unpjeb 0 Posted December 28, 2020 Posted December 28, 2020 Hi all, new poster here. Recently I started planning for home video/audio hub to be more user friendly. My current setup is Oppo BDP-103D as a player (receiving signals from TV box, blu-rays, dvds, data from USB sticks, external HDs), with video output going into TV and audio output into Creek receiver Evolution 50A. Oppo is also connected to LAN with ethernet cable. I wanted to upgrade my media library front end selection with DLNA server. I went with Emby as it offers not only media server but also push playing to Oppo for example. I created server on my laptop, connected to router with an ethernet cable (both laptop and Oppo are on the same netwotk). I have an app on my phone to browse/play the library, wirelessly connected to the same network. Problem I have is that Emby server doesn't see Oppo as an option to push the file to. I only see my laptop as a playback option if I want to start playback from an app on my phone, and my phone if I want to start playback from my laptop. However, if I navigate to networked folders on my Oppo, I can see Emby media server, so it seems Oppo can see Emby, but not the other way around. It may be a quite straightforward solution, but I am just only starting out with this, and I couldn't find any solution in the support section. It seems that it should be plug and play.:) I will be grateful for any help and pointers how to fix this. Cheers!
Luke 42237 Posted December 29, 2020 Posted December 29, 2020 Hi there, what version of Emby Server are you running?
unpjeb 0 Posted December 29, 2020 Author Posted December 29, 2020 Hi Luke, I am using 4.5.4.0, although when I logged on last night from laptop, it was showing that I am running Emby Web 4.5.4.11. Today it is showing 4.5.4.0. Regardless, yesterday evening it showed Oppo and I was able to start playback. It is still showing today - I don't know really what changed. Hope it stays this way.:)
rajchand 0 Posted March 15, 2021 Posted March 15, 2021 Hi Guys, Newbie to Emby, just migrated over from Plex. I've got Emby 4.5.4.0 server working fine with my OPPO BDP-103D except for files with ATMOS or DTS-X. All files are in MKV format. Files with DTS-HD, Dolby TrueHD, Dolby Digital & DTS work fine, just not ATMOS or DTS-X. I will be grateful for any help to fix this issue. I have read other topics regarding Profiles. I have downloaded the UDP-203 profile. But I don't know how to load it in my DLNA settings. Will that work in BDP-103D? If not, can you please steer me in the right direction. Cheers & Thanks in Advance.
Luke 42237 Posted March 15, 2021 Posted March 15, 2021 3 hours ago, rajchand said: Hi Guys, Newbie to Emby, just migrated over from Plex. I've got Emby 4.5.4.0 server working fine with my OPPO BDP-103D except for files with ATMOS or DTS-X. All files are in MKV format. Files with DTS-HD, Dolby TrueHD, Dolby Digital & DTS work fine, just not ATMOS or DTS-X. I will be grateful for any help to fix this issue. I have read other topics regarding Profiles. I have downloaded the UDP-203 profile. But I don't know how to load it in my DLNA settings. Will that work in BDP-103D? If not, can you please steer me in the right direction. Cheers & Thanks in Advance. Hi, what is the problem you are having?
rajchand 0 Posted March 15, 2021 Posted March 15, 2021 Hi, mkv files with ATMOS & DTSX, the sound not working
rbjtech 5341 Posted March 15, 2021 Posted March 15, 2021 Does the OPPO even support Atmos/DTS-X ? http://www.oppodigital.co.uk/UserFiles/Docs/PDF/BDP-103D_DataSheet_V1.0.pdf This PDF does not mention Atmos/DTS-X ... The fact it is working with Tru-HD and DTS-HD suggests that if it did support the positioning/height metadata, then it will automatically work...
