yaksplat 68 Posted January 2, 2021 Posted January 2, 2021 Found a handy way to change the volume of the pi, without needing to open up a window. amixer -q -M sset Headphone {volume}% This will adjust the volume for the device Headphone, but use PCM for the HDMI port. 85% is the max, before the audio becomes distorted. public async Task<string> SetVolume(string ip, int volume) { string retval; retval = ""; using (var client = new SshClient(ip, 22, "pi", "raspberry")) { client.Connect(); try { client.RunCommand($"amixer -q -M sset Headphone {volume}%"); } catch (SshConnectionException) { retval = "Disconnected"; } } return retval; } 1
yaksplat 68 Posted January 3, 2021 Author Posted January 3, 2021 Better yet, i found that there's an extension class on Renci.SshNet to make async calls The fade is nice and gradual, not an instant change. using Renci.SshNet.Async; public async Task<string> SetVolume(string ip, int volume) { string retval; retval = ""; using (var client = new SshClient(ip, 22, "pi", "raspberry")) { client.Connect(); try { string command = $"amixer -q -M sset Headphone {volume}%"; var cmd = client.CreateCommand(command); var response = await cmd.ExecuteAsync(); } catch (SshConnectionException) { retval = "Disconnected"; } } return retval; } public async Task<string> FadeVolume(string ip, int volume) { int StartingVolume = await GetVolume(ip); if(StartingVolume > volume) { for (int i = StartingVolume; i >= volume; i-=1) { await SetVolume(ip, i); } } else { for (int i = StartingVolume; i <= volume; i += 1) { await SetVolume(ip, i); } } return null; } public async Task<int> GetVolume(string ip) { int vol=0; using (var client = new SshClient(ip, 22, "pi", "raspberry")) { client.Connect(); try { string command = "amixer -M sget Headphone |grep % |awk '{print $4}'|sed 's/[^0-9]//g'"; var cmd = client.CreateCommand(command); var response = await cmd.ExecuteAsync(); if (response != null) { Int32.TryParse(response.TrimEnd("/n".ToCharArray()),out vol); } } catch (SshConnectionException) { } } return vol; }
