Flatten Seasons and Slow Episode Deletion?
1) Is there a way to flatten seasons like you can in the standard XBMC TV shows section such that all episodes are shown in one list?
2) Deleting an episode shows a progress bar and takes several seconds to complete.  Seems unusually long for this relatively simple task.  It also does not seem to delete the thumbnail jpg associated with the deleted episode?
Thanks for your help.
xnappo
1. Not - but it would be easy to add as an option.  You would want it to do that all the time and just show the season number in the title?  I might actually like it that way myself :)
2. It takes a while for the server to update.  I can make it shorter, but then sometimes when it goes back to the list the episode will still be there (though it won't really be there).
xnappo
1) Yes, please - the season number in the title.
2) Ok, I don't mind that it takes a little while as I would rather have the episode list be accurate.  Do you have any idea why the thumbnail is not being deleted?  Maybe it is related to my folder structure?  I have the episodes in a subdirectory of the show name with no subdirectory for season number.
xnappo
The delete is handled by the server. @@Luke - any way to delete images too? Personally I have the option on the server set to not put files in the directories - it isn't really needed.
xnappo
I didn't see that option.  I will just stop doing that, then. Thanks.
Edited by cncb
xnappo
Cool. I will look at the season thing when I get back in town 8/13. I have been meaning to rework the way seasons work anyway to speed it up.
xnappo
  • 3 weeks later...
Were you able to give this any more consideration? Thanks.
In progress...
@@cncb ,
I finished this in the Git - do you know how to run from there?
@@marcelveldt ,
When we add a new String - how do we need to handle other languages?  Does English fall through by default, or do we need to add a dummy?
xnappo
marcelveldt
@@cncb ,
@@marcelveldt ,
xnappo
It falls back to English as default. Please add the english string to english translation file, I'll take care of the translation.
@@cncb ,
I seem to have gotten it in a normal update today.  It works great - thanks.  The only issue is that the "larger unwatched count on artwork" change (from other thread) seems to have been reversed.
Yes - this is going to be skin specific.  Each skin will need to fix it.
The deal is that the indicators were made for the poster size used on the Roku.  XBMC skins use all sorts of sizes.  The original fix was to use a lower resolution so the indicators would be bigger - but then skins that use big posters all looked bad.  So now skins with small posters need to use the new 'small_posters' image.
xnappo
Edited by xnappo
Guest
