desmond7 0 Posted January 2, 2021 Posted January 2, 2021 I try to choose the preferred audio language to Chinese Traditional (or Chinese Traditional (Hong Kong)), hoping that the desired audio, instead of the default audio track, will be played. However, Chinese Simplified is saved after Chinese Traditional is chosen. The same happens in the subtitle preference.
Abobader 3485 Posted January 2, 2021 Posted January 2, 2021 Hello desmond7, Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Carlo 4561 Posted January 3, 2021 Posted January 3, 2021 On 1/2/2021 at 2:10 AM, desmond7 said: I try to choose the preferred audio language to Chinese Traditional (or Chinese Traditional (Hong Kong)), hoping that the desired audio, instead of the default audio track, will be played. However, Chinese Simplified is saved after Chinese Traditional is chosen. The same happens in the subtitle preference. So this happens every time you play something new and choose Chinese Traditional?
desmond7 0 Posted January 6, 2021 Author Posted January 6, 2021 This happens every time after I choose Chinese Traditional. In other words, Chinese Traditional cannot be chosen.
Carlo 4561 Posted January 9, 2021 Posted January 9, 2021 I read this as there being 2 or more audio and subs tracks. He chooses the Chinese Traditional track but instead Emby save it (for next use) as Chinese Simplified instead. @desmond7 did I get that correct?
Luke 42204 Posted January 23, 2021 Posted January 23, 2021 Ok I see what's going on. We'll take a look at it. Thanks for reporting.
