ItangoII 0 Posted December 29, 2020 Posted December 29, 2020 Don't know any better way to put it. I'm migrating from one server to another. Both Freenas servers have different IPs and all apps/jails in those servers as well. I noticed extremely slow response from old server in trying to bring up shows and movies as well as stalling when trying to watch a show. I also noticed that doing an upgrade of the jail was slow. No network problems have been found but turning off Emby jail on new server brings back the old one to full life/speed. This would suggest a conflict of some kind, but cannot find anything in settings that suggest a conflict possible outside their respective jails/servers. Any thoughts? Thanks
Luke 42204 Posted December 29, 2020 Posted December 29, 2020 Hi there, can you please attach the emby server log from when this happened? Thanks.
ItangoII 0 Posted December 29, 2020 Author Posted December 29, 2020 56 minutes ago, Luke said: Hi there, can you please attach the emby server log from when this happened? Thanks. Thanks Luke Cleared logs on both, restarted both jails Started both servers. Went to smart tv and started Emby, selected series, selected show, Somewhat slow to that point. After selecting show it took some time. IPs .50 smart tv .15 my workstation .25 old Emby install .32 new install 2020-12-29 12:43:05.672 Info Main: Application path: /usr/local/lib/emby-server/system/EmbyServer.exe 2020-12-29 12:43:06.048 Info Main: Emby Command line: /usr/local/lib/emby-server/system/EmbyServer.exe -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server -updatepackage emby-server-freebsd12_{version}_amd64.txz Operating system: Unix 11.3.14.0 Framework: Mono: 6.8.0.96 (6.8.0.96 Thu May 21 13:31:54 UTC 2020) OS/Process: X64/X64 Runtime: usr/local/lib/mono/4.5/mscorlib.dll Processor count: 8 Data path: /var/db/emby-server Application path: /usr/local/lib/emby-server/system 2020-12-29 12:43:06.080 Info App: Application version: 4.5.4.0 2020-12-29 12:43:06.082 Info App: Loading assemblies 2020-12-29 12:43:06.096 Info App: File /var/db/emby-server/plugins/DvdMounter.dll has version 1.0.0.0 2020-12-29 12:43:06.096 Info App: File /usr/local/lib/emby-server/system/plugins/DvdMounter.dll has version 1.0.0.0 2020-12-29 12:43:06.096 Info App: File /var/db/emby-server/plugins/OMDb.dll has version 1.0.12.0 2020-12-29 12:43:06.096 Info App: File /usr/local/lib/emby-server/system/plugins/OMDb.dll has version 1.0.11.0 2020-12-29 12:43:06.096 Info App: File /var/db/emby-server/plugins/AudioDb.dll has version 1.0.11.0 2020-12-29 12:43:06.096 Info App: File /usr/local/lib/emby-server/system/plugins/AudioDb.dll has version 1.0.11.0 2020-12-29 12:43:06.097 Info App: File /var/db/emby-server/plugins/Emby.Server.CinemaMode.dll has version 1.0.35.0 2020-12-29 12:43:06.097 Info App: File /usr/local/lib/emby-server/system/plugins/Emby.Server.CinemaMode.dll has version 1.0.35.0 2020-12-29 12:43:06.097 Info App: File /var/db/emby-server/plugins/BlurayMounter.dll has version 1.0.0.0 2020-12-29 12:43:06.097 Info App: File /usr/local/lib/emby-server/system/plugins/BlurayMounter.dll has version 1.0.0.0 2020-12-29 12:43:06.097 Info App: File /var/db/emby-server/plugins/Emby.PortMapper.dll has version 1.0.4.0 2020-12-29 12:43:06.097 Info App: File /usr/local/lib/emby-server/system/plugins/Emby.PortMapper.dll has version 1.0.4.0 2020-12-29 12:43:06.097 Info App: File /var/db/emby-server/plugins/OpenSubtitles.dll has version 1.0.27.0 2020-12-29 12:43:06.097 Info App: File /usr/local/lib/emby-server/system/plugins/OpenSubtitles.dll has version 1.0.27.0 2020-12-29 12:43:06.097 Info App: File /var/db/emby-server/plugins/MovieDb.dll has version 1.3.8.0 2020-12-29 12:43:06.097 Info App: File /usr/local/lib/emby-server/system/plugins/MovieDb.dll has version 1.3.8.0 2020-12-29 12:43:06.097 Info App: File /var/db/emby-server/plugins/Emby.Webhooks.dll has version 1.0.14.0 2020-12-29 12:43:06.097 Info App: File /usr/local/lib/emby-server/system/plugins/Emby.Webhooks.dll has version 1.0.13.0 2020-12-29 12:43:06.097 Info App: File /var/db/emby-server/plugins/Tvdb.dll has version 1.0.36.0 2020-12-29 12:43:06.097 Info App: File /usr/local/lib/emby-server/system/plugins/Tvdb.dll has version 1.0.35.0 2020-12-29 12:43:06.097 Info App: File /var/db/emby-server/plugins/Emby.Dlna.dll has version 1.0.39.0 2020-12-29 12:43:06.098 Info App: File /usr/local/lib/emby-server/system/plugins/Emby.Dlna.dll has version 1.0.39.0 2020-12-29 12:43:06.098 Info App: File /var/db/emby-server/plugins/NfoMetadata.dll has version 1.0.34.0 2020-12-29 12:43:06.098 Info App: File /usr/local/lib/emby-server/system/plugins/NfoMetadata.dll has version 1.0.34.0 2020-12-29 12:43:06.098 Info App: File /var/db/emby-server/plugins/MusicBrainz.dll has version 1.0.13.0 2020-12-29 12:43:06.098 Info App: File /usr/local/lib/emby-server/system/plugins/MusicBrainz.dll has version 1.0.13.0 2020-12-29 12:43:06.098 Info App: File /var/db/emby-server/plugins/Fanart.dll has version 1.0.10.0 2020-12-29 12:43:06.098 Info App: File /usr/local/lib/emby-server/system/plugins/Fanart.dll has version 1.0.10.0 2020-12-29 12:43:06.098 Info App: File /var/db/emby-server/plugins/StudioImages.dll has version 1.0.3.0 2020-12-29 12:43:06.098 Info App: File /usr/local/lib/emby-server/system/plugins/StudioImages.dll has version 1.0.3.0 2020-12-29 12:43:06.109 Info App: Loading MovieDb, Version=1.3.8.0, Culture=neutral, PublicKeyToken=null from /var/db/emby-server/plugins/MovieDb.dll 2020-12-29 12:43:06.109 Info App: Loading OMDb, Version=1.0.12.0, Culture=neutral, PublicKeyToken=null from /var/db/emby-server/plugins/OMDb.dll 2020-12-29 12:43:06.109 Info App: Loading Emby.Dlna, Version=1.0.39.0, Culture=neutral, PublicKeyToken=null from /var/db/emby-server/plugins/Emby.Dlna.dll 2020-12-29 12:43:06.109 Info App: Loading DvdMounter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null from /var/db/emby-server/plugins/DvdMounter.dll 2020-12-29 12:43:06.110 Info App: Loading BlurayMounter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null from /var/db/emby-server/plugins/BlurayMounter.dll 2020-12-29 12:43:06.110 Info App: Loading Emby.PortMapper, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null from /var/db/emby-server/plugins/Emby.PortMapper.dll 2020-12-29 12:43:06.110 Info App: Loading StudioImages, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null from /var/db/emby-server/plugins/StudioImages.dll 2020-12-29 12:43:06.110 Info App: Loading OpenSubtitles, Version=1.0.27.0, Culture=neutral, PublicKeyToken=null from /var/db/emby-server/plugins/OpenSubtitles.dll 2020-12-29 12:43:06.110 Info App: Loading Fanart, Version=1.0.10.0, Culture=neutral, PublicKeyToken=null from /var/db/emby-server/plugins/Fanart.dll 2020-12-29 12:43:06.110 Info App: Loading Emby.Server.CinemaMode, Version=1.0.35.0, Culture=neutral, PublicKeyToken=null from /var/db/emby-server/plugins/Emby.Server.CinemaMode.dll 2020-12-29 12:43:06.110 Info App: Loading AudioDb, Version=1.0.11.0, Culture=neutral, PublicKeyToken=null from /var/db/emby-server/plugins/AudioDb.dll 2020-12-29 12:43:06.110 Info App: Loading Tvdb, Version=1.0.36.0, Culture=neutral, PublicKeyToken=null from /var/db/emby-server/plugins/Tvdb.dll 2020-12-29 12:43:06.110 Info App: Loading Emby.Webhooks, Version=1.0.14.0, Culture=neutral, PublicKeyToken=null from /var/db/emby-server/plugins/Emby.Webhooks.dll 2020-12-29 12:43:06.110 Info App: Loading NfoMetadata, Version=1.0.34.0, Culture=neutral, PublicKeyToken=null from /var/db/emby-server/plugins/NfoMetadata.dll 2020-12-29 12:43:06.110 Info App: Loading MusicBrainz, Version=1.0.13.0, Culture=neutral, PublicKeyToken=null from /var/db/emby-server/plugins/MusicBrainz.dll 2020-12-29 12:43:06.110 Info App: Loading Emby.Api, Version=4.5.4.0, Culture=neutral, PublicKeyToken=null 2020-12-29 12:43:06.110 Info App: Loading Emby.Web, Version=4.5.4.0, Culture=neutral, PublicKeyToken=null 2020-12-29 12:43:06.110 Info App: Loading MediaBrowser.Model, Version=4.5.4.0, Culture=neutral, PublicKeyToken=null 2020-12-29 12:43:06.110 Info App: Loading MediaBrowser.Common, Version=4.5.4.0, Culture=neutral, PublicKeyToken=null 2020-12-29 12:43:06.110 Info App: Loading MediaBrowser.Controller, Version=4.5.4.0, Culture=neutral, PublicKeyToken=null 2020-12-29 12:43:06.110 Info App: Loading Emby.Providers, Version=4.5.4.0, Culture=neutral, PublicKeyToken=null 2020-12-29 12:43:06.110 Info App: Loading Emby.Photos, Version=4.5.4.0, Culture=neutral, PublicKeyToken=null 2020-12-29 12:43:06.110 Info App: Loading Emby.Server.Implementations, Version=4.5.4.0, Culture=neutral, PublicKeyToken=null 2020-12-29 12:43:06.110 Info App: Loading Emby.LiveTV, Version=4.5.4.0, Culture=neutral, PublicKeyToken=null 2020-12-29 12:43:06.110 Info App: Loading Emby.ActivityLog, Version=4.5.4.0, Culture=neutral, PublicKeyToken=null 2020-12-29 12:43:06.110 Info App: Loading Emby.Server.MediaEncoding, Version=4.5.4.0, Culture=neutral, PublicKeyToken=null 2020-12-29 12:43:06.110 Info App: Loading Emby.LocalMetadata, Version=4.5.4.0, Culture=neutral, PublicKeyToken=null 2020-12-29 12:43:06.110 Info App: Loading Emby.Notifications, Version=4.5.4.0, Culture=neutral, PublicKeyToken=null 2020-12-29 12:43:06.110 Info App: Loading Emby.Codecs, Version=4.5.4.0, Culture=neutral, PublicKeyToken=null 2020-12-29 12:43:06.110 Info App: Loading Emby.Server.Connect, Version=4.5.4.0, Culture=neutral, PublicKeyToken=null 2020-12-29 12:43:06.110 Info App: Loading Emby.Server.Sync, Version=4.5.4.0, Culture=neutral, PublicKeyToken=null 2020-12-29 12:43:06.110 Info App: Loading EmbyServer, Version=4.5.4.0, Culture=neutral, PublicKeyToken=null 2020-12-29 12:43:06.207 Info SqliteUserRepository: Sqlite version: 3.34.0 2020-12-29 12:43:06.208 Info SqliteUserRepository: Sqlite compiler options: COMPILER=clang-10.0.0,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS4,ENABLE_FTS5,ENABLE_GEOPOLY,ENABLE_JSON1,ENABLE_RTREE,ENABLE_UNLOCK_NOTIFY,HAVE_ISNAN,SECURE_DELETE,TEMP_STORE=1,THREADSAFE=1,USE_URI 2020-12-29 12:43:06.220 Info SqliteUserRepository: Default journal_mode for /var/db/emby-server/data/users.db is wal 2020-12-29 12:43:06.272 Info AuthenticationRepository: Default journal_mode for /var/db/emby-server/data/authentication.db is wal 2020-12-29 12:43:06.307 Info ActivityRepository: Default journal_mode for /var/db/emby-server/data/activitylog.db is wal 2020-12-29 12:43:06.309 Info SqliteDisplayPreferencesRepository: