gokuz 13 Posted December 28, 2020 Posted December 28, 2020 (edited) Windows 1809 Nvidia 1070 latest drivers + rollback to 2 drivers down Tried 3.0.13 + rollback to other versions 32bit & 64bit Install and Zipped Above is all the info needed to solve this problem asap. Problem= ET just starts at the taskbar, there's an invisible layer which I can't click on. How do I fix this? Edited December 28, 2020 by gokuz
Luke 42240 Posted December 29, 2020 Posted December 29, 2020 Quote Tried 3.0.13 + rollback to other versions Hi, what other versions did you try?
gokuz 13 Posted December 29, 2020 Author Posted December 29, 2020 5 hours ago, Luke said: Hi, what other versions did you try? The previous 3.
gokuz 13 Posted December 30, 2020 Author Posted December 30, 2020 13 minutes ago, Luke said: Does this look like your issue? Good news seems like it fixed itself. No idea what happened I didn't change a thing. On another note, how do I disable the volume control of the internal player? It's clashing with windows volume which I do not want.
Luke 42240 Posted December 30, 2020 Posted December 30, 2020 Thanks for the feedback. There isn't any disabling of the internal volume. I would just not use it if that's what you prefer to do.
gokuz 13 Posted December 30, 2020 Author Posted December 30, 2020 1 minute ago, Luke said: There isn't any disabling of the internal volume. I would just not use it if that's what you prefer to do. I meant if I use my volume keys on my keyboard both the internal volume and windows will change. Could I disable the internal volume controls
gokuz 13 Posted December 30, 2020 Author Posted December 30, 2020 (edited) 1 minute ago, gokuz said: I meant if I use my volume keys on my keyboard both the internal volume and windows will change. Could I disable the internal volume controls @Luke Edited December 30, 2020 by gokuz
Luke 42240 Posted December 30, 2020 Posted December 30, 2020 Ok sorry there's currently no way to do that. We'll look at improving it. Thanks for reporting.
