soundino 0 Posted January 1, 2021 Posted January 1, 2021 Hi everyone.... I have updated my F4-210 to version 4.2.07 .... Now I don't leave Emby anymore ...... with the version in the store of Emby it gave me the error "502 Bad Gateway". I manually updated Emby with the site version "emby_TOS_APP_4.5.4.0_aarch64.tpk", the installation is successful, but when I launch it it gives me the error "connection denied from 192.168.1.8" (which is the address of the NAS. Moreover, updating the version is 4.5.2.0 and not 4.5.4.0 ....). I tried several times to uninstall and reinstall Emby and reboot the NAS but nothing .... always the same problem ...... A little help, please ..... Hello and happy new year to all ....... Fabio
Luke 42237 Posted January 1, 2021 Posted January 1, 2021 Hi there, are you sure emby server is started and running?
soundino 0 Posted January 1, 2021 Author Posted January 1, 2021 Ciao..... Apart from the screenshot I attached, how else can you see if the server is running?
soundino 0 Posted January 1, 2021 Author Posted January 1, 2021 mmmmm ...... I realized now that if I switch to another TOS application screen and then return to Emby, the latter stops .... I attach a short video ...... Emby.wmv
Luke 42237 Posted January 2, 2021 Posted January 2, 2021 Can you please attach the emby server log from when this happens? Thanks.
soundino 0 Posted January 2, 2021 Author Posted January 2, 2021 How can I do it, the log, if Emby doesn't start? Could you tell me the steps to follow Thanks a lot. I attach a video Video.mp4
soundino 0 Posted January 6, 2021 Author Posted January 6, 2021 (edited) Emby ancora non va ........ Mi dispiace, perché mi piace molto di più di Plex, perché, oltre ad altre cose, Emby ti permette di vedere i poster delle cartelle ... Ma continua a darmi "502 Bad Gateway" ... Ho anche provato a reinstallare il TOS (4.2.07) e poi a disinstallare e reinstallare Emby, ma niente ....... Ho notato però che oltre per non avviare il server, la riga dell'indirizzo è come lo schermo che allego, diversa dagli altri programmi ..... va bene? Se puoi aiutarmi ... Grazie Edited January 6, 2021 by soundino
soundino 0 Posted January 6, 2021 Author Posted January 6, 2021 Sorry, I realized now that I wrote in Italian ...... Emby still not going ........ I'm sorry, because I like it a lot more than Plex, because, in addition to other things, Emby allows you to see folder posters ... But he keeps giving me "502 Bad Gateway" ... I also tried reinstalling the TOS (4.2.07) and then uninstalling and reinstalling Emby, but nothing ....... But I noticed that in addition to not starting the server, the address line is like the screen that I attach, different from the other programs ..... okay? If you can help me ... Thanks
soundino 0 Posted January 8, 2021 Author Posted January 8, 2021 No help or idea? Ok .... Thanks anyway.
Luke 42237 Posted January 14, 2021 Posted January 14, 2021 Hi, have you tried updating to Emby Server 4.5.4?
soundino 0 Posted January 14, 2021 Author Posted January 14, 2021 Hello...... Yes ... I did ... Now I uninstalled and reinstalled it, it's still the same and she doesn't want to leave ..... f I open the window in the address bar in the browser, I get this ...... I am attaching a screenshot and a video .... Video 2.mp4
Luke 42237 Posted January 23, 2021 Posted January 23, 2021 Hi, have you updated to Emby Server 4.5.4? Are you still having an issue with this?
soundino 0 Posted January 24, 2021 Author Posted January 24, 2021 Seen and updated ...... But the problem remains .... "502 Bad Gateway" .....
Luke 42237 Posted January 24, 2021 Posted January 24, 2021 Did you customize the local emby server port to 8181? Or where does 8181 come from? The default emby server port is 8096.
soundino 0 Posted January 24, 2021 Author Posted January 24, 2021 No, I didn't customize it ..... The 8181 is the http port of the Terramaster NAS ... How can I change to point to port 8096 even if it doesn't start?
Luke 42237 Posted January 24, 2021 Posted January 24, 2021 1 hour ago, soundino said: No, I didn't customize it ..... The 8181 is the http port of the Terramaster NAS ... How can I change to point to port 8096 even if it doesn't start? Sounds like the whole Terramaster web interface is down for you then? Maybe this is a question for Terramaster?
gonzalonavarre 0 Posted February 13, 2021 Posted February 13, 2021 Tengo el mismo lio, y mi nas tiene solo 1 mes de comprado, tengo dudas no se que ocurre aunque funcionan las demas apps, como plex y otras cosas, emby dejo de funcionarme y me gusta pero no logro salir de este mismo problema lo tengo yo
Luke 42237 Posted February 13, 2021 Posted February 13, 2021 3 minutes ago, gonzalonavarre said: Tengo el mismo lio, y mi nas tiene solo 1 mes de comprado, tengo dudas no se que ocurre aunque funcionan las demas apps, como plex y otras cosas, emby dejo de funcionarme y me gusta pero no logro salir de este mismo problema lo tengo yo Hi, we will help you in your topic that you created. Thanks.