Default journal_mode for /var/db/emby-server/data/displaypreferences.db is wal 2020-12-29 12:43:06.316 Info App: Adding HttpListener prefix http://+:8096/ 2020-12-29 12:43:06.429 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/users/ae310e0fec754ead8c8413546c4e7633/policy.xml 2020-12-29 12:43:06.451 Info SqliteItemRepository: Default journal_mode for /var/db/emby-server/data/library.db is wal 2020-12-29 12:43:06.705 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/encoding.xml 2020-12-29 12:43:07.309 Info ImageMagick: ImageMagick version: ImageMagick 6.9.11-6 Q16 amd64 2020-12-27 https://imagemagick.org 2020-12-29 12:43:07.354 Info TaskManager: Daily trigger for Thumbnail image extraction set to fire at 12/30/2020 02:00:00, which is 796.877452666667 minutes from now. 2020-12-29 12:43:07.365 Info TaskManager: Daily trigger for Rotate log file set to fire at 12/30/2020 00:00:00, which is 676.8772396 minutes from now. 2020-12-29 12:43:07.366 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/livetv.xml 2020-12-29 12:43:07.372 Info App: ServerId: 8a4d5edcaaed41ea837e10a61b66243d 2020-12-29 12:43:07.406 Info App: Starting entry point Emby.Dlna.Main.DlnaEntryPoint 2020-12-29 12:43:07.415 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/dlna/system/Sony PlayStation 4.xml 2020-12-29 12:43:07.452 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/dlna/system/Sony PlayStation 3.xml 2020-12-29 12:43:07.453 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/dlna/system/Sony Bravia (2014).xml 2020-12-29 12:43:07.454 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/dlna/system/Sony Blu-ray Player 2016.xml 2020-12-29 12:43:07.454 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/dlna/system/Linksys DMA2100.xml 2020-12-29 12:43:07.454 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/dlna/system/Dish Hopper-Joey.xml 2020-12-29 12:43:07.455 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/dlna/system/Sony Bravia (2010).xml 2020-12-29 12:43:07.455 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/dlna/system/Sony Blu-ray Player.xml 2020-12-29 12:43:07.455 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/dlna/system/Xbox One.xml 2020-12-29 12:43:07.456 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/dlna/system/Samsung Smart TV.xml 2020-12-29 12:43:07.456 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/dlna/system/Marantz.xml 2020-12-29 12:43:07.456 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/dlna/system/Sony Bravia (2011).xml 2020-12-29 12:43:07.457 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/dlna/system/Sharp Smart TV.xml 2020-12-29 12:43:07.457 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/dlna/system/DirecTV HD-DVR.xml 2020-12-29 12:43:07.457 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/dlna/system/Panasonic Viera.xml 2020-12-29 12:43:07.457 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/dlna/system/Denon AVR.xml 2020-12-29 12:43:07.458 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/dlna/system/Sony Blu-ray Player 2013.xml 2020-12-29 12:43:07.458 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/dlna/system/Sony Blu-ray Player 2014.xml 2020-12-29 12:43:07.458 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/dlna/system/Sony Bravia (2013).xml 2020-12-29 12:43:07.459 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/dlna/system/Sony Bravia (2012).xml 2020-12-29 12:43:07.459 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/dlna/system/Default.xml 2020-12-29 12:43:07.459 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/dlna/system/WDTV Live.xml 2020-12-29 12:43:07.459 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/dlna/system/Sony Blu-ray Player 2015.xml 2020-12-29 12:43:07.460 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/dlna/system/LG Smart TV.xml 2020-12-29 12:43:07.461 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/dlna.xml 2020-12-29 12:43:07.466 Info Dlna: Registering publisher for urn:schemas-upnp-org:device:MediaServer:1 2020-12-29 12:43:07.531 Info App: Entry point completed: Emby.Dlna.Main.DlnaEntryPoint. Duration: 0.124614 seconds 2020-12-29 12:43:07.531 Info App: Starting entry point Emby.Server.Connect.ConnectEntryPoint 2020-12-29 12:43:07.532 Info App: Loading data from /var/db/emby-server/data/connect.txt 2020-12-29 12:43:07.533 Info App: Loading data from /var/db/emby-server/data/wan.dat 2020-12-29 12:43:07.538 Info App: Entry point completed: Emby.Server.Connect.ConnectEntryPoint. Duration: 0.006877 seconds 2020-12-29 12:43:07.538 Info App: Core startup complete 2020-12-29 12:43:07.538 Info App: Post-init migrations complete 2020-12-29 12:43:07.538 Info App: Starting entry point Emby.PortMapper.ExternalPortForwarding 2020-12-29 12:43:07.539 Info App: Entry point completed: Emby.PortMapper.ExternalPortForwarding. Duration: 0.000752 seconds 2020-12-29 12:43:07.539 Info App: Starting entry point Emby.Security.PluginSecurityManager 2020-12-29 12:43:07.539 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 2.8E-05 seconds 2020-12-29 12:43:07.539 Info App: Starting entry point Emby.Server.CinemaMode.IntrosEntryPoint 2020-12-29 12:43:07.539 Info App: Entry point completed: Emby.Server.CinemaMode.IntrosEntryPoint. Duration: 8.1E-05 seconds 2020-12-29 12:43:07.539 Info App: Starting entry point Emby.Webhooks.WebhooksEntryPoint 2020-12-29 12:43:07.540 Info App: Entry point completed: Emby.Webhooks.WebhooksEntryPoint. Duration: 0.001191 seconds 2020-12-29 12:43:07.540 Info App: Starting entry point NfoMetadata.EntryPoint 2020-12-29 12:43:07.540 Info App: Entry point completed: NfoMetadata.EntryPoint. Duration: 6.9E-05 seconds 2020-12-29 12:43:07.540 Info App: Starting entry point MediaBrowser.Api.ApiEntryPoint 2020-12-29 12:43:07.541 Info App: Entry point completed: MediaBrowser.Api.ApiEntryPoint. Duration: 2.6E-05 seconds 2020-12-29 12:43:07.541 Info App: Starting entry point Emby.Server.Implementations.Udp.UdpServerEntryPoint 2020-12-29 12:43:07.542 Info App: Entry point completed: Emby.Server.Implementations.Udp.UdpServerEntryPoint. Duration: 0.001617 seconds 2020-12-29 12:43:07.542 Info App: Starting entry point Emby.Server.Implementations.Playlists.PlaylistsEntryPoint 2020-12-29 12:43:07.544 Info App: Entry point completed: Emby.Server.Implementations.Playlists.PlaylistsEntryPoint. Duration: 0.001292 seconds 2020-12-29 12:43:07.544 Info App: Starting entry point Emby.Server.Implementations.News.NewsEntryPoint 2020-12-29 12:43:07.544 Info App: Entry point completed: Emby.Server.Implementations.News.NewsEntryPoint. Duration: 0.000142 seconds 2020-12-29 12:43:07.544 Info App: Starting entry point Emby.Server.Implementations.Library.DeviceAccessEntryPoint 2020-12-29 12:43:07.544 Info App: Entry point completed: Emby.Server.Implementations.Library.DeviceAccessEntryPoint. Duration: 0.000412 seconds 2020-12-29 12:43:07.544 Info App: Starting entry point Emby.Server.Implementations.IO.LibraryMonitorStartup 2020-12-29 12:43:07.709 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/Movies/options.xml 2020-12-29 12:43:07.719 Debug App: Ping test result to http://192.168.0.25:8096/system/ping. Success: True 2020-12-29 12:43:07.720 Debug App: CreateUdpMulticastSocket 239.255.255.250:1900 2020-12-29 12:43:07.721 Debug App: CreateSsdpUdpSocket 0.0.0.0:1900 2020-12-29 12:43:07.722 Info App: Init BeginReceive on 0.0.0.0 2020-12-29 12:43:07.732 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/Music/options.xml 2020-12-29 12:43:07.733 Debug XmlSerializer: Deserializing file /var/db/emby-server/root/default/TV shows/options.xml 2020-12-29 12:43:07.734 Info App: Entry point completed: Emby.Server.Implementations.IO.LibraryMonitorStartup. Duration: 0.189547 seconds 2020-12-29 12:43:07.734 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint 2020-12-29 12:43:07.734 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint. Duration: 0.000183 seconds 2020-12-29 12:43:07.734 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.KeepServerAwake 2020-12-29 12:43:07.734 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.KeepServerAwake. Duration: 0.000135 seconds 2020-12-29 12:43:07.734 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier 2020-12-29 12:43:07.735 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier. Duration: 0.000628 seconds 2020-12-29 12:43:07.735 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ServerEventNotifier 2020-12-29 12:43:07.736 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ServerEventNotifier. Duration: 0.000895 seconds 2020-12-29 12:43:07.736 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.StartupWizard 2020-12-29 12:43:07.736 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.StartupWizard. Duration: 0.000203 seconds 2020-12-29 12:43:07.736 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.SystemEvents 2020-12-29 12:43:07.736 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.SystemEvents. Duration: 0.000133 seconds 2020-12-29 12:43:07.736 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier 2020-12-29 12:43:07.736 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier. Duration: 6.2E-05 seconds 2020-12-29 12:43:07.736 Info App: Starting entry point Emby.Server.Implementations.Channels.ChannelsEntryPoint 2020-12-29 12:43:07.738 Info App: Entry point completed: Emby.Server.Implementations.Channels.ChannelsEntryPoint. Duration: 0.001427 seconds 2020-12-29 12:43:07.738 Info App: Starting entry point Emby.LiveTV.EntryPoint 2020-12-29 12:43:07.740 Info LiveTV: Loading live tv data from /var/db/emby-server/data/livetv/timers 2020-12-29 12:43:07.749 Info App: Entry point completed: Emby.LiveTV.EntryPoint. Duration: 0.011338 seconds 2020-12-29 12:43:07.749 Info App: Starting entry point Emby.LiveTV.LiveTVEntryPoint 2020-12-29 12:43:07.749 Info App: Entry point completed: Emby.LiveTV.LiveTVEntryPoint. Duration: 0.000108 seconds 2020-12-29 12:43:07.749 Info App: Starting entry point Emby.LiveTV.RecordingNotifier 2020-12-29 12:43:07.750 Info App: Entry point completed: Emby.LiveTV.RecordingNotifier. Duration: 0.000721 seconds 2020-12-29 12:43:07.750 Info App: Starting entry point Emby.ActivityLog.ActivityLogEntryPoint 2020-12-29 12:43:07.751 Info App: Entry point completed: Emby.ActivityLog.ActivityLogEntryPoint. Duration: 0.001218 seconds 2020-12-29 12:43:07.751 Info App: Starting entry point Emby.Server.MediaEncoding.Api.EncodingManagerEntryPoint 