TheShanMan 41 Posted December 28, 2020 Posted December 28, 2020 I'll preface my problem with this in case it's relevant: I recently installed Windows 10 clean, previously ran Windows 7, and copied my old Emby Server and Theater folders over after installing fresh copies of them. I didn't manually install any codecs apart from that. All videos I've played since then have played fine in Theater, but one last night didn't. Rebooting didn't help. The problem is the video was playing at a very slow speed even though audio was playing at normal speed. If I hit the skip forward button, it would skip forward based on the current video position, not the current audio position. That would sync video and audio back up, but only for that instant because from that point, video would continue playing at the slow speed. I've played this video in the distant past, I'm pretty sure in Theater, without a problem. It also plays just fine in VLC and in Emby Android, so my workaround was to cast from my phone to my Chromecast. Any idea what would cause this and what the fix is? Here's the MediaInfo output for the mkv file in case that's helpful: Format : Matroska Format version : Version 2 File size : 4.38 GiB Duration : 2 h 10 min Overall bit rate : 4 795 kb/s Encoded date : UTC 2009-11-19 20:02:45 Writing application : mkvmerge v2.9.7 ('Tenderness') built on Jul 1 2009 18:43:35 Writing library : libebml v0.7.7 + libmatroska v0.8.1 Attachments : arial.ttf / ariali.ttf Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 9 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 9 frames Codec ID : V_MPEG4/ISO/AVC Duration : 2 h 10 min Bit rate : 4 567 kb/s Width : 968 pixels Height : 720 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.273 Stream size : 4.08 GiB (93%) Writing library : x264 core 79 r1332M 70f8869 Encoding settings : cabac=1 / ref=9 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=0.7:0.2 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-3 / threads=6 / nr=0 / decimate=0 / mbaff=0 / constrained_intra=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / mbtree=0 / bitrate=4567 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.80 Language : English Default : Yes Forced : No Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 2 h 10 min Bit rate mode : Constant Bit rate : 224 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 209 MiB (5%) Title : AC3 2.0 @ 224 Language : English Service kind : Complete Main Default : Yes Forced : No Text #1 ID : 3 Format : ASS Codec ID : S_TEXT/ASS Codec ID/Info : Advanced Sub Station Alpha Compression mode : Lossless Language : English Default : No Forced : No Text #2 ID : 4 Format : ASS Codec ID : S_TEXT/ASS Codec ID/Info : Advanced Sub Station Alpha Compression mode : Lossless Language : French Default : No Forced : No Text #3 ID : 5 Format : ASS Codec ID : S_TEXT/ASS Codec ID/Info : Advanced Sub Station Alpha Compression mode : Lossless Language : Portuguese Default : No Forced : No Text #4 ID : 6 Format : ASS Codec ID : S_TEXT/ASS Codec ID/Info : Advanced Sub Station Alpha Compression mode : Lossless Language : Spanish Default : No Forced : No
pmac 143 Posted December 29, 2020 Posted December 29, 2020 I just started having this same issue on one of my machines running emby theater. I haven't made any changes to my system, and everything has played fine up until tonight. It doesn't matter what I try playing, I get terrible judder on everything I've tried. They all play fine when using the web app on that machine though, as well as the Samsung app on that TV, but my preferred player is ET, which kinda sucks, because it's unusable for me currently. ET is working just fine on my main HTPC though.
TheShanMan 41 Posted December 29, 2020 Author Posted December 29, 2020 (edited) I should've stated that I'm running version 3.0.13, which as I recall isn't an official release and just an interim solution for the overlay problem. Good to know it's not just me, I guess. Edited December 29, 2020 by TheShanMan Had the version number wrong
sooty234 266 Posted December 29, 2020 Posted December 29, 2020 Also, post an mpv log On 12/27/2020 at 9:55 AM, sooty234 said: To generate an mpv log, you need to make an mpv.conf and add logging to it. Be sure to name the log file you're making in the logging entry. Example: log-file="G:\mpv logs\Portable mpv log.txt"
TheShanMan 41 Posted December 29, 2020 Author Posted December 29, 2020 I installed 3.0.13 clean and it seems to be working. However, now I can't seem to get Theater to start full screen for the life of me. It doesn't seem to remember that it was full screen. I have an mpv log too but I'm guessing since clean .13 works, you might not be interested in the log.
sooty234 266 Posted December 29, 2020 Posted December 29, 2020 Try switching to the GPU renderer and restarting the app.
