21:06:15.219 Info HttpServer: HTTP POST http://192.168.1.100:8096/emby/Sessions/Playing/Stopped. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-03-01 21:06:15.219 Info EncodingManager: Deleting partial stream file(s) /var/lib/emby/transcoding-temp/E4E8AD.m3u8 2020-03-01 21:06:15.219 Info SessionManager: Playback stopped reported by app AndroidTv 1.7.78g playing El gran Lunes. Stopped at 2547384 ms 2020-03-01 21:06:15.221 Info Trakt: Playback Stopped 2020-03-01 21:06:15.221 Info HttpServer: HTTP Response 204 to 192.168.1.88. Time: 2ms. http://192.168.1.100:8096/emby/Sessions/Playing/Stopped 2020-03-01 21:06:15.221 Info Trakt: Item is played. Scrobble 2020-03-01 21:06:15.221 Info HttpClient: POST https://api.trakt.tv/scrobble/stop 2020-03-01 21:06:15.221 Info HttpServer: HTTP Response 200 to 192.168.1.88. Time: 2ms. http://192.168.1.100:8096/emby/Shows/NextUp?Fields=Overview&SeriesId=1502&UserId=575b9dd9ae9242548f5bd17cd52c541f&EnableTotalRecordCount=false&Limit=1&format=json 2020-03-01 21:06:15.355 Info HttpServer: HTTP GET http://192.168.1.100:8096/emby/Users/575b9dd9ae9242548f5bd17cd52c541f/Items/2827?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-03-01 21:06:15.357 Info HttpServer: HTTP Response 200 to 192.168.1.88. Time: 2ms. http://192.168.1.100:8096/emby/Users/575b9dd9ae9242548f5bd17cd52c541f/Items/2827?format=json 2020-03-01 21:06:15.395 Info HttpServer: HTTP POST http://192.168.1.100:8096/emby/Items/2827/PlaybackInfo?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-03-01 21:06:15.397 Info MediaInfoService: User policy for joan. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True embyserver.txt
Gilgamesh_48 1243 Posted March 1, 2020 Posted March 1, 2020 Just as a point of info on my systems the Trakt plugin has no issues. I am running server version 4.4.0.17 (beta) on my main system and 4.3.1.0 on my Shield server. Trakt is installed on both systems. I also have a Plex server that is running Trakt as well. I had a problem some time ago when I attempted to reactivate an old Plex server and it was so of of date that it updated Trakt with very outdated data and really screwed up my next up status on both my Emby servers. I reverted the Emby servers back to the data as it was before I activated that Plex server was activated but I could not get Trakt correct. I the created a new Trakt account and linked my Emby servers to the new account. Then I completely deleted the Plex server and all related data and reinstalled Plex anew and added Trakt back to it. I allowed Plex to sync to the new Trakt account and then fully linked Trakt to it as well. I now have Trakt updating (push/pull) all my servers and everything is absolutely solid and I can watch any show on any server and it updates Trakt and the other servers correctly. I spent a LOT of time trying to fix the screwed up data on Trakt but it seems that once it is screwed up it becomes nearly unfixable and the only way to get correct operation back is with a new account.
vdatanet 1619 Posted August 1, 2020 Posted August 1, 2020 There are still episodes watched with no watched date using Trakt, causing the "Next Up" row to be completely messy.
Luke 42210 Posted August 1, 2020 Posted August 1, 2020 We'd have to go over a specific example. Thanks.
vdatanet 1619 Posted August 1, 2020 Posted August 1, 2020 16 minutes ago, Luke said: We'd have to go over a specific example. Thanks. Isn't this topic a representative enough example?