2020-12-29 12:43:07.752 Info App: Entry point completed: Emby.Server.MediaEncoding.Api.EncodingManagerEntryPoint. Duration: 0.001057 seconds 2020-12-29 12:43:07.752 Info App: Starting entry point Emby.Notifications.Notifications 2020-12-29 12:43:07.753 Info App: Entry point completed: Emby.Notifications.Notifications. Duration: 0.000151 seconds 2020-12-29 12:43:07.753 Info App: Starting entry point Emby.Server.Sync.SyncManagerEntryPoint 2020-12-29 12:43:07.756 Info App: SyncRepository Initialize taking write lock 2020-12-29 12:43:07.756 Info App: SyncRepository Initialize write lock taken 2020-12-29 12:43:07.757 Info App: Entry point completed: Emby.Server.Sync.SyncManagerEntryPoint. Duration: 0.003947 seconds 2020-12-29 12:43:07.757 Info App: Starting entry point Emby.Server.Sync.SyncNotificationEntryPoint 2020-12-29 12:43:07.757 Info App: Entry point completed: Emby.Server.Sync.SyncNotificationEntryPoint. Duration: 0.000621 seconds 2020-12-29 12:43:07.757 Info App: All entry points have started 2020-12-29 12:43:08.051 Info HttpClient: HttpClientManager GET: https://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog 2020-12-29 12:43:08.903 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/System/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:43:09.024 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 123ms. http://192.168.0.25:8096/emby/System/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:43:09.026 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:43:09.032 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/users/ae310e0fec754ead8c8413546c4e7633/config.xml 2020-12-29 12:43:09.086 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 60ms. http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:43:09.094 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:43:09.131 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 37ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:43:10.363 Debug TaskManager: StartupTrigger fired for task: Check for plugin updates 2020-12-29 12:43:10.364 Debug TaskManager: Queueing task PluginUpdateTask 2020-12-29 12:43:10.364 Debug TaskManager: StartupTrigger fired for task: Check for application updates 2020-12-29 12:43:10.364 Debug TaskManager: Queueing task SystemUpdateTask 2020-12-29 12:43:10.367 Debug TaskManager: Executing Check for plugin updates 2020-12-29 12:43:10.367 Debug TaskManager: Executing Check for application updates 2020-12-29 12:43:10.370 Debug TaskManager: StartupTrigger fired for task: Hardware Detection 2020-12-29 12:43:10.370 Debug TaskManager: Queueing task HardwareDetectionScheduledTask 2020-12-29 12:43:10.370 Debug TaskManager: Executing Hardware Detection 2020-12-29 12:43:10.370 Info HttpClient: HttpClientManager GET: https://www.mb3admin.com/admin/service/EmbyPackages.json 2020-12-29 12:43:10.371 Info FfmpegManager: FFMpeg: /usr/local/lib/emby-server/bin/ffmpeg 2020-12-29 12:43:10.371 Info FfmpegManager: FFProbe: /usr/local/lib/emby-server/bin/ffprobe 2020-12-29 12:43:10.371 Info FfmpegManager: FFDetect: /usr/local/lib/emby-server/bin/ffdetect 2020-12-29 12:43:10.379 Info FfmpegManager: ProcessRun 'ffmpeg -hide_banner -version' Execute: /usr/local/lib/emby-server/bin/ffmpeg -hide_banner -version 2020-12-29 12:43:10.400 Debug FfmpegManager: ProcessRun 'ffmpeg -hide_banner -version' Started. 2020-12-29 12:43:10.485 Info FfmpegManager: ProcessRun 'ffmpeg -hide_banner -version' Process exited with code 0 2020-12-29 12:43:10.494 Debug SoftwareCodecProvider: Start GetCodecList() 2020-12-29 12:43:10.509 Debug App: No application update available. 2020-12-29 12:43:10.509 Debug TaskManager: Check for application updates Completed after 0 minute(s) and 0 seconds 2020-12-29 12:43:10.564 Info SoftwareCodecProvider: h264, libx264, libx264 Software Encoder, V-E-libx264 2020-12-29 12:43:10.564 Info SoftwareCodecProvider: hevc, libx265, libx265 Software Encoder, V-E-libx265 2020-12-29 12:43:10.564 Info SoftwareCodecProvider: mpeg4, mpeg4, MPEG-4 part 2 Software Encoder, V-E-mpeg4 2020-12-29 12:43:10.564 Info SoftwareCodecProvider: msmpeg4v3, msmpeg4, MPEG-4 part 2 (MS Variant 3) Software Encoder, V-E-msmpeg4 2020-12-29 12:43:10.564 Info SoftwareCodecProvider: vp8, libvpx, libvpx VP8, V-E-libvpx 2020-12-29 12:43:10.566 Debug SoftwareCodecProvider: End GetCodecList() 2020-12-29 12:43:10.566 Debug SoftwareCodecProvider: Start GetCodecList() 2020-12-29 12:43:10.567 Info SoftwareCodecProvider: h264, libx264, libx264 Software Encoder, V-E-libx264 2020-12-29 12:43:10.567 Info SoftwareCodecProvider: hevc, libx265, libx265 Software Encoder, V-E-libx265 2020-12-29 12:43:10.567 Info SoftwareCodecProvider: mpeg4, mpeg4, MPEG-4 part 2 Software Encoder, V-E-mpeg4 2020-12-29 12:43:10.567 Info SoftwareCodecProvider: msmpeg4v3, msmpeg4, MPEG-4 part 2 (MS Variant 3) Software Encoder, V-E-msmpeg4 2020-12-29 12:43:10.567 Info SoftwareCodecProvider: vp8, libvpx, libvpx VP8, V-E-libvpx 2020-12-29 12:43:10.568 Debug SoftwareCodecProvider: End GetCodecList() 2020-12-29 12:43:10.570 Debug VaapiCodecProvider: Start GetCodecList() 2020-12-29 12:43:10.572 Info VaapiCodecProvider: ProcessRun 'ffdetect_vaencdec' Execute: /usr/local/lib/emby-server/bin/ffdetect -hide_banner -show_program_version -loglevel 48 -show_error -show_log 40 vaencdec -print_format json 2020-12-29 12:43:10.577 Debug VaapiCodecProvider: ProcessRun 'ffdetect_vaencdec' Started. 2020-12-29 12:43:10.693 Info VaapiCodecProvider: ProcessRun 'ffdetect_vaencdec' Process exited with code 1 2020-12-29 12:43:10.745 Error VaapiCodecProvider: Error running ffdetect for vaencdec - /usr/local/lib/emby-server/bin/ffdetect: Undefined symbol "alphasort@FBSD_1.5" 2020-12-29 12:43:10.746 Error VaapiCodecProvider: ProcessRun 'ffdetect_vaencdec' Output: 2020-12-29 12:43:10.746 Error VaapiCodecProvider: ProcessRun 'ffdetect_vaencdec' Error Output: /usr/local/lib/emby-server/bin/ffdetect: Undefined symbol "alphasort@FBSD_1.5" 2020-12-29 12:43:10.746 Debug VaapiCodecProvider: End GetCodecList() 2020-12-29 12:43:11.034 Debug TaskManager: Hardware Detection Completed after 0 minute(s) and 0 seconds 2020-12-29 12:43:12.724 Debug App: Begin Sending Alive Notifications For All Devices 2020-12-29 12:43:12.725 Debug App: Sending alive notification MediaServer - 8a4d5edcaaed41ea837e10a61b66243d 2020-12-29 12:43:12.946 Debug Dlna: Attempting to create PlayToController from location http://192.168.0.50:9197/dmr 2020-12-29 12:43:12.946 Debug Dlna: Logging session activity from location http://192.168.0.50:9197/dmr 2020-12-29 12:43:12.953 Debug HttpClient: HttpClientManager GET: http://192.168.0.50:9197/dmr 2020-12-29 12:43:12.976 Debug Dlna: Dlna Device.Start 2020-12-29 12:43:12.980 Debug Dlna: Found matching device profile: Samsung Smart TV 2020-12-29 12:43:13.013 Info Dlna: DLNA Session created for [TV] Bedroom tv - UN43MU630D 2020-12-29 12:43:13.034 Debug App: Sending alive notification MediaServer - 8a4d5edcaaed41ea837e10a61b66243d 2020-12-29 12:43:13.338 Debug App: Sending alive notification MediaServer - 8a4d5edcaaed41ea837e10a61b66243d 2020-12-29 12:43:13.641 Debug App: Sending alive notification ContentDirectory - 8a4d5edcaaed41ea837e10a61b66243d 2020-12-29 12:43:13.945 Debug App: Sending alive notification ContentDirectory - 8a4d5edcaaed41ea837e10a61b66243d 2020-12-29 12:43:13.979 Debug HttpClient: HttpClientManager GET: http://192.168.0.50:9197/AVTransport_1.xml 2020-12-29 12:43:14.251 Debug App: Sending alive notification ConnectionManager - 8a4d5edcaaed41ea837e10a61b66243d 2020-12-29 12:43:14.554 Debug App: Sending alive notification ConnectionManager - 8a4d5edcaaed41ea837e10a61b66243d 2020-12-29 12:43:14.860 Debug App: Completed Sending Alive Notifications For All Devices 2020-12-29 12:43:15.740 Debug Server: http/1.1 GET http://192.168.0.25:8096/dlna/8a4d5edcaaed41ea837e10a61b66243d/description.xml. UserAgent: DLNADOC/1.50 SEC_HHP_[TV] Bedroom tv/1.0 UPnP/1.0 2020-12-29 12:43:15.743 Debug Dlna: Found matching device profile: Samsung Smart TV 2020-12-29 12:43:15.756 Debug Server: http/1.1 Response 200 to 192.168.0.50. Time: 16ms. http://192.168.0.25:8096/dlna/8a4d5edcaaed41ea837e10a61b66243d/description.xml 2020-12-29 12:43:15.768 Debug Server: http/1.1 GET http://192.168.0.25:8096/dlna/8a4d5edcaaed41ea837e10a61b66243d/connectionmanager/connectionmanager.xml. UserAgent: DLNADOC/1.50 SEC_HHP_[TV] Bedroom tv/1.0 UPnP/1.0 2020-12-29 12:43:15.768 Debug Server: http/1.1 GET http://192.168.0.25:8096/dlna/8a4d5edcaaed41ea837e10a61b66243d/contentdirectory/contentdirectory.xml. UserAgent: DLNADOC/1.50 SEC_HHP_[TV] Bedroom tv/1.0 UPnP/1.0 2020-12-29 12:43:15.774 Debug Server: http/1.1 Response 200 to 192.168.0.50. Time: 5ms. http://192.168.0.25:8096/dlna/8a4d5edcaaed41ea837e10a61b66243d/connectionmanager/connectionmanager.xml 2020-12-29 12:43:15.774 Debug Server: http/1.1 Response 200 to 192.168.0.50. Time: 6ms. http://192.168.0.25:8096/dlna/8a4d5edcaaed41ea837e10a61b66243d/contentdirectory/contentdirectory.xml 2020-12-29 12:43:15.789 Debug Server: http/1.1 GET http://192.168.0.25:8096/dlna/8a4d5edcaaed41ea837e10a61b66243d/icons/logo120.png. UserAgent: 2020-12-29 12:43:15.790 Debug Server: http/1.1 Response 200 to 192.168.0.50. Time: 2ms. http://192.168.0.25:8096/dlna/8a4d5edcaaed41ea837e10a61b66243d/icons/logo120.png 2020-12-29 12:43:25.540 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:43:25.542 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:43:25.893 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:43:25.894 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:43:27.147 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio,BasicSyncInfo,ProductionYear,CanDelete&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&EnableTotalRecordCount=false&MediaTypes=Video&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:43:27.149 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio,BasicSyncInfo,ProductionYear,CanDelete&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&EnableTotalRecordCount=false&MediaTypes=Audio&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:43:27.151 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio,SeriesInfo,DateCreated,BasicSyncInfo,CanDelete&UserId=ae310e0fec754ead8c8413546c4e7633&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Banner,Thumb&EnableTotalRecordCount=false&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:43:27.153 