TheShanMan 41 Posted July 14, 2021 Author Posted July 14, 2021 I have this happening again with some episodes of a TV series I have, which are .avi's. Again, they play correctly in VLC. General Format : AVI Format/Info : Audio Video Interleave File size : 105 MiB Duration : 6 min 26 s Overall bit rate : 2 281 kb/s Writing application : VirtualDubMod 1.5.10.1 (build 2366/release) Writing library : VirtualDubMod build 2366/release Video ID : 0 Format : MPEG-4 Visual Format profile : Simple@L3 Format settings, BVOP : No Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default (MPEG) Codec ID : XVID Codec ID/Hint : XviD Duration : 6 min 26 s Bit rate : 2 079 kb/s Width : 576 pixels Height : 432 pixels Display aspect ratio : 4:3 Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.334 Stream size : 95.7 MiB (91%) Writing library : XviD 0.0.09 (UTC 2003-03-25) Audio ID : 1 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : 2000 Duration : 6 min 26 s Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Delay relative to video : 516 ms Stream size : 8.84 MiB (8%) Alignment : Split across interleaves Interleave, duration : 40 ms (1.00 video frame) Interleave, preload duration : 500 ms Service kind : Complete Main
TheShanMan 41 Posted July 14, 2021 Author Posted July 14, 2021 On 12/29/2020 at 10:14 AM, sooty234 said: Try switching to the GPU renderer and restarting the app. That appears to solve it. Any idea why "auto" would do the wrong thing at times?
Guest Posted July 18, 2021 Posted July 18, 2021 On 7/13/2021 at 8:24 PM, TheShanMan said: Any idea why "auto" would do the wrong thing at times? Auto just defaults to the libmpv renderer, and doesn't use the gpu renderer.
TheShanMan 41 Posted July 18, 2021 Author Posted July 18, 2021 Seems kinda silly... seems like simply defaulting to libmpv would eliminate potential confusion. Auto to me implies a (presumably intelligent) choice by the app for which renderer to use. Unfortunately choosing gpu is a poor solution because the OSD stops working if I set it to gpu. Would that be a bug in the gpu renderer or a limitation that Emby can't overcome? Is fixing the libmpv renderer so it doesn't have sync issues in videos like I have a possibility?
Guest Posted July 18, 2021 Posted July 18, 2021 2 minutes ago, TheShanMan said: Seems kinda silly... seems like simply defaulting to libmpv would eliminate potential confusion. Auto to me implies a (presumably intelligent) choice by the app for which renderer to use. Unfortunately choosing gpu is a poor solution because the OSD stops working if I set it to gpu. Would that be a bug in the gpu renderer or a limitation that Emby can't overcome? Is fixing the libmpv renderer so it doesn't have sync issues in videos like I have a possibility? The UI issue was the reason libmpv was introduced. But the problem is that the libmpv renderer and electron, don't like each other. There are some conflicts. One big conflict is mpv's access/use of the Windows d3d swapchain is blocked. So when using libmpv in Theater, if you look at the stats when playing, you'll see that for hardware acceleration, there will either be none or it will use one of the copyback modes. This is the only way mpv will be able play any video. This means you can't play HDR stuff. The metadata will not pass to the display.
Guest Posted July 18, 2021 Posted July 18, 2021 For reference. https://github.com/mpv-player/mpv/issues/7769
TheShanMan 41 Posted July 18, 2021 Author Posted July 18, 2021 Are you saying the videos I'm having trouble with are HDR? I don't know much about HDR but I think it's associated with 4k, isn't it? I don't have any 4k videos.
Guest Posted July 18, 2021 Posted July 18, 2021 4 minutes ago, TheShanMan said: Are you saying the videos I'm having trouble with are HDR? I don't know much about HDR but I think it's associated with 4k, isn't it? I don't have any 4k videos. No, it affects all video. I was just using HDR stuff as an example. The libmpv renderer is shit (comparatively). GPU is better, but that too will be replaced in the not too distant future. 4k (UHD) and HDR are not synonymous. They are different entities. But the foundation video still needs to be decoded and rendered before it's sent to the display using the d3d swapchain. The HDR metadata is sent along with the video for the display to decode and apply (if it isn't being tone mapped by the software). In your example above, that is an xvid encoded video in an AVI container. This can be problematic to demux and decode. mpv can do it, but you should leave hardware acceleration to auto, so mpv can decide how best to handle it. You'd be wise to run that through Handbrake and transcode it to h264 in an mkv container. Then you won't have any issues.
