TheGremlin 68 Posted December 27, 2020 Posted December 27, 2020 Hi, I just noticed a wrong Scraping / Metadata filling from TMDB Source of TV Shows. in the field "Studios". It works correctly for Movies. Just TV-Shows are wrong scraped. Here are some examples to explain: Lets take a look at the new "Evil Dead (2013)" Movie: https://www.themoviedb.org/movie/109428-evil-dead?language=de On my Screenshot you can see the filled in production companys: Emby does correct scraping of these: So, as you can see above, this works correctly. Now lets take a look at a TV Show on TMDB (Children of the Whales (2017)): https://www.themoviedb.org/tv/73017-children-of-the-whales?language=en-US As you can see above, the production field got two different areas. The first are is "TV Network", the second is "Production Company" aka "Studios". In the case of a TV Show, emby fills up the Studio field with the informations from "TV Network" instead of "Production Company". Look at my Screenshot from my Emby TV Shows: As you can see, not the "Production Companies / Studios" are filled here. Instead the scraper fills up the "TV Network" information.
Solution Luke 42204 Posted December 27, 2020 Solution Posted December 27, 2020 Hi, yes you can argue that perhaps we should split them apart, but this is what Emby does and it's not going to be easily changed without causing disruption for a lot of people. However down the road if we rework studios, then it's something we can look at.
TheGremlin 68 Posted December 28, 2020 Author Posted December 28, 2020 Hi Luke, To bad it isn't something, what can be easily changed. The I will need to wait for the rework. Thanks :)