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio,BasicSyncInfo,ProductionYear,Status,EndDate,CanDelete&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:43:27.156 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio,BasicSyncInfo,ProductionYear,Status,EndDate,CanDelete&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&ParentId=6c2a057148b4d7c20a207c789aba6d07&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:43:27.159 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Latest?Limit=30&Fields=PrimaryImageAspectRatio,BasicSyncInfo,ProductionYear,Status,EndDate,CanDelete&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&ParentId=7e64e319657a9516ec78490da03edccb&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:43:27.370 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 221ms. http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio,BasicSyncInfo,ProductionYear,CanDelete&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&EnableTotalRecordCount=false&MediaTypes=Audio&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:43:27.385 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 237ms. http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio,BasicSyncInfo,ProductionYear,CanDelete&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&EnableTotalRecordCount=false&MediaTypes=Video&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:43:27.385 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 229ms. http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio,BasicSyncInfo,ProductionYear,Status,EndDate,CanDelete&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&ParentId=6c2a057148b4d7c20a207c789aba6d07&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:43:27.385 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 233ms. http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio,BasicSyncInfo,ProductionYear,Status,EndDate,CanDelete&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:43:27.391 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 233ms. http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Latest?Limit=30&Fields=PrimaryImageAspectRatio,BasicSyncInfo,ProductionYear,Status,EndDate,CanDelete&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&ParentId=7e64e319657a9516ec78490da03edccb&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:43:27.404 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 253ms. http://192.168.0.25:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio,SeriesInfo,DateCreated,BasicSyncInfo,CanDelete&UserId=ae310e0fec754ead8c8413546c4e7633&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Banner,Thumb&EnableTotalRecordCount=false&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:43:46.353 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:43:46.355 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:43:46.358 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:43:46.359 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:43:55.896 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:43:55.897 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:44:18.216 Debug TaskManager: Check for plugin updates Completed after 1 minute(s) and 7 seconds 2020-12-29 12:44:35.907 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:44:35.908 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:44:35.911 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:44:35.912 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:44:35.912 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:44:35.912 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:44:45.254 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:44:45.255 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:44:45.896 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:44:45.897 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:44:55.906 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:44:55.907 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:45:15.230 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:45:15.230 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:45:55.253 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:45:55.254 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:45:55.905 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:45:55.906 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:46:15.909 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:46:15.910 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:46:34.203 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:46:34.204 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:46:34.207 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:46:34.208 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:46:35.887 Warn App: Unable to respond to udp request because the local ip address could not be determined. 2020-12-29 12:46:35.899 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:46:35.899 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:46:51.922 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/system/info/public. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:46:51.942 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 20ms. http://192.168.0.25:8096/emby/system/info/public 2020-12-29 12:46:51.964 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/web/manifest.json. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:46:51.964 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/web/strings/en-US.json. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:46:51.976 Info Server: http/1.1 Response 304 to 192.168.0.50. Time: 12ms. http://192.168.0.25:8096/emby/web/strings/en-US.json 2020-12-29 12:46:51.976 Info Server: http/1.1 Response 304 to 192.168.0.50. Time: 12ms. http://192.168.0.25:8096/emby/web/manifest.json 2020-12-29 12:46:51.997 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/System/Info. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:46:52.018 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 21ms. http://192.168.0.25:8096/emby/System/Info 2020-12-29 12:46:52.051 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/DisplayPreferences/usersettings?userId=ae310e0fec754ead8c8413546c4e7633&client=emby&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:46:52.053 Info HttpServer: WS http://192.168.0.25:8096/embywebsocket?api_key=cf36cbfdc3fa48ebb27c581f659db39e&deviceId=9cd0a87e-a7e0-4805-9fbc-af27742783f9. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:46:52.065 Debug SessionManager: Creating new WebSocketController 2020-12-29 12:46:52.075 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 24ms. http://192.168.0.25:8096/emby/DisplayPreferences/usersettings?userId=ae310e0fec754ead8c8413546c4e7633&client=emby&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:46:52.085 Info Server: http/1.1 POST http://192.168.0.25:8096/emby/Sessions/Capabilities/Full?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:46:52.095 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:46:52.096 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 1ms. http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:46:52.108 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:46:52.109 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 1ms. http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:46:52.160 Info Server: http/1.1 Response 204 to 192.168.0.50. Time: 75ms. http://192.168.0.25:8096/emby/Sessions/Capabilities/Full?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:46:52.238 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Resume?Limit=3&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:46:52.452 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/LiveTv/Channels?userId=ae310e0fec754ead8c8413546c4e7633&limit=1&ImageTypeLimit=1&EnableTotalRecordCount=false&EnableImages=false&EnableUserData=false&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:46:52.455 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Views?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:46:52.482 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 27ms. http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Views?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:46:52.590 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 351ms. http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Resume?Limit=3&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:46:52.597 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 146ms. http://192.168.0.25:8096/emby/LiveTv/Channels?userId=ae310e0fec754ead8c8413546c4e7633&limit=1&ImageTypeLimit=1&EnableTotalRecordCount=false&EnableImages=false&EnableUserData=false&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:46:52.608 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Shows/NextUp?Limit=3&Fields=PrimaryImageAspectRatio&ImageTypeLimit=1&UserId=ae310e0fec754ead8c8413546c4e7633&EnableTotalRecordCount=false&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:46:52.615 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio,BasicSyncInfo,ProductionYear,CanDelete&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&EnableTotalRecordCount=false&MediaTypes=Video&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:46:52.617 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio,BasicSyncInfo,ProductionYear,CanDelete&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&EnableTotalRecordCount=false&MediaTypes=Audio&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:46:52.623 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio,SeriesInfo,DateCreated,BasicSyncInfo,CanDelete&UserId=ae310e0fec754ead8c8413546c4e7633&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Banner,Thumb&EnableTotalRecordCount=false&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:46:52.623 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio,BasicSyncInfo,ProductionYear,Status,EndDate,CanDelete&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:46:52.623 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio,BasicSyncInfo,ProductionYear,Status,EndDate,CanDelete&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&ParentId=6c2a057148b4d7c20a207c789aba6d07&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:46:52.628 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 13ms. http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio,BasicSyncInfo,ProductionYear,CanDelete&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&EnableTotalRecordCount=false&MediaTypes=Video&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:46:52.633 