ThomasTang 0 Posted December 24, 2020 Posted December 24, 2020 (edited) Hello guys, I found the transcoding(hw) speed became to very slow since 4.5.2 for the HEVC(10bit) video file after test the different files and versions many times on J3455. For the same file, the transcoding speed is around 90fps on 4.5.1 but only 6-9fps on 4.5.2-4.5.4/4.6.10(beta). My computer: CPU: Intel J3455 GPU: Integrated Intel® HD Graphics 500: 12 EUs inside (Up to 750MHz) RAM:16GB OS: Debian 10 Emby server as a docker container. Docker version 20.10.1, I also installed the emby-server on the host directly. But the result is the same. The transcode speed is slow sinve 4.5.2. I notied there are some differences about the processing plan /Projected Processing Formats/Decoder between the 4.5.1 log and 4.5.4 log ===VER 4.5.1== >>>>>> Processing Plan Info Name CanDoInHardware WillDoInHardware Reason Info VAAPI HD Graphics 500 - H.265 (HEVC) >> True True Hardware Codec Info VideoInput >> True True Same adapter (/dev/dri/renderD128), s... Info ColorConversion >> True True Info VideoOutput >> True True Hardware encoder Info VAAPI HD Graphics 500 - H.264 (AVC) >> True True Hardware Codec >>>>>> Projected Processing Formats Info Previous HW-Context Format SW-Format Next Info hevc >> VAAPI vaapi_vld yuv420p10 >> scale_vaapi Info scale_vaapi >> VAAPI vaapi_vld nv12 >> Decoder VAAPI HD Graphics 500 - H.265 (HEVC) Adapter #0: 'HD Graphics 500' Id:23173 (Driver: Intel iHD driver for Intel(R) Gen Graphics - 20.1.1 (223f94d), Vendor: Intel Corporation) Frame Sizes: max 8192x8192 Color Formats: NV12, P010, NV16 Profiles: Main Profile (Level 1 (Main)), Main 10 Profile (Level 1 (Main)) ====VER.4.5.4 >>>>>> Processing Plan Info Name CanDoInHardware WillDoInHardware Reason Info VAAPI HD Graphics 500 - H.265 (HEVC) >> True True Hardware Codec Info VideoInput >> True False Same adapter (/dev/dri/renderD128), s... Info ColorConversion >> False False Info VideoOutput >> True True Hardware encoder Info VAAPI HD Graphics 500 - H.264 (AVC) >> True True Hardware Codec >>>>>> Projected Processing Formats Info Previous HW-Context Format SW-Format NextInfo hevc >> - yuv420p10 yuv420p10 >> format Info format >> - yuv420p yuv420p >> format Info format >> - nv12 nv12 >> hwupload Info hwupload >> VAAPI vaapi_vld nv12 >> Decoder VAAPI HD Graphics 500 - H.265 (HEVC) Adapter #0: 'HD Graphics 500' Id:23173 (Driver: Intel iHD driver for Intel(R) Gen Graphics - 20.1.1 (ac0a19f), Vendor: Intel Corporation) Frame Sizes: max 8192x8192 Color Formats: NV12, P010 Profiles: Main Profile (Level 6.1), Main 10 Profile (Level 6.1) I attached the log and pic for your reference ( I test many HEVC 10bit files and select one's log of them). Could you give me some adv. how to fix this problem? Now I can only keep the 4.5.1 on my server without any update. Thank you so much! 4.5.1 4.5.4 4.6.10_on_host.txt Edited December 24, 2020 by ThomasTang
ThomasTang 0 Posted December 30, 2020 Author Posted December 30, 2020 hi, is there anyone can help me fix this problem? thank you!
Luke 42246 Posted December 31, 2020 Posted December 31, 2020 Hi, @softworkz will take a look at this. Thanks.
softworkz 5133 Posted December 31, 2020 Posted December 31, 2020 @ThomasTang - Thanks a lot for the detailed information. This seems to be a regression. We had cases where transcoding failed on VAAPI devices that are unable to convert 10bit video in hardware, so we added a check that uses the color formats that the encoder supports. That check might not be 100% correct. Could you please post a hardwarre_detection log? (it doesn't matter from which of the installations) Thanks
ThomasTang 0 Posted January 1, 2021 Author Posted January 1, 2021 (edited) @softworkz @Luke Thank you for your help! hardware_detection-63745112726_ver4.6.10.txtI installed the deb file on the host. Because I note there is no hardware detaction log in the server running as dock container. Edited January 1, 2021 by ThomasTang
ThomasTang 0 Posted January 1, 2021 Author Posted January 1, 2021 I also installed the embyserver ver.4.5.1 on the host. The transcodeing speed is fine. hardware_detection-63745120431_ver4.5.1.txt cpu.txt
fRzzy 0 Posted February 2, 2021 Posted February 2, 2021 I'm having the same problem with the same CPU on 4.5.4.0... I'm using docker, is it safe to just use 4.5.1.0 docker tag with 4.5.4.0 data folder?
Luke 42246 Posted February 4, 2021 Posted February 4, 2021 On 2/2/2021 at 1:27 PM, fRzzy said: I'm having the same problem with the same CPU on 4.5.4.0... I'm using docker, is it safe to just use 4.5.1.0 docker tag with 4.5.4.0 data folder? Hi there @fRzzy can we please look at a log example? Thanks.
fRzzy 0 Posted February 6, 2021 Posted February 6, 2021 On 2/5/2021 at 1:04 AM, Luke said: Hi there @fRzzy can we please look at a log example? Thanks. it's exactly the same as in post #1... I just change the tag in the docker-compose file from latest to 4.5.1.0, relaunch the container and transcoding works...
Luke 42246 Posted February 20, 2021 Posted February 20, 2021 Ok, @fRzzy we'll look into it. There have been a lot of transcoding related changes to the 4.6 beta channel so you could always try that as well. Thanks.
wedgekc 12 Posted April 16, 2021 Posted April 16, 2021 (edited) I also have the same problem as the original poster after installing Emby server 4.5.4.0 via docker on a Intel Pentium N4200. After downgrading to 4.5.1.0 transcoding worked as expected. emby log.txt hardware_detection-63754107571.txt Edited April 16, 2021 by wedgekc
Luke 42246 Posted April 16, 2021 Posted April 16, 2021 16 hours ago, wedgekc said: I also have the same problem as the original poster after installing Emby server 4.5.4.0 via docker on a Intel Pentium N4200. After downgrading to 4.5.1.0 transcoding worked as expected. emby log.txt 21.09 kB · 0 downloads hardware_detection-63754107571.txt 163.85 kB · 0 downloads Hi, the Emby Server 4.6 release is soon to be available. I would suggest trying again with that once you have it. Thanks.
fRzzy 0 Posted June 4, 2021 Posted June 4, 2021 with latest 4.6.2 HEVC 10bit to H264 8bit hw transcoding works again, but only with HDR tone mapping set to off. But I need to dig a bit more to see if it's my hardware limitation.
Luke 42246 Posted June 4, 2021 Posted June 4, 2021 18 minutes ago, fRzzy said: with latest 4.6.2 HEVC 10bit to H264 8bit hw transcoding works again, but only with HDR tone mapping set to off. But I need to dig a bit more to see if it's my hardware limitation. It could be, yes. Can you provide an ffmpeg log example of it with tone mapping?
