Thanytos 1 Posted December 25, 2020 Posted December 25, 2020 Hello, I'm trying to get House loaded into the system. I have DVD ordered files (see filelist.jpg below), which for the most part is the same as the Air Order except that in season 6, the first episode was split into two for the DVD. This means that when House is scanned with Air Order, all the metadata is off by one episode and the last episode has nothing at all, though it does at least show. When I switch to DVD order, it shows episodes 1 & 3-22 (see metadata.jpg below). Episode 2 is missing from list, but Episode 3 is actually pointing to the file for Episode 2. The file for Episode 3 isn't picked up, and then 4-22 are correctly correlated to their meta data. No matter what I've done, renaming files, deleting and readding show, rescanning, etc. nothing seems to solve this problem.
Abobader 3485 Posted December 25, 2020 Posted December 25, 2020 Hello Thanyto, Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Carlo 4561 Posted December 26, 2020 Posted December 26, 2020 Hi, I have mine setup by airdate and use this naming: I have no issue at all this way.
Thanytos 1 Posted December 26, 2020 Author Posted December 26, 2020 (edited) My Season 1 is fine. As mentioned, I only have issues with Season 6. Does your Season 6 folder contain 21 or 22 episodes? Also looks like you're using nfo files for metadata. Were these generated by Emby or did you source those elsewhere? Edited December 26, 2020 by Thanytos
Carlo 4561 Posted December 26, 2020 Posted December 26, 2020 Sorry about that mixup on the seasons. Mine has 21 episodes and matches what you'll find here:https://thetvdb.com/series/house/seasons/official/6
Thanytos 1 Posted January 3, 2021 Author Posted January 3, 2021 So, I have a work around for this. I set it back to Aired Date order and renamed all the files changing the initial E01 and E02 to E01-Part1 and E01-Part2, the splitting it apart in the UI, and then renaming the rest down an episode. This doesn't really fix the problem that the DVD order functionality isn't working right, but at least everything is viewable now. 1
Happy2Play 9802 Posted January 3, 2021 Posted January 3, 2021 (edited) The S06E01, S06E02 is a defect in TVDB previous api, don't know if it has been fixed in v4 api as it require a user subscription and there has not been a plugin update done to accommodate the user subscription pin system. You can see the metadata defect looking in Emby's \cache\tvdb\73255 folder and look at the xml metadata. DVD info missing from aired xml and dvd xmls are missing for S06E01 and 2. Spoiler <?xml version="1.0" encoding="utf-8"?> <Episode> <id>761291</id> <Combined_episodenumber>1</Combined_episodenumber> <Combined_season>6</Combined_season> <DVD_chapter>0</DVD_chapter> <DVD_discid/> <DVD_episodenumber>0</DVD_episodenumber> <DVD_season>0</DVD_season> <Director>|Katie Jacobs|</Director> <EpImgFlag/> <EpisodeName>Broken</EpisodeName> <EpisodeNumber>1</EpisodeNumber> <FirstAired>2009-09-21</FirstAired> <GuestStars>|Andre Braugher|Franka Potente|Lin-Manuel Miranda|</GuestStars> <IMDB_ID>tt1462220</IMDB_ID> <Language>en</Language> <Overview>House engages in a battle of wits and wills against the attending physician in charge of his detox program. When he starts to lose, House resorts to blackmail to gain the upper hand.</Overview> <ProductionCode>HOU-601/602</ProductionCode> <Rating>8.4</Rating> <RatingCount>4527</RatingCount> <SeasonNumber>6</SeasonNumber> <Writer>|David Foster|David Shore|Garrett Lerner|Russel Friend|</Writer> <absolute_number>0</absolute_number> <airsafter_season>0</airsafter_season> <airsbefore_episode>0</airsbefore_episode> <airsbefore_season>0</airsbefore_season> <filename>episodes/73255/761291.jpg</filename> <lastupdated>1577823805</lastupdated> <seasonid>79091</seasonid> <seriesid>73255</seriesid> <thumb_added>2019-11-13 10:20:03</thumb_added> <thumb_height>360</thumb_height> <thumb_width>640</thumb_width> </Episode> Edited January 3, 2021 by Happy2Play