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Latest?Limit=30&Fields=PrimaryImageAspectRatio,BasicSyncInfo,ProductionYear,Status,EndDate,CanDelete&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&ParentId=7e64e319657a9516ec78490da03edccb&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:46:52.650 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 33ms. http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Resume?Limit=12&Recursive=true&Fields=PrimaryImageAspectRatio,BasicSyncInfo,ProductionYear,CanDelete&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&EnableTotalRecordCount=false&MediaTypes=Audio&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:46:52.667 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 44ms. http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio,BasicSyncInfo,ProductionYear,Status,EndDate,CanDelete&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:46:52.729 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 106ms. http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Latest?Limit=16&Fields=PrimaryImageAspectRatio,BasicSyncInfo,ProductionYear,Status,EndDate,CanDelete&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&ParentId=6c2a057148b4d7c20a207c789aba6d07&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:46:52.775 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 142ms. http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Latest?Limit=30&Fields=PrimaryImageAspectRatio,BasicSyncInfo,ProductionYear,Status,EndDate,CanDelete&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&ParentId=7e64e319657a9516ec78490da03edccb&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:46:52.809 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 201ms. http://192.168.0.25:8096/emby/Shows/NextUp?Limit=3&Fields=PrimaryImageAspectRatio&ImageTypeLimit=1&UserId=ae310e0fec754ead8c8413546c4e7633&EnableTotalRecordCount=false&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:46:52.814 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 191ms. http://192.168.0.25:8096/emby/Shows/NextUp?Limit=24&Fields=PrimaryImageAspectRatio,SeriesInfo,DateCreated,BasicSyncInfo,CanDelete&UserId=ae310e0fec754ead8c8413546c4e7633&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Banner,Thumb&EnableTotalRecordCount=false&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:46:52.919 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Latest?IncludeItemTypes=Episode,Movie&Limit=3&EnableImageTypes=Primary,Backdrop,Thumb&Fields=PrimaryImageAspectRatio&ImageTypeLimit=1&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:46:52.930 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 12ms. http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Latest?IncludeItemTypes=Episode,Movie&Limit=3&EnableImageTypes=Primary,Backdrop,Thumb&Fields=PrimaryImageAspectRatio&ImageTypeLimit=1&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:46:55.255 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:46:55.256 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:46:57.496 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/30632?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:46:57.574 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 78ms. http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/30632?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:46:57.695 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/System/Endpoint?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:46:57.704 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 9ms. http://192.168.0.25:8096/emby/System/Endpoint?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:46:57.735 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Items/30632/ThemeMedia?UserId=ae310e0fec754ead8c8413546c4e7633&InheritFromParent=true&EnableThemeSongs=true&EnableThemeVideos=false&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:46:57.752 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 17ms. http://192.168.0.25:8096/emby/Items/30632/ThemeMedia?UserId=ae310e0fec754ead8c8413546c4e7633&InheritFromParent=true&EnableThemeSongs=true&EnableThemeVideos=false&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:46:57.753 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Shows/25850/Episodes?SeasonId=30625&UserId=ae310e0fec754ead8c8413546c4e7633&Fields=PrimaryImageAspectRatio,BasicSyncInfo,CanDelete&EnableTotalRecordCount=false&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:46:57.756 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/30632/SpecialFeatures?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:46:57.758 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 2ms. http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/30632/SpecialFeatures?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:46:57.760 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items?fields=PrimaryImageAspectRatio,UserData,CanDelete&EnableTotalRecordCount=false&IncludeItemTypes=Playlist,BoxSet&Recursive=true&SortBy=SortName&ListItemIds=30632&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:46:57.766 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 6ms. http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items?fields=PrimaryImageAspectRatio,UserData,CanDelete&EnableTotalRecordCount=false&IncludeItemTypes=Playlist,BoxSet&Recursive=true&SortBy=SortName&ListItemIds=30632&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:46:57.769 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 16ms. http://192.168.0.25:8096/emby/Shows/25850/Episodes?SeasonId=30625&UserId=ae310e0fec754ead8c8413546c4e7633&Fields=PrimaryImageAspectRatio,BasicSyncInfo,CanDelete&EnableTotalRecordCount=false&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:46:57.809 Info Server: http/1.1 POST http://192.168.0.25:8096/emby/Items/30632/PlaybackInfo?UserId=ae310e0fec754ead8c8413546c4e7633&StartTimeTicks=0&IsPlayback=false&AutoOpenLiveStream=false&MaxStreamingBitrate=140000000&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:46:57.832 Debug App: GetPostedPlaybackInfo request: {"Id":"30632","UserId":"ae310e0fec754ead8c8413546c4e7633","MaxStreamingBitrate":140000000,"StartTimeTicks":0,"DeviceProfile":{"EnableAlbumArtInDidl":false,"EnableSingleAlbumArtLimit":false,"EnableSingleSubtitleLimit":false,"SupportedMediaTypes":"Audio,Photo,Video","MaxAlbumArtWidth":0,"MaxAlbumArtHeight":0,"MaxStreamingBitrate":140000000,"MusicStreamingTranscodingBitrate":192000,"TimelineOffsetSeconds":0,"RequiresPlainVideoItems":false,"RequiresPlainFolders":false,"IgnoreTranscodeByteRangeRequests":false,"XmlRootAttributes":[],"DirectPlayProfiles":[{"Container":"mp4,m4v","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"h264,h265,hevc,mpeg2video,vc1,msmpeg4v2,mpeg4,vp8,vp9","Type":"Video"},{"Container":"mkv","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"h264,h265,hevc,mpeg2video,vc1,msmpeg4v2,mpeg4,vp8,vp9","Type":"Video"},{"Container":"m2ts","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"h264,vc1,mpeg2video","Type":"Video"},{"Container":"wmv","AudioCodec":"","VideoCodec":"","Type":"Video"},{"Container":"ts,mpegts","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"h264,h265,hevc,vc1,mpeg2video","Type":"Video"},{"Container":"asf","AudioCodec":"","VideoCodec":"","Type":"Video"},{"Container":"avi","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"","Type":"Video"},{"Container":"mpg","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"","Type":"Video"},{"Container":"mpeg","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"","Type":"Video"},{"Container":"flv","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"","Type":"Video"},{"Container":"3gp","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"","Type":"Video"},{"Container":"mts","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"","Type":"Video"},{"Container":"trp","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"","Type":"Video"},{"Container":"vob","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"","Type":"Video"},{"Container":"vro","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"","Type":"Video"},{"Container":"mov","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"h264","Type":"Video"},{"Container":"rm","AudioCodec":"","VideoCodec":"","Type":"Video"},{"Container":"opus","Type":"Audio"},{"Container":"mp3","AudioCodec":"mp3","Type":"Audio"},{"Container":"mp2,mp3","AudioCodec":"mp2","Type":"Audio"},{"Container":"aac","AudioCodec":"aac","Type":"Audio"},{"Container":"m4a","AudioCodec":"aac","Type":"Audio"},{"Container":"mp4","AudioCodec":"aac","Type":"Audio"},{"Container":"flac","Type":"Audio"},{"Container":"webma,webm","Type":"Audio"},{"Container":"wma","Type":"Audio"},{"Container":"asf","Type":"Audio"},{"Container":"wav","AudioCodec":"PCM_S16LE","Type":"Audio"},{"Container":"ogg","Type":"Audio"},{"Container":"webm","AudioCodec":"vorbis,opus","VideoCodec":"VP8","Type":"Video"},{"Container":"webm","AudioCodec":"vorbis,opus","VideoCodec":"VP9","Type":"Video"}],"TranscodingProfiles":[{"Container":"aac","Type":"Audio","AudioCodec":"aac","Protocol":"hls","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"6","MinSegments":1,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"aac","Type":"Audio","AudioCodec":"aac","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"6","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"mp3","Type":"Audio","AudioCodec":"mp3","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"6","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"opus","Type":"Audio","AudioCodec":"opus","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"6","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"wav","Type":"Audio","AudioCodec":"wav","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"6","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"opus","Type":"Audio","AudioCodec":"opus","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Static","MaxAudioChannels":"6","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"mp3","Type":"Audio","AudioCodec":"mp3","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Static","MaxAudioChannels":"6","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"aac","Type":"Audio","AudioCodec":"aac","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Static","MaxAudioChannels":"6","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"wav","Type":"Audio","AudioCodec":"wav","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Static","MaxAudioChannels":"6","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"mkv","Type":"Video","VideoCodec":"h264,h265,hevc,mpeg2video,vc1,msmpeg4v2,mpeg4,vp8,vp9","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":true,"Context":"Static","MaxAudioChannels":"6","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"ts","Type":"Video","VideoCodec":"h264,h265,hevc","AudioCodec":"ac3,eac3,aac,mp3,opus","Protocol":"hls","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"6","MinSegments":1,"SegmentLength":0,"BreakOnNonKeyFrames":false,"ManifestSubtitles":"vtt"},{"Container":"webm","Type":"Video","VideoCodec":"vpx","AudioCodec":"vorbis","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"6","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"mp4","Type":"Video","VideoCodec":"h264","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Static","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false}],"ContainerProfiles":[],"CodecProfiles":[{"Type":"Video","Conditions":[{"Condition":"EqualsAny","Property":"VideoProfile","Value":"high|main|baseline|constrained