AWG97 3 Posted December 25, 2020 Posted December 25, 2020 Currently Emby seems to show Audio track ID/channels for the title. Therefore, it doesn't show the title of the track (whether it's just commentary or surround). I would love to see both Track ID/channel info and Titles. Audio track info of the media: Audio #1 ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Codec ID : A_AC3 Duration : 1 h 26 min Bit rate mode : Constant Bit rate : 448 kb/s Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 16 bits Compression mode : Lossy Stream size : 279 MiB (14%) Title : Surround Language : English Service kind : Complete Main Default : Yes Forced : No Audio #2 ID : 3 Format : AC-3 Format/Info : Audio Coding 3 Codec ID : A_AC3 Duration : 1 h 26 min Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 16 bits Compression mode : Lossy Stream size : 119 MiB (6%) Title : Commentary Language : English Service kind : Complete Main Default : No Forced : No How Embys shows it: 1
Solution AWG97 3 Posted December 25, 2020 Author Solution Posted December 25, 2020 Found out that I can change it to show track titles by going to; Settings>Library>Advanced>Embedded track title display:Prefer embedded titles
