PrincessClevage 175 Posted December 24, 2020 Posted December 24, 2020 (edited) With the recent release each time I stop media and play new media volume returns to 100% Edited December 26, 2020 by PrincessClevage
Chillout 111 Posted December 26, 2020 Posted December 26, 2020 I have the same issue. Even stopping and playing same media switches volume back to 100%.
Luke 42240 Posted December 29, 2020 Posted December 29, 2020 We're looking into it. Thanks for reporting.
PrincessClevage 175 Posted January 9, 2021 Author Posted January 9, 2021 On 12/30/2020 at 4:34 AM, Luke said: We're looking into it. Thanks for reporting. Thanks for fixing the volume issue when changing media. There still remains the default movement sounds in ET do not respect the set volume and are at 100%
Chillout 111 Posted January 10, 2021 Posted January 10, 2021 Seems to be fixed for me. Volume no longer defaults to 100%. Thanks!
PrincessClevage 175 Posted January 11, 2021 Author Posted January 11, 2021 8 hours ago, Luke said: Thanks for the feedback. When playing separate media previous video line is maintained however the default movement and action sounds in ET are still using 100% volume which can be quite disturbing with loud beeps
sooty234 266 Posted January 11, 2021 Posted January 11, 2021 1 hour ago, PrincessClevage said: When playing separate media previous video line is maintained however the default movement and action sounds in ET are still using 100% volume which can be quite disturbing with loud beeps I turn those sounds off
