Mark-Ev 0 Posted January 4, 2021 Posted January 4, 2021 (edited) Can't seem to update metadata or refresh media library. Synology CPU pegs at 99% and stays there until I manually stop the server. Updated to: emby-server-synology_4.5.4.0_x86_64.spk Rebooted several times to see if fault would clear. Previous version (emby-server-synology_4.5.2.0_x86_64.spk) I had also did some weird things and would not work properly but I gave up and left it for months. This version just fails to update anything even though I can play media that's listed. DS918+ Log is attached. embyserver.txt Edited January 4, 2021 by Mark-Ev added model
Luke 42243 Posted January 4, 2021 Posted January 4, 2021 Hi there, how have you configured your libraries in emby library setup?
Mark-Ev 0 Posted January 5, 2021 Author Posted January 5, 2021 Luke, Not sure what exactly you mean but here is what I think you're asking. I have two libraries, Movies and TV shows Under "Server" - > "Library" - edit selected under each library; Folders for "Movies" /volume1/Emby \\DS918plus\NAS\Video\MOVIE RIPS Folders for "TV shows"; \\DS918plus\NAS\Video\TV Series
Solution Happy2Play 9812 Posted January 5, 2021 Solution Posted January 5, 2021 I would assume this System.OutOfMemoryException could be a factor. 2021-01-04 12:55:29.815 Error App: Error in GetLibraryUpdateInfo *** Error Report *** Version: 4.5.4.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /volume1/Emby -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -updatepackage emby-server-synology_{version}_x86_64.spk Operating system: Linux version 4.4.59+ (root@build3) (gcc version 4.9.3 20150311 (prerelease) (crosstool-NG 1.20.0) ) #25426 SMP PREEMPT Mon Dec 14 18:48:50 CST 2020 Framework: .NET Core 3.1.8 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 4 Data path: /volume1/Emby Application path: /volume1/@appstore/EmbyServer/system System.OutOfMemoryException: System.OutOfMemoryException: Exception of type 'System.OutOfMemoryException' was thrown. at System.Collections.Generic.LargeArrayBuilder`1.AllocateBuffer() at System.Collections.Generic.LargeArrayBuilder`1.AddWithBufferAllocation(T item, T[]& destination, Int32& index) at System.Collections.Generic.LargeArrayBuilder`1.AddRange(IEnumerable`1 items) at System.Collections.Generic.EnumerableHelpers.ToArray[T](IEnumerable`1 source) at MediaBrowser.Controller.Entities.BaseItem.IsVisibleStandaloneInternal(User user) at MediaBrowser.Controller.Entities.BaseItem.IsVisibleStandalone(User user) at Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier.TranslatePhysicalItemToUserLibrary[T](T item, User user, Boolean includeIfNotFound) at Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier.<>c__DisplayClass29_0.<GetLibraryUpdateInfo>b__0(BaseItem i) at System.Linq.Enumerable.SelectManySingleSelectorIterator`2.MoveNext() at System.Linq.Enumerable.SelectEnumerableIterator`2.MoveNext() at System.Linq.Set`1.UnionWith(IEnumerable`1 other) at System.Linq.Enumerable.DistinctIterator`1.FillSet() at System.Linq.Enumerable.DistinctIterator`1.ToArray() at Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier.GetLibraryUpdateInfo(List`1 itemsAdded, List`1 itemsUpdated, List`1 itemsRemoved, List`1 foldersAddedTo, List`1 foldersRemovedFrom, Int64 userId) at Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier.SendChangeNotifications(List`1 itemsAdded, List`1 itemsUpdated, List`1 itemsRemoved, List`1 foldersAddedTo, List`1 foldersRemovedFrom, CancellationToken cancellationToken) Source: System.Linq TargetSite: Void AllocateBuffer() That log appears to only show one library. Info LibraryMonitor: Watching directory /volume1/Emby Why is your data path configured as a Library? That path is only for Emby programdata. So you are creating a infinite loop on itself if I am reading this correctly.
Luke 42243 Posted January 5, 2021 Posted January 5, 2021 @Happy2Play excellent catch ! that's why i asked about the libraries because I expected we'd find something funny like that going on.
Mark-Ev 0 Posted January 5, 2021 Author Posted January 5, 2021 Happy2Play, It was a while a go (1yr?)but my recollection is that it was a default directory. I did not want to move the media files to the Emby directory so I added my own library directory and gave Emby full access under the NAS User Control settings. I left the "Emby" directory there. Unless during installation I was asked to select a destination? Funny that it used to work OK until I upgraded to a new version. I will try to remove the directory reference. As for RAM usage, the DSM Resource Monitor says RAM is OK at 11%. Thanks for your help.
Luke 42243 Posted January 5, 2021 Posted January 5, 2021 At some point you must have added that folder as an emby library folder, which is not good because that's also the server's data folder. I would suggest removing it and then running a full library scan.
Mark-Ev 0 Posted January 5, 2021 Author Posted January 5, 2021 Thank you very much guys. Looks like it's fixed!
