rjwill10 2 Posted December 29, 2020 Posted December 29, 2020 Hi, I have a VU+ Zero that I have hooked into my network. I've tried to add this box to my Emby Server, but the drop down only ever shows 3 options "HD Homerun, M3U & Other". I've added the VU+ plug in, and reset the server. I then added the IP address of the box and hit save. After saving the config, I returned to Live TV and refreshed the guide data, but nothing changes. I also tried to detect the device, but this did nothing either. When selecting "other" from the drop down, this doesn't seem to give me any options. I've tested that the IP address of the box works. I run the IP address in my browser using Webif, and the box is accessible and able to stream. Thanks
AndrewLe 3 Posted December 29, 2020 Posted December 29, 2020 I have VU+ devices also. It looks like VU+ plugin is outdated but we don't need it. You can export M3U with all the channels in the bucket (use OpenWebIf and click on the icon at the top of the list to download the file). This file should be configured with Emby (M3U). Also you need to install HDTunerProxy on VU+ box to generate EPG / Guide that can be used by Emby Server.
vdatanet 1619 Posted December 29, 2020 Posted December 29, 2020 You also can install a plugin called HRTunerProxy in your vu+ box and then Emby can use it as an HDHomeRun device Enigma2 LiveTV/DVR support. - Emby Server - Emby Community
AndrewLe 3 Posted December 29, 2020 Posted December 29, 2020 Btw, does HRTunerProxy support picons? I was unable to configure it.
Luke 42243 Posted December 29, 2020 Posted December 29, 2020 3 hours ago, AndrewLe said: Btw, does HRTunerProxy support picons? I was unable to configure it. Are there any in it's user interface?
AndrewLe 3 Posted December 29, 2020 Posted December 29, 2020 (edited) Nope, it is very basic. Maybe it is located somewhere in the XMLs returned by the service (I don't know HDTuner API to check). This is the XML returned: <root xmlns="urn:schemas-upnp-org:device-1-0"> <specVersion> <major>1</major> <minor>0</minor> </specVersion> <URLBase>http://10.0.0.215:6083</URLBase> <device> <deviceType>urn:schemas-upnp-org:device:MediaServer:1</deviceType> <friendlyName>vusolo2</friendlyName> <manufacturer>Silicondust</manufacturer> <modelName>VUSOLO2</modelName> <modelNumber>vusolo2</modelNumber> <serialNumber/> <UDN>uuid:bd738cf7-2968-4aac-a624-bc05cea63f4d</UDN> </device> </root> Edited December 29, 2020 by AndrewLe
Luke 42243 Posted December 30, 2020 Posted December 30, 2020 15 hours ago, AndrewLe said: I have VU+ devices also. It looks like VU+ plugin is outdated but we don't need it. You can export M3U with all the channels in the bucket (use OpenWebIf and click on the icon at the top of the list to download the file). This file should be configured with Emby (M3U). Also you need to install HDTunerProxy on VU+ box to generate EPG / Guide that can be used by Emby Server. Curious, does that generate an m3u only? Does it also support outputting epg data as xmltv?
AndrewLe 3 Posted December 30, 2020 Posted December 30, 2020 Nope, maybe other plugins are able to generate XMLTV EPG, but I don't know any of them. Plugin's source is here - https://github.com/OpenViX/HRTunerProxy I don't like Python but I'll check how to add XMLTV output to this plugin as well.
rjwill10 2 Posted December 30, 2020 Author Posted December 30, 2020 Are there any other suggested boxes that can be used? The HD home run is an aerial box, I prefer SAT boxes. I only have VU boxes from the good old days of card sharing, so am open to changing.
AndrewLe 3 Posted December 31, 2020 Posted December 31, 2020 (edited) Btw, yesterday I made the service that resides between VU+ and Emby and provides Emby with channels, picons and additional streams (cctv). Unfortunately, it has no EPG data (I can't find the data source - even VU+ shows very limited information) yet. It runs on linux (.net5 daemon) near the Emby server. Here is the link: https://github.com/alishchytovych/EnigmaLiveTV Edited December 31, 2020 by AndrewLe
AndrewLe 3 Posted January 1, 2021 Posted January 1, 2021 The real EPG data has been added. It looks like I've solved this issue for myself. Btw, crosschecked the same service with the Plex - it works well too. Except RTSP CCTV stream. Do you have any discounts for the migrating Plex Pass users?
AndrewLe 3 Posted January 2, 2021 Posted January 2, 2021 I've rewritten the service and removed any dependency on the HRTunerProxy plugin. It works directly with the OpenWebIf API. Emby team is welcomed to integrate it to the Emby server and you'll get a lot of kudos from OpenPLi / Enigma2 users 1
canada99 9 Posted January 3, 2021 Posted January 3, 2021 (edited) I am curious of the legality of hosting epg guide data only without any channels, is it perfectly legal to host for all to use ? @AndrewLe this has been done for years behind closed doors but now that you brought it up I totally agree it should be integrated into emby but maybe taken a step further. Why not create a guide share so that people can share their guide data, I would be happy to contribute to this if it is legal. Integrated so iptv sellers could not use it or even see it for that matter, would definitely be cool! Edited January 3, 2021 by canada99
AndrewLe 3 Posted January 3, 2021 Posted January 3, 2021 I'm pretty sure that in the "license chain" we will find some limitations to share the data. Or it could be limited to the free of charge sharing only etc. Another aspect - EPG data is pretty heavy (let say few MB per the 100 channels bouquete / per week), someone should pay for the servers / traffic. The service (or if Emby integrates it into the core) works with the user's own devices that doesn't break any licenses. 1
wodaaa 2 Posted October 10, 2021 Posted October 10, 2021 On 1/2/2021 at 9:14 PM, AndrewLe said: I've rewritten the service and removed any dependency on the HRTunerProxy plugin. It works directly with the OpenWebIf API. Emby team is welcomed to integrate it to the Emby server and you'll get a lot of kudos from OpenPLi / Enigma2 users Has the Emby team done anything with downloading epg directly from the tuner? It would be the perfect solution for me.
Luke 42243 Posted October 11, 2021 Posted October 11, 2021 6 hours ago, wodaaa said: Has the Emby team done anything with downloading epg directly from the tuner? It would be the perfect solution for me. HI, it's something we're planning on looking at in future updates. Thanks.