TheShanMan 41 Posted July 18, 2021 Author Posted July 18, 2021 (edited) Haha! In one case "auto" is nothing more than a default, and in another "auto" means an intelligent choice is actually made. Seems like the former case should be fixed so that auto actually means intelligent choice, or should be removed. Thanks for pointing out the key characteristic: xvid in avi. I'm pretty sure I have hardware acceleration set to auto but I'll double check. And I think I have a lot of those which do play properly but maybe I'm wrong. It would be nice to single out just the ones that libmpv won't play properly if in fact I do have xvid avi's that work fine. I don't want to convert more videos than I have to. I don't suppose you know of a way to do that? Or do you think all xvid avi's will have playback problems in libmpv? Appreciate the feedback on this! Edited July 18, 2021 by TheShanMan
Guest Posted July 18, 2021 Posted July 18, 2021 1 hour ago, TheShanMan said: Haha! In one case "auto" is nothing more than a default, and in another "auto" means an intelligent choice is actually made. Seems like the former case should be fixed so that auto actually means intelligent choice, or should be removed. Thanks for pointing out the key characteristic: xvid in avi. I'm pretty sure I have hardware acceleration set to auto but I'll double check. And I think I have a lot of those which do play properly but maybe I'm wrong. It would be nice to single out just the ones that libmpv won't play properly if in fact I do have xvid avi's that work fine. I don't want to convert more videos than I have to. I don't suppose you know of a way to do that? Or do you think all xvid avi's will have playback problems in libmpv? Appreciate the feedback on this! Well, in the case of the choice of renderer, that's Emby, but the choice of hardware acceleration, that's mpv. Because of electron sitting on top of libmpv, that adds an instruction layer. If you played your media directly in mpv, I suspect they would play just fine (as it does in VLC). But you should be aware that support for these older containers and codecs, is slowly ebbing away. Even h264 is now old, but very common. I just found some of my shows that are in the same format as yours. mpv chooses nvdec-copy to play it. Other than that, it's software decoded. So I need to get to work on those.
TheShanMan 41 Posted September 10, 2023 Author Posted September 10, 2023 I've had this start happening more and more lately for some reason, with videos that aren't XVID, and videos that used to work just fine. What's going on? Super frustrating to run into this randomly and have to re-encode stuff.
TheShanMan 41 Posted September 13, 2023 Author Posted September 13, 2023 Is older hardware and/or OS likely to cause video to play at a slow rate while the audio plays at normal speed? I just tried one such video on Theater on my desktop computer and it plays fine there (Windows 11 on relatively new hardware) in contrast to my HTPC (Windows 10 on old hardware). I'd really like to understand the root cause/solution to this so I don't keep running into this on videos which can't even be blamed on xvid. I'll upgrade Windows if I have to, but don't want to just on a roll of the dice. Same for hardware. Here's mediainfo output fwiw: General Unique ID : 187635967868198955619548001858952226150 (0x8D295F776EB507CD81BDEAF7AEC5E566) Complete name : .mkv Format : Matroska Format version : Version 2 File size : 1.85 GiB Duration : 1 h 2 min Overall bit rate : 4 251 kb/s Frame rate : 23.976 FPS Encoded date : 2013-08-23 12:35:39 UTC Writing application : mkvmerge v5.8.0 ('No Sleep / Pillow') built on Sep 2 2012 15:37:04 Writing library : libebml v1.2.3 + libmatroska v1.3.0 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.1 Format settings : 2 Ref Frames Format settings, CABAC : No Format settings, Reference frames : 2 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1 h 2 min Width : 980 pixels Height : 720 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 23.976 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Language : English Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : A_AAC-2 Duration : 1 h 2 min Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 46.875 FPS (1024 SPF) Compression mode : Lossy Language : English Default : Yes Forced : Yes
Luke 42237 Posted September 13, 2023 Posted September 13, 2023 Possibly. I've just released Emby Theater 3.0.21 which updates to mpv 0.36. Can you see if that helps by chance?
TheShanMan 41 Posted September 14, 2023 Author Posted September 14, 2023 I'm gonna tentatively say yes... Of the several videos I've seen this problem with recently, I only had one remaining in original form. The rest I re-encoded to get them to play better. The untouched one is playing properly now. So I think that might've been the problem! I'll keep an eye on it and report back if I run into this again. What is it about the mpv library that would have caused the problem? Thanks Luke! 1
Luke 42237 Posted September 15, 2023 Posted September 15, 2023 Quote What is it about the mpv library that would have caused the problem? It's our video player. It's hard to say. Maybe there was a bug fix in a newer version of theirs.
TheShanMan 41 Posted September 17, 2023 Author Posted September 17, 2023 Well @LukeI was wrong because it depends on the monitor it plays on... I have 2 TV's - a normal modern one and a 1956 black and white console TV and my HTPC is hooked up to both, via 2 different graphics cards. So for whatever reason, the video in question seems to play properly on my main TV but improperly on my black and white. Therefore my only guess is the video card drivers factor into this problem. Why would that be? And what, if anything, is the solution?
Luke 42237 Posted September 17, 2023 Posted September 17, 2023 It's certainly possible. Are the video drivers up to date?
TheShanMan 41 Posted September 18, 2023 Author Posted September 18, 2023 They are but that's not saying much... It's a very old video card providing me with an s-video output. Doing a little troubleshooting... The most reliable way of switching between TV's in an automated (press of a remote button) fashion involved disabling/enabling the desired video card in device manager, as opposed to disabling/enabling the monitor in the display settings screen. The latter was my preference but I couldn't get it to work reliably. From trying some things so far, I think if my main video card (the hdmi one which is newer) is disabled, the video plays improperly but if I have both cards enabled but the hdmi monitor disabled, it plays properly on the black and white TV. Maybe after half a dozen years, I could get the monitor enabling/disabling approach to work better. I'll see what I can do there and report back. 1
