gawtmw 1 Posted January 3, 2021 Posted January 3, 2021 Before I move from Plex to Emby, I want to make sure that closed captions work on my OTA recorded shows in Emby? CC in Plex doesn't work.
gawtmw 1 Posted January 6, 2021 Author Posted January 6, 2021 (edited) I'm using a Nvidia Shield TV Pro 2019. Closed Captions will work on this? I also have a samsung smart tv. Will it work on the emby tizen app? Edited January 6, 2021 by gawtmw
Luke 42239 Posted January 6, 2021 Posted January 6, 2021 18 minutes ago, gawtmw said: I'm using a Nvidia Shield TV Pro 2019. Closed Captions will work on this? I also have a samsung smart tv. Will it work on the emby tizen app? Hi, yes, using our Android TV app.
gawtmw 1 Posted January 6, 2021 Author Posted January 6, 2021 Ok...I downloaded the app on the samsung smart tv and onto my Nvidia Shield...I can watch the show but when I press down and check the box for the cc, it doesn't work. It says CC (und).
Luke 42239 Posted January 7, 2021 Posted January 7, 2021 1 hour ago, gawtmw said: Ok...I downloaded the app on the samsung smart tv and onto my Nvidia Shield...I can watch the show but when I press down and check the box for the cc, it doesn't work. It says CC (und). HI, what exactly do you mean by "doesn't work" ?
gawtmw 1 Posted January 7, 2021 Author Posted January 7, 2021 (edited) When I select CC, it doesn't show up while I'm watching a recorded tv show. Edited January 7, 2021 by gawtmw
vdatanet 1619 Posted January 7, 2021 Posted January 7, 2021 (edited) Playback method? Direct play? Direct streaming? Remuxing? Transcoding? I think CC only work while direct playing. So, you need these two options enabled: - In Live TV options, Enable direct play Live TV - In playback options, Enable direct play of TS streams Edited January 7, 2021 by vdatanet
Luke 42239 Posted January 7, 2021 Posted January 7, 2021 @gawtmw please let us know if this helps. Thanks !
gawtmw 1 Posted January 7, 2021 Author Posted January 7, 2021 Not seeing where I can enable direct play live TV. I enable the other one.
gawtmw 1 Posted January 7, 2021 Author Posted January 7, 2021 On the Samsung Smart TV, I still do not have CC available.
vdatanet 1619 Posted January 7, 2021 Posted January 7, 2021 (edited) 56 minutes ago, gawtmw said: Not seeing where I can enable direct play live TV. I enable the other one. Settings - Live TV - (1st option) Direct Play Live TV. Edited January 7, 2021 by vdatanet
