Sammy 790 Posted December 30, 2020 Posted December 30, 2020 (edited) Error 522 Ray ID: 609e9f750927e50a • 2020-12-30 20:48:39 UTC Connection timed out You Browser Working Los Angeles Cloudflare Working myhostname.extension Host Error What happened? The initial connection between Cloudflare's network and the origin web server timed out. As a result, the web page can not be displayed. What can I do? If you're a visitor of this website: Please try again in a few minutes. If you're the owner of this website: Contact your hosting provider letting them know your web server is not completing requests. An Error 522 means that the request was able to connect to your web server, but that the request didn't finish. The most likely cause is that something on your server is hogging resources. Additional troubleshooting information here. embyserver.txt embyserver-63744935233.txt embyserver-63744911303.txt Edited December 30, 2020 by Sammy
Solution Carlo 4561 Posted December 31, 2020 Solution Posted December 31, 2020 Didn't look at the logs but check your WAN IP and make sure it's the same as the DNS record in Cloudflare. That's the number one cause of this not being able to talk to your server. If not let me know and I can jump on with you in TV and help you. 1
Sammy 790 Posted December 31, 2020 Author Posted December 31, 2020 That was it. We had an internet outage last night and my public IP address changed.
