Zanr7 0 Posted January 3, 2021 Posted January 3, 2021 Hi guys need some advice when i try to go to watch films my Emby server stops and i need to keep logging in to the server and starting it agin but will only last a matter of hours then turns it off again
Luke 42237 Posted January 4, 2021 Posted January 4, 2021 Hi there, can you please attach the emby server log from when this happens: Thanks.
Zanr7 0 Posted January 4, 2021 Author Posted January 4, 2021 ok i have found the logs what one would you like
Zanr7 0 Posted January 4, 2021 Author Posted January 4, 2021 ok bud here you go thank you embyserver.txt embyserver-63745315200.txt embyserver-63745371976.txt
Luke 42237 Posted January 6, 2021 Posted January 6, 2021 Ok, I've submitted 4.5.4 to TerraMaster. Let's see how that compares once you have that. You can always install manually from our website.
Zanr7 0 Posted January 6, 2021 Author Posted January 6, 2021 ok thank you for your help if i were to do it how would i do it and would it be armv8 or 64 bit
Zanr7 0 Posted January 7, 2021 Author Posted January 7, 2021 Cheers bud ok i updated the package to the latest one and i'm afraid it has not fixed the issue
Luke 42237 Posted January 7, 2021 Posted January 7, 2021 Ok I'm not able to reproduce here but we'll try to chase it down. Thanks.
expectmercy 0 Posted January 15, 2021 Posted January 15, 2021 (edited) @Luke I have the same problem with my F2-210. Emby (v4.5.2) stops running sometimes especially when I run the client on my TV. Initially it was transcoding (4k) for very large files (>6GB) so I shut it off. It was to just stop working. I can understand this due to low computational power. It does work for same type of encoded file of size 4GB. It is slow but works. Now whenever I press 10s back button it does go back once and then it stops. After few moments emby server stops working. I saw ffmpeg still running even though I have shut off transcoding. I do not understand what causes this. I am not able to find logs now. Once it happens I can attach them again. Also when I resume playback, I can not go back at all. IS this normal behavior? So I am still curious why this happens. Thanks in advance! Cheers Edited January 15, 2021 by expectmercy
Luke 42237 Posted January 23, 2021 Posted January 23, 2021 Hi, have you updated to Emby Server 4.5.4? Are you still having an issue with this?
