denis_emby 0 Posted December 28, 2020 Posted December 28, 2020 Перешел с встроенного Android TV (Sony KD-55XD8599) на Mi Box S. Столкнулся с тем, что фильм, который на Sony воспроизводился без проблем, на Mi Box стал периодически фризить картинку и как будто подгружаться! Plex воспроизводит тот же фильм, без проблем. В чем может быть причина? Сервер: 4.5.4.0 Клиент: AndroidTV 1.8.54g
ebr 16332 Posted December 28, 2020 Posted December 28, 2020 Hi. That is a very high bitrate item and may just be beyond what the system can handle. What happens if you lower the max bitrate setting in the app?
denis_emby 0 Posted December 29, 2020 Author Posted December 29, 2020 16 hours ago, ebr said: Привет. Это элемент с очень высоким битрейтом, который может выходить за рамки возможностей системы. Что произойдет, если вы снизите настройку максимального битрейта в приложении? But why then: 1 - does it play without problems in Emby on TV? 2 - is it playable in Plex without any problems on the same system? 3 - high bitrate videos can be played without problems?
ebr 16332 Posted December 29, 2020 Posted December 29, 2020 Different device, different network connections, etc. all can play a role here. The other guys could be automatically lowering the bitrate without you even knowing it. The first step in diagnosing would be to find out if the item plays well with a lower bitrate setting.
neik 874 Posted December 29, 2020 Posted December 29, 2020 Doesn't the MiBox S have issues with very high bitrate (>50 or 60 mbit)? I think it was reported somewhere but couldn't find it right now...
ebr 16332 Posted December 29, 2020 Posted December 29, 2020 2 minutes ago, neik said: Doesn't the MiBox S have issues with very high bitrate (>50 or 60 mbit)? I think it was reported somewhere but couldn't find it right now... Pretty sure that is beyond the spec for it, yes. 1
denis_emby 0 Posted March 19, 2021 Author Posted March 19, 2021 On 30.12.2020 at 00:15, ebr said: Совершенно уверен, что это выходит за рамки спецификации, да. Проблема все же с Emby. Так как тот же файл, через KODI воспроизводиться без проблем!
Luke 42239 Posted March 21, 2021 Posted March 21, 2021 Hi there, can you please try playing it with our standard Android app and see how that compares? https://emby.media/emby-for-android.html
denis_emby 0 Posted April 20, 2021 Author Posted April 20, 2021 Не получилось проверить. standard Android app требуется Premier, которого у меня нет. Проблема больше не актуально. Перешел на Nvidia Sheild TV Pro - там все работает без проблем.
Carlo 4561 Posted April 20, 2021 Posted April 20, 2021 OK thanks for the update and glad you got this resolved using the Shield TV Pro.