baseline|high 10","IsRequired":false},{"Condition":"LessThanEqual","Property":"VideoLevel","Value":"51","IsRequired":false},{"Condition":"LessThanEqual","Property":"Width","Value":"4096","IsRequired":false}],"ApplyConditions":[],"Codec":"h264"},{"Type":"Video","Conditions":[{"Condition":"LessThanEqual","Property":"Width","Value":"4096","IsRequired":false}],"ApplyConditions":[]}],"ResponseProfiles":[{"Container":"m4v","Type":"Video","MimeType":"video/mp4","Conditions":[]}],"SubtitleProfiles":[{"Format":"vtt","Method":"Hls"},{"Format":"subrip","Method":"Embed","Container":"mkv"},{"Format":"srt","Method":"Embed"},{"Format":"mov_text","Method":"Embed"},{"Format":"ass","Method":"External"},{"Format":"ssa","Method":"External"},{"Format":"vtt","Method":"External"}]},"EnableDirectPlay":true,"EnableDirectStream":true,"EnableTranscoding":true,"AllowVideoStreamCopy":true,"AllowAudioStreamCopy":true,"IsPlayback":false,"AutoOpenLiveStream":false,"DirectPlayProtocols":["Http"]} 2020-12-29 12:46:57.876 Info App: User policy for Admin. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2020-12-29 12:46:57.916 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 107ms. http://192.168.0.25:8096/emby/Items/30632/PlaybackInfo?UserId=ae310e0fec754ead8c8413546c4e7633&StartTimeTicks=0&IsPlayback=false&AutoOpenLiveStream=false&MaxStreamingBitrate=140000000&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:47:15.897 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:47:15.898 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:47:15.901 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:47:15.901 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:47:25.912 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:47:25.913 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:47:28.429 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Shows/25850/Episodes?IsVirtualUnaired=false&IsMissing=false&UserId=ae310e0fec754ead8c8413546c4e7633&Fields=Chapters,ProductionYear,PremiereDate&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:47:28.433 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 4ms. http://192.168.0.25:8096/emby/Shows/25850/Episodes?IsVirtualUnaired=false&IsMissing=false&UserId=ae310e0fec754ead8c8413546c4e7633&Fields=Chapters,ProductionYear,PremiereDate&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:47:28.467 Info Server: http/1.1 POST http://192.168.0.25:8096/emby/Items/30632/PlaybackInfo?UserId=ae310e0fec754ead8c8413546c4e7633&StartTimeTicks=3291010000&IsPlayback=true&AutoOpenLiveStream=true&AudioStreamIndex=1&SubtitleStreamIndex=2&MediaSourceId=ad90215ec9869b84672a45e00655fcfe&MaxStreamingBitrate=140000000&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:47:28.583 Debug App: GetPostedPlaybackInfo request: {"Id":"30632","UserId":"ae310e0fec754ead8c8413546c4e7633","MaxStreamingBitrate":140000000,"StartTimeTicks":3291010000,"AudioStreamIndex":1,"SubtitleStreamIndex":2,"MediaSourceId":"ad90215ec9869b84672a45e00655fcfe","DeviceProfile":{"EnableAlbumArtInDidl":false,"EnableSingleAlbumArtLimit":false,"EnableSingleSubtitleLimit":false,"SupportedMediaTypes":"Audio,Photo,Video","MaxAlbumArtWidth":0,"MaxAlbumArtHeight":0,"MaxStreamingBitrate":140000000,"MusicStreamingTranscodingBitrate":192000,"TimelineOffsetSeconds":0,"RequiresPlainVideoItems":false,"RequiresPlainFolders":false,"IgnoreTranscodeByteRangeRequests":false,"XmlRootAttributes":[],"DirectPlayProfiles":[{"Container":"mp4,m4v","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"h264,h265,hevc,mpeg2video,vc1,msmpeg4v2,mpeg4,vp8,vp9","Type":"Video"},{"Container":"mkv","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"h264,h265,hevc,mpeg2video,vc1,msmpeg4v2,mpeg4,vp8,vp9","Type":"Video"},{"Container":"m2ts","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"h264,vc1,mpeg2video","Type":"Video"},{"Container":"wmv","AudioCodec":"","VideoCodec":"","Type":"Video"},{"Container":"ts,mpegts","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"h264,h265,hevc,vc1,mpeg2video","Type":"Video"},{"Container":"asf","AudioCodec":"","VideoCodec":"","Type":"Video"},{"Container":"avi","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"","Type":"Video"},{"Container":"mpg","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"","Type":"Video"},{"Container":"mpeg","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"","Type":"Video"},{"Container":"flv","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"","Type":"Video"},{"Container":"3gp","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"","Type":"Video"},{"Container":"mts","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"","Type":"Video"},{"Container":"trp","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"","Type":"Video"},{"Container":"vob","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"","Type":"Video"},{"Container":"vro","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"","Type":"Video"},{"Container":"mov","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"h264","Type":"Video"},{"Container":"rm","AudioCodec":"","VideoCodec":"","Type":"Video"},{"Container":"opus","Type":"Audio"},{"Container":"mp3","AudioCodec":"mp3","Type":"Audio"},{"Container":"mp2,mp3","AudioCodec":"mp2","Type":"Audio"},{"Container":"aac","AudioCodec":"aac","Type":"Audio"},{"Container":"m4a","AudioCodec":"aac","Type":"Audio"},{"Container":"mp4","AudioCodec":"aac","Type":"Audio"},{"Container":"flac","Type":"Audio"},{"Container":"webma,webm","Type":"Audio"},{"Container":"wma","Type":"Audio"},{"Container":"asf","Type":"Audio"},{"Container":"wav","AudioCodec":"PCM_S16LE","Type":"Audio"},{"Container":"ogg","Type":"Audio"},{"Container":"webm","AudioCodec":"vorbis,opus","VideoCodec":"VP8","Type":"Video"},{"Container":"webm","AudioCodec":"vorbis,opus","VideoCodec":"VP9","Type":"Video"}],"TranscodingProfiles":[{"Container":"aac","Type":"Audio","AudioCodec":"aac","Protocol":"hls","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"6","MinSegments":1,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"aac","Type":"Audio","AudioCodec":"aac","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"6","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"mp3","Type":"Audio","AudioCodec":"mp3","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"6","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"opus","Type":"Audio","AudioCodec":"opus","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"6","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"wav","Type":"Audio","AudioCodec":"wav","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"6","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"opus","Type":"Audio","AudioCodec":"opus","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Static","MaxAudioChannels":"6","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"mp3","Type":"Audio","AudioCodec":"mp3","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Static","MaxAudioChannels":"6","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"aac","Type":"Audio","AudioCodec":"aac","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Static","MaxAudioChannels":"6","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"wav","Type":"Audio","AudioCodec":"wav","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Static","MaxAudioChannels":"6","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"mkv","Type":"Video","VideoCodec":"h264,h265,hevc,mpeg2video,vc1,msmpeg4v2,mpeg4,vp8,vp9","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":true,"Context":"Static","MaxAudioChannels":"6","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"ts","Type":"Video","VideoCodec":"h264,h265,hevc","AudioCodec":"ac3,eac3,aac,mp3,opus","Protocol":"hls","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"6","MinSegments":1,"SegmentLength":0,"BreakOnNonKeyFrames":false,"ManifestSubtitles":"vtt"},{"Container":"webm","Type":"Video","VideoCodec":"vpx","AudioCodec":"vorbis","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"6","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"mp4","Type":"Video","VideoCodec":"h264","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Static","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false}],"ContainerProfiles":[],"CodecProfiles":[{"Type":"Video","Conditions":[{"Condition":"EqualsAny","Property":"VideoProfile","Value":"high|main|baseline|constrained baseline|high 10","IsRequired":false},{"Condition":"LessThanEqual","Property":"VideoLevel","Value":"51","IsRequired":false},{"Condition":"LessThanEqual","Property":"Width","Value":"4096","IsRequired":false}],"ApplyConditions":[],"Codec":"h264"},{"Type":"Video","Conditions":[{"Condition":"LessThanEqual","Property":"Width","Value":"4096","IsRequired":false}],"ApplyConditions":[]}],"ResponseProfiles":[{"Container":"m4v","Type":"Video","MimeType":"video/mp4","Conditions":[]}],"SubtitleProfiles":[{"Format":"vtt","Method":"Hls"},{"Format":"subrip","Method":"Embed","Container":"mkv"},{"Format":"srt","Method":"Embed"},{"Format":"mov_text","Method":"Embed"},{"Format":"ass","Method":"External"},{"Format":"ssa","Method":"External"},{"Format":"vtt","Method":"External"}]},"EnableDirectPlay":true,"EnableDirectStream":true,"EnableTranscoding":true,"AllowVideoStreamCopy":true,"AllowAudioStreamCopy":true,"IsPlayback":true,"AutoOpenLiveStream":true,"DirectPlayProtocols":["Http"]} 2020-12-29 12:47:28.587 Info App: User policy for Admin. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2020-12-29 12:47:28.587 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 121ms. http://192.168.0.25:8096/emby/Items/30632/PlaybackInfo?UserId=ae310e0fec754ead8c8413546c4e7633&StartTimeTicks=3291010000&IsPlayback=true&AutoOpenLiveStream=true&AudioStreamIndex=1&SubtitleStreamIndex=2&MediaSourceId=ad90215ec9869b84672a45e00655fcfe&MaxStreamingBitrate=140000000&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:47:45.233 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:47:45.235 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:47:45.904 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:47:45.904 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/videos/30632/stream.mkv?DeviceId=9cd0a87e-a7e0-4805-9fbc-af27742783f9&MediaSourceId=ad90215ec9869b84672a45e00655fcfe&Static=true&PlaySessionId=6acc2de5148d4d2e9329655045723c67. Host=192.168.0.25:8096, Range=bytes=0-, User-Agent=samsung-agent/1.1, Accept=*/*, Accept-Encoding=deflate, gzip 2020-12-29 12:47:45.905 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:47:45.980 Info Server: SocketException: http://192.168.0.25:8096/emby/videos/30632/stream.mkv?DeviceId=9cd0a87e-a7e0-4805-9fbc-af27742783f9&MediaSourceId=ad90215ec9869b84672a45e00655fcfe&Static=true&PlaySessionId=6acc2de5148d4d2e9329655045723c67&api_key=cf36cbfdc3fa48ebb27c581f659db39e 2020-12-29 12:47:45.981 Info Server: http/1.1 Response 206 to 192.168.0.50. Time: 77ms. http://192.168.0.25:8096/emby/videos/30632/stream.mkv?DeviceId=9cd0a87e-a7e0-4805-9fbc-af27742783f9&MediaSourceId=ad90215ec9869b84672a45e00655fcfe&Static=true&PlaySessionId=6acc2de5148d4d2e9329655045723c67 2020-12-29 12:47:45.985 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/videos/30632/stream.mkv?DeviceId=9cd0a87e-a7e0-4805-9fbc-af27742783f9&MediaSourceId=ad90215ec9869b84672a45e00655fcfe&Static=true&PlaySessionId=6acc2de5148d4d2e9329655045723c67. Host=192.168.0.25:8096, Range=bytes=334663598-, User-Agent=samsung-agent/1.1, Accept=*/*, Accept-Encoding=deflate, gzip 2020-12-29 12:47:45.988 Info Server: http/1.1 Response 206 to 192.168.0.50. Time: 3ms. http://192.168.0.25:8096/emby/videos/30632/stream.mkv?DeviceId=9cd0a87e-a7e0-4805-9fbc-af27742783f9&MediaSourceId=ad90215ec9869b84672a45e00655fcfe&Static=true&PlaySessionId=6acc2de5148d4d2e9329655045723c67 2020-12-29 12:47:46.031 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/videos/30632/stream.mkv?DeviceId=9cd0a87e-a7e0-4805-9fbc-af27742783f9&MediaSourceId=ad90215ec9869b84672a45e00655fcfe&Static=true&PlaySessionId=6acc2de5148d4d2e9329655045723c67. Host=192.168.0.25:8096, Range=bytes=229376-, User-Agent=samsung-agent/1.1, Accept=*/*, Accept-Encoding=deflate, gzip 2020-12-29 12:47:46.477 Info Server: SocketException: http://192.168.0.25:8096/emby/videos/30632/stream.mkv?DeviceId=9cd0a87e-a7e0-4805-9fbc-af27742783f9&MediaSourceId=ad90215ec9869b84672a45e00655fcfe&Static=true&PlaySessionId=6acc2de5148d4d2e9329655045723c67&api_key=cf36cbfdc3fa48ebb27c581f659db39e 2020-12-29 12:47:46.477 Info Server: http/1.1 Response 206 to 192.168.0.50. Time: 446ms. http://192.168.0.25:8096/emby/videos/30632/stream.mkv?DeviceId=9cd0a87e-a7e0-4805-9fbc-af27742783f9&MediaSourceId=ad90215ec9869b84672a45e00655fcfe&Static=true&PlaySessionId=6acc2de5148d4d2e9329655045723c67 2020-12-29 12:47:46.558 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/videos/30632/stream.mkv?DeviceId=9cd0a87e-a7e0-4805-9fbc-af27742783f9&MediaSourceId=ad90215ec9869b84672a45e00655fcfe&Static=true&PlaySessionId=6acc2de5148d4d2e9329655045723c67. Host=192.168.0.25:8096, Range=bytes=27587378-, User-Agent=samsung-agent/1.1, Accept=*/*, Accept-Encoding=deflate, gzip 2020-12-29 12:47:47.157 Info Server: http/1.1 POST http://192.168.0.25:8096/emby/Sessions/Playing?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:47:47.231 Info SessionManager: Playback start reported by app Emby for Samsung 1.0.86 playing Enemies. Started at 332808 ms 2020-12-29 12:47:47.239 Info Server: http/1.1 Response 204 to 192.168.0.50. Time: 81ms. http://192.168.0.25:8096/emby/Sessions/Playing?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:47:47.241 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/webhooks.xml 2020-12-29 12:47:47.244 Debug XmlSerializer: Deserializing file /var/db/emby-server/config/notifications.xml 2020-12-29 12:47:47.264 Info Server: http/1.1 POST http://192.168.0.25:8096/emby/Items/30632/PlaybackInfo?UserId=ae310e0fec754ead8c8413546c4e7633&StartTimeTicks=0&IsPlayback=false&AutoOpenLiveStream=false&MaxStreamingBitrate=140000000&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:47:47.266 Debug App: GetPostedPlaybackInfo request: {"Id":"30632","UserId":"ae310e0fec754ead8c8413546c4e7633","MaxStreamingBitrate":140000000,"StartTimeTicks":0,"DeviceProfile":{"EnableAlbumArtInDidl":false,"EnableSingleAlbumArtLimit":false,"EnableSingleSubtitleLimit":false,"SupportedMediaTypes":"Audio,Photo,Video","MaxAlbumArtWidth":0,"MaxAlbumArtHeight":0,"MaxStreamingBitrate":140000000,"MusicStreamingTranscodingBitrate":192000,"TimelineOffsetSeconds":0,"RequiresPlainVideoItems":false,"RequiresPlainFolders":false,"IgnoreTranscodeByteRangeRequests":false,"XmlRootAttributes":[],"DirectPlayProfiles":[{"Container":"mp4,m4v","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"h264,h265,hevc,mpeg2video,vc1,msmpeg4v2,mpeg4,vp8,vp9","Type":"Video"},{"Container":"mkv","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"h264,h265,hevc,mpeg2video,vc1,msmpeg4v2,mpeg4,vp8,vp9","Type":"Video"},{"Container":"m2ts","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"h264,vc1,mpeg2video","Type":"Video"},{"Container":"wmv","AudioCodec":"","VideoCodec":"","Type":"Video"},{"Container":"ts,mpegts","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"h264,h265,hevc,vc1,mpeg2video","Type":"Video"},{"Container":"asf","AudioCodec":"","VideoCodec":"","Type":"Video"},{"Container":"avi","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"","Type":"Video"},{"Container":"mpg","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"","Type":"Video"},{"Container":"mpeg","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"","Type":"Video"},{"Container":"flv","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"","Type":"Video"},{"Container":"3gp","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"","Type":"Video"},{"Container":"mts","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"","Type":"Video"},{"Container":"trp","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"","Type":"Video"},{"Container":"vob","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"","Type":"Video"},{"Container":"vro","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"","Type":"Video"},{"Container":"mov","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","VideoCodec":"h264","Type":"Video"},{"Container":"rm","AudioCodec":"","VideoCodec":"","Type":"Video"},{"Container":"opus","Type":"Audio"},{"Container":"mp3","AudioCodec":"mp3","Type":"Audio"},{"Container":"mp2,mp3","AudioCodec":"mp2","Type":"Audio"},{"Container":"aac","AudioCodec":"aac","Type":"Audio"},{"Container":"m4a","AudioCodec":"aac","Type":"Audio"},{"Container":"mp4","AudioCodec":"aac","Type":"Audio"},{"Container":"flac","Type":"Audio"},{"Container":"webma,webm","Type":"Audio"},{"Container":"wma","Type":"Audio"},{"Container":"asf","Type":"Audio"},{"Container":"wav","AudioCodec":"PCM_S16LE","Type":"Audio"},{"Container":"ogg","Type":"Audio"},{"Container":"webm","AudioCodec":"vorbis,opus","VideoCodec":"VP8","Type":"Video"},{"Container":"webm","AudioCodec":"vorbis,opus","VideoCodec":"VP9","Type":"Video"}],"TranscodingProfiles":[{"Container":"aac","Type":"Audio","AudioCodec":"aac","Protocol":"hls","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"6","MinSegments":1,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"aac","Type":"Audio","AudioCodec":"aac","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"6","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"mp3","Type":"Audio","AudioCodec":"mp3","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"6","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"opus","Type":"Audio","AudioCodec":"opus","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"6","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"wav","Type":"Audio","AudioCodec":"wav","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"6","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"opus","Type":"Audio","AudioCodec":"opus","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Static","MaxAudioChannels":"6","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"mp3","Type":"Audio","AudioCodec":"mp3","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Static","MaxAudioChannels":"6","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"aac","Type":"Audio","AudioCodec":"aac","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Static","MaxAudioChannels":"6","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"wav","Type":"Audio","AudioCodec":"wav","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Static","MaxAudioChannels":"6","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"mkv","Type":"Video","VideoCodec":"h264,h265,hevc,mpeg2video,vc1,msmpeg4v2,mpeg4,vp8,vp9","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":true,"Context":"Static","MaxAudioChannels":"6","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"ts","Type":"Video","VideoCodec":"h264,h265,hevc","AudioCodec":"ac3,eac3,aac,mp3,opus","Protocol":"hls","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"6","MinSegments":1,"SegmentLength":0,"BreakOnNonKeyFrames":false,"ManifestSubtitles":"vtt"},{"Container":"webm","Type":"Video","VideoCodec":"vpx","AudioCodec":"vorbis","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Streaming","MaxAudioChannels":"6","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false},{"Container":"mp4","Type":"Video","VideoCodec":"h264","AudioCodec":"ac3,eac3,mp3,aac,mp2,dca,dts,pcm_s16le,pcm_s24le,aac_latm,opus,flac,vorbis","Protocol":"http","EstimateContentLength":false,"EnableMpegtsM2TsMode":false,"TranscodeSeekInfo":"Auto","CopyTimestamps":false,"Context":"Static","MinSegments":0,"SegmentLength":0,"BreakOnNonKeyFrames":false}],"ContainerProfiles":[],"CodecProfiles":[{"Type":"Video","Conditions":[{"Condition":"EqualsAny","Property":"VideoProfile","Value":"high|main|baseline|constrained baseline|high 10","IsRequired":false},{"Condition":"LessThanEqual","Property":"VideoLevel","Value":"51","IsRequired":false},{"Condition":"LessThanEqual","Property":"Width","Value":"4096","IsRequired":false}],"ApplyConditions":[],"Codec":"h264"},{"Type":"Video","Conditions":[{"Condition":"LessThanEqual","Property":"Width","Value":"4096","IsRequired":false}],"ApplyConditions":[]}],"ResponseProfiles":[{"Container":"m4v","Type":"Video","MimeType":"video/mp4","Conditions":[]}],"SubtitleProfiles":[{"Format":"vtt","Method":"Hls"},{"Format":"subrip","Method":"Embed","Container":"mkv"},{"Format":"srt","Method":"Embed"},{"Format":"mov_text","Method":"Embed"},{"Format":"ass","Method":"External"},{"Format":"ssa","Method":"External"},{"Format":"vtt","Method":"External"}]},"EnableDirectPlay":true,"EnableDirectStream":true,"EnableTranscoding":true,"AllowVideoStreamCopy":true,"AllowAudioStreamCopy":true,"IsPlayback":false,"AutoOpenLiveStream":false,"DirectPlayProtocols":["Http"]} 2020-12-29 12:47:47.267 Info App: User policy for Admin. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2020-12-29 12:47:47.267 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 3ms. http://192.168.0.25:8096/emby/Items/30632/PlaybackInfo?UserId=ae310e0fec754ead8c8413546c4e7633&StartTimeTicks=0&IsPlayback=false&AutoOpenLiveStream=false&MaxStreamingBitrate=140000000&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:47:47.584 Info Server: http/1.1 POST http://192.168.0.25:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:47:47.598 Info Server: http/1.1 Response 204 to 192.168.0.50. Time: 15ms. http://192.168.0.25:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:47:48.165 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Resume?Limit=3&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:47:48.515 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 350ms. http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Resume?Limit=3&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:47:48.529 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Shows/NextUp?Limit=3&Fields=PrimaryImageAspectRatio&ImageTypeLimit=1&UserId=ae310e0fec754ead8c8413546c4e7633&EnableTotalRecordCount=false&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:47:48.614 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 85ms. http://192.168.0.25:8096/emby/Shows/NextUp?Limit=3&Fields=PrimaryImageAspectRatio&ImageTypeLimit=1&UserId=ae310e0fec754ead8c8413546c4e7633&EnableTotalRecordCount=false&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:47:48.630 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Latest?IncludeItemTypes=Episode,Movie&Limit=3&EnableImageTypes=Primary,Backdrop,Thumb&Fields=PrimaryImageAspectRatio&ImageTypeLimit=1&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:47:48.638 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 9ms. http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Latest?IncludeItemTypes=Episode,Movie&Limit=3&EnableImageTypes=Primary,Backdrop,Thumb&Fields=PrimaryImageAspectRatio&ImageTypeLimit=1&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:47:52.238 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Resume?Limit=3&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:47:52.585 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 347ms. http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Resume?Limit=3&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:47:52.594 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Shows/NextUp?Limit=3&Fields=PrimaryImageAspectRatio&ImageTypeLimit=1&UserId=ae310e0fec754ead8c8413546c4e7633&EnableTotalRecordCount=false&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:47:52.637 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:47:52.637 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 2ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:47:52.646 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 53ms. http://192.168.0.25:8096/emby/Shows/NextUp?Limit=3&Fields=PrimaryImageAspectRatio&ImageTypeLimit=1&UserId=ae310e0fec754ead8c8413546c4e7633&EnableTotalRecordCount=false&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:47:52.659 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Latest?IncludeItemTypes=Episode,Movie&Limit=3&EnableImageTypes=Primary,Backdrop,Thumb&Fields=PrimaryImageAspectRatio&ImageTypeLimit=1&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:47:52.669 Info Server: http/1.1 Response 200 to 192.168.0.50. Time: 10ms. http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633/Items/Latest?IncludeItemTypes=Episode,Movie&Limit=3&EnableImageTypes=Primary,Backdrop,Thumb&Fields=PrimaryImageAspectRatio&ImageTypeLimit=1&X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:47:55.896 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:47:55.897 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:47:57.589 Info Server: http/1.1 POST http://192.168.0.25:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:47:57.590 Info Server: http/1.1 Response 204 to 192.168.0.50. Time: 1ms. http://192.168.0.25:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:47:58.589 Info Server: http/1.1 POST http://192.168.0.25:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:47:58.590 Info Server: http/1.1 Response 204 to 192.168.0.50. Time: 1ms. http://192.168.0.25:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:48:05.918 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:48:05.919 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:48:07.262 Info Server: http/1.1 POST http://192.168.0.25:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:48:07.263 Info Server: http/1.1 Response 204 to 192.168.0.50. Time: 1ms. http://192.168.0.25:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:48:16.203 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:48:16.204 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:48:17.261 Info Server: http/1.1 POST http://192.168.0.25:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:48:17.318 Info Server: http/1.1 Response 204 to 192.168.0.50. Time: 57ms. http://192.168.0.25:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:48:26.819 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:48:26.820 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:48:27.261 Info Server: http/1.1 POST http://192.168.0.25:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:48:27.285 Info Server: http/1.1 Response 204 to 192.168.0.50. Time: 24ms. http://192.168.0.25:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:48:35.913 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:48:35.914 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:48:37.261 Info Server: http/1.1 POST http://192.168.0.25:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:48:37.262 Info Server: http/1.1 Response 204 to 192.168.0.50. Time: 1ms. http://192.168.0.25:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:48:45.903 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:48:45.904 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:48:47.262 Info Server: http/1.1 POST http://192.168.0.25:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:48:47.263 Info Server: http/1.1 Response 204 to 192.168.0.50. Time: 1ms. http://192.168.0.25:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:48:55.901 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:48:55.902 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:48:57.262 Info Server: http/1.1 POST http://192.168.0.25:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:48:57.264 Info Server: http/1.1 Response 204 to 192.168.0.50. Time: 2ms. http://192.168.0.25:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:49:08.697 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:49:08.698 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/Users/ae310e0fec754ead8c8413546c4e7633?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:49:08.706 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/System/Logs?SortBy=IsFolder,SortName&SortOrder=Ascending&Fields=BasicSyncInfo,CanDelete&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&StartIndex=0&Limit=50&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:49:08.738 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 33ms. http://192.168.0.25:8096/emby/System/Logs?SortBy=IsFolder,SortName&SortOrder=Ascending&Fields=BasicSyncInfo,CanDelete&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&StartIndex=0&Limit=50&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:49:08.745 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:49:08.746 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:49:09.085 Info Server: http/1.1 POST http://192.168.0.25:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:49:09.086 Info Server: http/1.1 Response 204 to 192.168.0.50. Time: 1ms. http://192.168.0.25:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:49:13.508 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/System/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-29 12:49:13.509 Info Server: http/1.1 Response 200 to 192.168.0.15. Time: 1ms. http://192.168.0.25:8096/emby/System/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=ed974394-d7bd-4319-a17e-7a1e04beb5a3&X-Emby-Client-Version=4.5.4.0 2020-12-29 12:49:17.264 Info Server: http/1.1 POST http://192.168.0.25:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86. UserAgent: Mozilla/5.0 (SMART-TV; LINUX; Tizen 3.0) AppleWebKit/538.1 (KHTML, like Gecko) Version/3.0 TV Safari/538.1 2020-12-29 12:49:17.265 Info Server: http/1.1 Response 204 to 192.168.0.50. Time: 1ms. http://192.168.0.25:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby for Samsung&X-Emby-Device-Name=Samsung Smart TV (UN43MU630D)&X-Emby-Device-Id=9cd0a87e-a7e0-4805-9fbc-af27742783f9&X-Emby-Client-Version=1.0.86 2020-12-29 12:49:35.774 Info Server: http/1.1 GET http://192.168.0.25:8096/emby/System/Logs/embyserver.txt. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36
Luke 42204 Posted December 30, 2020 Posted December 30, 2020 By selecting show do you mean just pulling up the details for one, or do you mean trying to start playback?
Carlo 4561 Posted December 31, 2020 Posted December 31, 2020 Is your new server scanning drives and building your libraries?
