Thuzad 50 Posted December 27, 2020 Posted December 27, 2020 Hello, I try to detect when there is a problem loading on a person reading a media. I am currently monitoring the transcoding position of each playback and I can tell if there is a transcoding problem. I'm watching if the transcoding position relative to the playback is less than 5% for more than 5 minutes. But sometimes it happens that the server is overloaded in I/O and CPU and even the plays that are done live (so without transcoding) don't load anymore and show a loading logo for a few moments. How can I detect a lag on my server and the fact that the readings no longer work? Best regards,
chef 3811 Posted December 27, 2020 Posted December 27, 2020 Hi, how are you monitoring the rate of transcoding now?
Thuzad 50 Posted December 27, 2020 Author Posted December 27, 2020 I use Zabbix and I monitor the following values via the API: TranscodingPositionTicks PositionTicks But I'm trying to find out when there is no transcoding if there are loading problems due to a server performance problem.
chef 3811 Posted January 4, 2021 Posted January 4, 2021 Do you have thottling enabled for transcoding?
Thuzad 50 Posted January 7, 2021 Author Posted January 7, 2021 Yes but when I have too many streams and a lot of CPU usage my website can sometimes freeze. And I'd like to detect this with values that I can retrieve, be it logs, API data... I have active monitoring on the CPU but it is difficult to activate alerts based on it, because of the transcoding that causes large CPU spikes.
