renewgeorgia 0 Posted January 4, 2021 Posted January 4, 2021 My p2000 is apparently installed, shows up in unraid devices. But when I go to transcoding advanced, nothing us shown under preferred hardware encoders. I am using: Ryzen 3700x Gigabyte x570 I Aorus pro wifi 32gig mem DDR4 [1022:1482] 00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1483] 00:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [10de:1c30] 09:00.0 VGA compatible controller: NVIDIA Corporation GP106GL [Quadro P2000] (rev a1) [10de:10f1] 09:00.1 Audio device: NVIDIA Corporation GP106 High Definition Audio Controller (rev a1) Any suggestions?
Luke 42246 Posted January 4, 2021 Posted January 4, 2021 Hi there, did you follow our hardware acceleration setup guide? https://support.emby.media/support/solutions/articles/44001160148-hardware-acceleration-overview
renewgeorgia 0 Posted January 4, 2021 Author Posted January 4, 2021 2 hours ago, Luke said: Hi there, did you follow our hardware acceleration setup guide? https://support.emby.media/support/solutions/articles/44001160148-hardware-acceleration-overview Yes, but it did not seem to help... it just said emby supports certain HA variants, listed a few, and mine P2000 appears to be one of them per the gpu support matrix.. It mentions a min driver version, but I have no idea how to see driver version and apparently I can not update drivers, have to be updated in unraid release? But... the card is shown in unraid so it is apparently working, but emby does not see it.
renewgeorgia 0 Posted January 4, 2021 Author Posted January 4, 2021 Found my driver, it meets the minimum.... any ideas please? Nvidia Driver Version: 455.38 Installed GPU(s): 0: Quadro P2000 09:00.0 GPU-ca5a1351-effb-02ea-23e7-065bd4907d01
RanmaCanada 502 Posted January 5, 2021 Posted January 5, 2021 You would be better to ask this on the unraid forums as it is an ongoing problem with Plex and Emby. but here is a nice video that should help.
renewgeorgia 0 Posted January 5, 2021 Author Posted January 5, 2021 Thanks for the advice. I figured it out... https://forums.unraid.net/topic/98978-plugin-nvidia-driver/ had to edit the emby install to see the card. anyone else have this issue, go to that link to solve.
Luke 42246 Posted January 5, 2021 Posted January 5, 2021 Glad you figured it out. Thanks for the feedback.
